I have a 5-speed 1996 ford probe the gears are becoming very hard to shift. It practically will not go into 1st gear without ''manhadling'' it. 3rd gear grinds a little. please help
Re: I have a 5-speed 1996 ford probe the gears are...
Before trying any of the costly repairs, try bleeding out the clutch slave cylinder, sounds like your clutch is not fully disengaging and there may be air in the clutch hydrolic lines.
Try changing the gearbox oil to a full synthetic 75w 90, chances are
its never been changed, these boxs are not tolerate of lack of
servicing just like the motors.
If it grinds when trying to shift, it is the synchronizers. Rebuild. If it pops out of gear. there is a plastic part at the top of the transmission that wears out. It fits around the ball of the shifter. It is two pieces. You'll have to remove the floor plate and pull it up to access the bolts to remove the shifter and replace those plastic pieces.
May 8, 2004 - 19 posts - 9 authors
Auto Trans not shifting correctly from 2nd to 3rd Under the Hood. ... Become an EliteExplorer. Lithuania. 1999 5.0. Join Date: Jun 2003. Posts: 107 ... When this happens, the transmission will skip to the next gear like you said.
? 3:59
https://www.youtube.com/watch?v=aAoiL4vR8Qw
Jan 13, 2013 - Uploaded by James Burns
... Doctor, explores the causes of harsh shifting in automatic transmissions. ... Early diagnosis is important to ...
It sounds as though your valve body may have a lot of particulates that have entered into it causing the valves to act sluggishly. Unfortunately, this is a condition that can only be taken care of by your mechanic and is not something that the average person can fix themselves.
I have a 92 Crown Vic first and second works fine reverse works fine when it shifts in the third gear it goes to slipping and overdraft can you help me fix this problem thank you
You can put the shifter in 2, 3, or overdrive. It will still start in first and shift up to whatever gear you have selected. Try it, you wont damage anythingl
What you need to check is the transmission release bearing because if there is a clearance on the release bearing you will encounter this problem and also check the transmission oil.
I own a 1995 Ford Probe SE 2.0L that suffered the same problem. The transmission shop Techs insisted the transmission was blown and needed replaced. After doing some research it turn out to be the Park Neutral Switch also known as a Transmission Range Sensor right below the air box. The part cost 54 bucks. The problem stopped after replacing it. About a year latter the problem came back. After doing some more research it turn out to be the VSS speed sensor. The part cost 57 bucks. The problem stopped after replacing it.
