Question about Sanyo PLV-Z4 Multimedia Projectors
Pulled the cord before cooling fan had finished
PLV Z4: Pulled the cord before cooling fan had finished Cant get the lamp on again. Lamp change didnt help
    Champion:
  • 205 Answers
What is the status lights telling you? if you dont have manual consider http://www.projectorcentral.com/Sanyo-PLV-Z4.htm
Good luck
Posted on Jul 07, 2009
  • 76 Answers
The bulb has overheated and no doubt burnt out by the sounds of it. Worth removing it or inspecting in in situ - be carfeful not to touch the surface with your fingers (use a soft cloth or a glove) otherwise you will leave an oil spot which will ruin the bulb if it isn't already!
Posted on Jul 11, 2009
PLV-Z2000 Projector Your question about PLV-Z2000
what about the Projector Condition leds: POWER, WARNING and LAMP REPLACE? How are they lit? For good measure you should also clean the air filter (the projector might not be getting enough air to cool the lamp)
Jan 09, 2012 | Sanyo PLV-Z2000 Projector
How to change lamp timer on sanyo plvz4
Hello
* Turn the projector ON, and press the MENU button to display the on-screen Menu. Select the 'setting' menu with point UP/DN button. Press '>' button to acess sub menu items.
* Select the Lamp Counter reset and press the OK or '>' button. "Lamp replacement counter reset?" will appear. Select "Yes" and then press OK or ">" button
8 Another confirmation dialogue box appears, and select "Yes" to reset lamp replacement counte.
** Do not reset the lamp replacement counter without implementing lamp replacement. Be sure to reset the lamp replacement counter only after replacing the lamp.
Dec 17, 2011 | Sanyo PLV-Z4 Multimedia Projectors
How do i change my lamp timer
Resetting lamp timer can be done by selecting the menu and proceeding according to the window display - interactive.please check this link for tips:http://www.relampit.com/Projector-Lamp-Timer/Sanyo-Projector-Lamp.php
I replaced the lamp and it still indicates that the lamp needs to be replaced
The lamp timer must be reset and so this will reset the processor to switch on the lamp.Please follow instruction on the manual, open main menu and proceed as directed.
Hi, i have the projector since january 2009, i use it no more than 2 hours a week, sudenly the lamp stupped to work, and when i try to get it on - the replace lamp is flash, what is the prublem?
Was it new when you bought it. (that is, are the lamp hours approximately 220 hours genuine)
take the lamp out and check that it looks OK.
The unit may have an electronic fault on the lamp power supply board.
Mar 26, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Just replaced the lamp on a sanyo plv-z4 and it still indicates lamp needs replacement. what do i do now?
reset your lamp counter. go to the menu find lamp setting. then reset. click OK 3 times
Oct 07, 2009 | Sanyo PLV-Z4 Multimedia Projectors
Sanyo PLV-Z4 Multimedia Projectors Logo
518 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
