Question about Dell Computers & Internet
My dell pc model dcslf will not power on green light on back is on and orange light inside is on
Wont power on
    Problem Solver:
  • 7 Answers
You could try opening the case after unplugging the power from the wall, then disconnect power supply from the Motherboard. then hold the pc power button in until the green back light and orange light go out. then reconnect power supply to motherboard. Plug the power back in to the wall and see if the pc turns on. Hope this helps
Posted on Apr 14, 2014
Orange light on and it wont turn on
I found this online. Many people have said this worked for them but you need to make sure you follow the instructions carefully.
Step By Step:
(Disconnect all cables, Inc the power)
1. Open the case of your Dell Pc
2. On the power supply box (top right) find the GREEN wire
(The green wire will almost always be the power switch on all Pc's)
3. Cut it at around the middle
4. Strip Both Ends
5.Find a long enough piece of wire that will reach to the front of the pc
6. Solder the GREEN wires back together but putting your seperate peice of wire inbetween them
7. Tidy them up with zip ties and shrink tubing (Electrical Tape if not)
8. Plug the power cable into the pc
9. Hold the wire onto the chassis of the pc
10. If the fans start at full speed, press the power button and let the wire off
11. your pc should be running as normal.
Mar 02, 2014 | Dell Latitude E5500 Laptop
Dell GX280 orange light on MOBO
Dell Support > Optiplex GX280 Desktop PC > User Manual,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tindex.htm
I chose the Mini-Tower model because the following information applies to all models;
Small Form Factor (SFF)
Small Desktop
Desktop
Small Mini-Tower
Mini-Tower
Computer and Software Problems > Troubleshooting Tools and Utilities > System Lights,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tools02.htm#wp1114432
Now scroll down. What do the Diagnostic Lights indicate?
Post back in a Comment.
Regards,
joecoolvette
Oct 09, 2012 | Dell OptiPlex GX280 PC Desktop
Dell inspiron 1150 wont power up the power light flashes green and batery light flashes orange but the fans or any thing else wont work
You may have a burnt board or the input pin is bad, try wiggling the pin while it is plugged in to see if you can at least get the fans to start you obviously have a short of power in the power button area. You may want to try replacing the power button board for your model this may offer you a solution. If you take it in they can test it with a meter to make sure that this is the problem before a board issue is determined. It is difficult to diagnose this kind of things without the machine in front of me. My advice is to take it in and have the power investigated.
Just because the lighting on the battery is going and showing signs of life does not mean the power button is not bad or not getting the proper power to start the computer. It seems to me that the power button board is bad. Or the input cord pin may be shorted out and only supplying power to the mains but not the power button circuitry. Just a good guess!......John
May 11, 2012 | Dell Inspiron 1150 Notebook
The power LED light is orange instead of green and it won't turn on
Hi! for most dell machines if the power led is orange its an indication of a issue with the ram, try to reseat the ram first.if that doesnt work normally for dimension 4600, there are diagnostic lights that are located at the back panel of the machine, they are four bicolor lights(amber and green) You can determine the exact problem by checking these lights and you can interpret them by going to this website: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/adtshoot.htm#1112886 hope this helps...
Jun 12, 2010 | Dell Dimension 4600 PC Desktop
My dell monitor turns on for 2 seconds then goes black and the green light blinks orange
I assume that you already try this monitor on another PC to verify that the problem is in the monitor, in this case you need to open it up and inspect the fuse, transitors, solder connections on the power/inverter board, see failed Dell monitors here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 23, 2010 | Dell E173FP 17" LCD Monitor
The power light on my dell dimension 2400 is orange (it is not blinking). The loading light next to it is green. the computer is on but it will not do anything.It wont show the dell logo or anything. What...
You May hev one of two problems, either you towers power suply is broken, or on of the system fans are not working.
Check the power supply fan on boot. If its working check the CPU fan
Regards
Feb 21, 2010 | Dell Dimension 2400 PC Desktop
Dell inspiron 1100 wont stay on
Normally the battery light will rapidly flash orange if the battery is defective. It will alternate between orange and green if it is too hot to charge. Or it will either flash orange or be a steady orange if the battery is low or completely discharged. Based on this and the fact that you cannot get it to stay on for more than 7 seconds, I would have to say that you need to recharge the battery by plugging the laptop into an AC outlet. After all, it can't run without the juice.
Apr 14, 2009 | Dell Inspiron 1100 Notebook
Orange blinking power light on inspiron laptop
I recommend purchasing a new Dell Inspiron battery.
The code 4 blinking orange or amber and one green, means a defective battery.
Thank You, Raphael
Jan 24, 2009 | Dell Inspiron 5160 Notebook
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
