My philips ppx1430 picopix turns on lights up then doesn't bring menu up why is this
How do I install the picopx viewer 2?
Contact Philips at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Mar 01, 2015 | Philips PPX1430 PicoPix Pocket Projector
Why does my ppx3610 turn from white light to purple?
I don't know if anyone else had such problem, I just wanted to share with you my experience, as i have the same model, one day from the sudden the picture turned pink , I turned off/on the unit, I have done a reset but still the same problem, the picture displayed is pink, this happen regardless if i'm watching a video or navigating in the menu, so i decided to contact Philips technical support , I sent them my unit, they have repaired it and sent it back to me, it is now working very good, no problem anymore.
May 25, 2014 | Philips PPX2495/F7 PicoPix Pocket...
Picopix connect to iphone
Try to restart your iphone or replace the cable.
Feb 01, 2014 | Philips Office Equipment & Supplies
How to connect an asus transformer to a phillips picopix 2055 projector ?
you cant, directly at least... there are no drivers for android to run this projector. since it is only USB, you cannot convert the hdmi to usb...
you could use your computer as a middle man, without hdmi input on your pc there would be video lag and your better off just using your pc.
you could return the picopix you have and get the PPX2480 version, that is brighter and also has hdmi input which you could get a mini-hdmi to hdmi cable and use it directly.
hope that helps
Feb 28, 2013 | ASUS Tablets & eReaders
Service light reset on 2006 e class 280 sports
You need to access the FSS menu, you get to the FSS screen by bringing up the status on how many miles to the next service.....then hold the reset button for five plus seconds and that brings up the FSS Main Menu. Trying to access the FSS by bringing up the outside temp screen just doesn't work on my vehicle. I was then able to follow my owner's manual directions to reset the FSS Service Indicator.......I got service at a 3rd party Euro Service Center and they hadn't reset the FSS so I was able to do it myself by using the above access process and then following my owner's manual to do the reset protocol.
__________________
Sep 27, 2012 | Cars & Trucks
I need an instruction manual for a Philips pocket projector ppx1430
Quick start guide:
http://download.p4c.philips.com/files/p/ppx1430_eu/ppx1430_eu_qsg_eng.pdf
User manual:
http://download.p4c.philips.com/files/p/ppx1430_eu/ppx1430_eu_dfu_eng.pdf
Jul 16, 2011 | Philips GoGear SA2RGA MP3 Player
I just bought a picopix projector and can get it to work on my laptop toshiba.?
the main problem people have (if everything is physically connected right) is they dont know how to activate the screen extension
In windows XP it is Right click on desktop -> properties -> settings from here you can activate your second screen
in windows 7/vista right click on desktop go to personalize -> display settings and again you should have the option to activate you second screen
this only works properly once the projector is on
Mar 11, 2011 | Philips Office Equipment & Supplies
42 plasma philips
When you turn on the set and it has sound, can you bring up the menue? tonyfalcione@msn.com.
Oct 13, 2008 | Philips 42PF9631D 42 in. Plasma Television
Can't watch footbal
NOTE: ----DO NOT TOUCH THE CONVERGENCE BOARD " -------
1. Bring Up 1 Projector Light 2. Bring Your Color Convergence + Sign and Should Be Center In Your TV 3. If Not Adjust Center with The 2 Tabs Just Above That Projector Tube You Have Lighted 1 Tab Will Move + Sign Horizontal Then Roll The Other Vertical Then Roll..U Will See--" 4. Once Your + Sign Is Center Turn Up Your 2 Other Projectors Make Sure They Are Able To Adjust Across The + Sign You used 1st Make Sure the 2 Other + Signs Move Left And Right And Up And Below The Vertical and Horizontal Lines. If Not Adjust There Tab to Make This Possible. 5. Using Your REMOTE Converge The + Signs Together. ---------------- IF YOU MESSED WITH THE CONVERGENCE BOARD ------------------- 6. Now Lower The 2 Lights So Your 1st Projector Is Lighted 7. Bring Up A Menue On Your TV -- Look At It ...Are The Lettering Center and Square ..?? 8. If They are Lower That Projector and Light Your Projectors 1 At A Time To Verify Letters are Center and Square. ---------------If You Have To Adjust The Menue To Bring Center And Square -------- 9.Looking At The Convergence Board You Will See 3 Rows Of Adjustment Dials Each Row Is For 1 Projector. ---TAKE NOTE TURN THE ADJUSTMENT Slowly--- 10. Locate The Row that will adjust The Projector You Have LITGHTED".... 11. Label On A Paper What Each Knob Will Do To The Screen Very Help-Full 12.Adjust Your Letters Dead Center and Square then Lower That Projector Light And Bring Each Projector Lighted At 1 Time To Verify Menue Is Center And Square. 13.Leave On Your 3rd Projector and Bring Up Your Light On The 1st Projector 14. Adjust the Letters Of Your 1st Projector Over The Letter Of Your 3rd Projector 15. Switch To Your Convergence + Sign To Help --Turn Knobs Slowly --- 16. Make Your Letters Merge Together And Your Lines Square. 17. I Use The Top Letters and Lower Letters And Keep The box Square 18. Hey If Your Projector Colors When Looking Through The Rear Of The TV Are Not Equal With Take And loosen The Wing Nuts And Turn The Lens To Focus the Color and Make Narrow Or Wide....All 3 - Equal DO NOT GET UPSET THIS WILL TAKE TIME MAYBE ALL DAY SO RELAX HAVE FUN" Do Not go Sticking Your Hand Into The TV While TV Is Plugged into The Wall" ---
Dec 16, 2007 | Philips Televison & Video
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
