Question about Funai DV-220SL8
How do i fix or alter the video tracking? - Funai DV-220SL8
I've got Dvd recorder with video cassette recorder DRVR-B778S, can you please tell me how I can alter the tracking on this machine.
Angie Taylor
Posted on Nov 16, 2010
Does anyone know if there are seat track extenders for a hummer h2 .I'm 6'5 and need the seat to go back just a little bit more
There's no after market product that will help you.
Your options are to have an engineering shop that will fabricate extended tracks for you, or alter the seat itself so it will fit further back on the current tracks.
Nov 02, 2015 | Hummer H2 Cars & Trucks
How do I fix the tracking on a video already shot
You cannot do any corrections. The video tracking signal is set. The best that you could do is use editing software to try and crop it.
Sep 12, 2014 | Canon GL2 Mini DV Digital Camcorder
Windows Media Player audio louder than voice
Since Video and Audio are on separate tracks, the only solution is to obtain a program that allows you to alter one or more tracts to your satisfaction. Wondershare Video Converter Ultimate v6.6.0.5 is an example.
Feb 10, 2014 | Audio Players & Recorders
I'm Changing the boot on steering rack ,Do the whole steering rack comes down ,or can I just change boot
Just remove the track rod end and lock nut, counting the turns on removal, otherwise you will alter the tracking,
Remove and renew gator and refit track rod end with new locking nut.
It is possible an oil leak from the rack seal has been primary cause of gator failure? have you noticed power steering fluid loss?
If so you require an exchange S/rack.
Good Luck!
Let me know your feedback.
John the Jag..
Dec 14, 2012 | 1996 Jaguar Vanden Plas
Hp designjet 500plus ,first time i change carriage belt ,but now it shown allignment error..
Two thing you need to check:
1. Are you replaced genuine carriage belt?.. Original belt having two type of inner tracks.. Right side horizontal & left side vertical tracks. Are you fixed it properly or not..
2. Check carriage assembly play.If it is over play(carriage bushes may be warn out) alignment won't complete, If bushes are available in your country replace them & do the calibration..If not go down how to alter bush. see the snap shot
3. While carriage movement pl check trailing cable flexibility.
Carriage Bush:
Note:This modification only professional not for users:
Un screw screws both sides as shown in fig, take out bushes estimate how much warn out happened.
Thing needed:
Fevi quik(glue),small peace of miler sheet,scissor & tweezers.
Cut miler sheet in to small peace & insert warn out place of bush(between bush & rail) & apply glue, fix it permanently,do it both sides & check for the carriage play.. once its finished try for alignment.. For this activity no need to remove carriage assembly from the rail. Main aim is alter bush warn out..
May 30, 2012 | HP DESIGNJET 500 InkJet Plotter Printer
Photos are all discolored when viewed. How to correct?
Yours description sounds more like a monitor dying but it may well be the video card in the computer so you have to try to determine which it really is.
I would be inclined to try the monitor on another machine and see if the defect recurs.
This will give you an idea which track to follow.
If the problem stays with the monitor, you might best consider getting a new one.
If the problem is not apparent on another system try altering your video card parameters and see if that might have effect..
Feb 11, 2010 | ViewSonic VA1912wb Monitor
Can i alter my tracking myself?
yes if you a tracking gauge .can be done with a metal adjustable rod as well ,evan used a lengh of string before now to put a truck on the road for the work the following morning
Nov 03, 2009 | 1997 Ford Escort
Mp3 player is changing the order of my tracks
it may be set to shuffle/random mode which may be altering the sequence....or it may be getting sorted name/size wise....check for the shuffle/random thing first....if that is not the case then change your track names to sequenced numbers1,2,3,....so on....your roblem should be rectified by either of the two methods
May 21, 2009 | Audio Players & Recorders
Altering an mp3 track
hi,
If you simply want to overlap the voice, you can do that by recording using any free softwares available on internet (just google free recording softwares)
you can try, cooledit as well, one track will contain your file with play mode, one track with record mode (for your voice)
then start recording, it will play the song simultaneously with recording your voice.
After then, you have to save the mixdown.
other long way is, you have to get KARAOKE for that song (karaoke means, no vocals only music track) then you'll get the recorded song in good quality.
Hope this helps.
Thanks.
May 11, 2009 | Apple Computers & Internet
Funai DV-220SL8 Logo
203 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
