Question about Samsung HLN507 50" Rear Projection HDTV-Ready Television
The lamp light keeps blinking at me with no picture
And does not turn back off
    Scholar:
  • 195 Answers
Sounds like a bad lamp to me.
Posted on Nov 26, 2014
  • 139 Answers
SOURCE: REPLACED LAMP. I TURN IT ON AND LAMP LIGHT BLINKS THEN TURNS OFF
Sorry to say it but this acts like another bad lamp.
Posted on Mar 23, 2009
ArnelM
  • 153 Answers
SOURCE: picture works normal for 10 ses then turns off. (3 blinking light
Re-position the safety switch behind the lamp door and if still the same try replacing the lamp.
Posted on May 27, 2009
lukster
  • 217 Answers
SOURCE: After turning on TV, lamp light blinks but no picture
IF IT SHUTS DOWN TO STANDBY, THEN DIGITAL BAORD IS BAD, IF IT JUST KEEPS CYCLING ON/OFF THEN YOU NEED A POWER SUPPLY, BALLAST AND PROBABLY LAMP
Posted on Dec 30, 2009
  • 8457 Answers
SOURCE: cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
Posted on May 27, 2010
AJIN G
  • 6694 Answers
SOURCE: My HLN617W dlp will turn on with no picture (sound
hi,
Check the lamp. possibility of lamp get damaged. check the lamp if possible try to replase it. you problem will be solved.
ok
Posted on Feb 12, 2011
Sony kds-50a2000 picture blacks out and green light blinks
Either the lamp is on it's way out or..... the lamp is incompatible because it is not a original one. (ie the same as what they fit in the sony factory)
Nov 06, 2013 | Sony KDS-50A2000 50" HDTV
Green light blinking, tv won't turn on
Lamp lifetime is not 100% predictable. A lamp may fail without notice, although this is not usually the case. The picture is more likely to become noticeably dimmer as the lamp nears the end of its lifetime.
While there is nothing wrong with using a lamp until it fails, some customers may want to purchase a new lamp and replace the existing one when they notice that it is aging.
If the lamp fails in a Mitsubishi MicroDisplay TV, there will be no picture on the screen and a red front panel LED indicator will illuminate.
Jan 17, 2008 | Mitsubishi WS-65813 65" Rear Projection...
Hlp 5063w on off front button flashing lamp then stanby..hear sound no picture.. shuts off then comes on.
If the lamp and standby lights are both flashing and the timer light is off, check that the lamp cover on the back of the TV is properly positioned in the groove and secured by the screw. Take it off and check that the screws that hold the lamp itself are secure. There is an safety feature that keeps the lamp from turning on when the lamp cover is off.
If the three lights (timer, lamp, and standby) are blinking, then the lamp needs to be replaced. If the timer and standby lights are blinking and the lamp light is off, then a cooling fan isn't working. When only the standby light is blinking and the other lights are off, the unit is overheating and a ventilation area may be blocked.
I hope this helps.
Sep 30, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Lamp light turns on
How is the picture is it dimmer than usual? Also how many times does the lamp light blink in between each pause? A faulty lamp/live driver on this one would cause it to blink 5 times.. Try counting it and let me know.
Jul 16, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Dec 30, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Sony LCD Projection TV turning OFF.....help!!!
Look carefully at the front lights. Usually when these sets shutdown they have a blink code on either the standby light or the lamp light. Update this with those counts. In the meantime, you may be seeing a problem with heat. If the lamp area gets too hot, the set will shutdown the lamp. Once the area is cool again, the lamp will fire.
Update this and we'll hopefully fix the both of them.
Dan
Apr 09, 2008 | Televison & Video
Sumsung HLP 4663W
Might be a bad ballast, has the picture been dark?
Jun 21, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLN507 50" Rear Projection HDTV-Ready Television Logo
46 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
