Question about Samsung BL103 Digital Camera
Aperture How do I change the aperture?
  • 164 Answers
1. Select the MANUAL mode by rotating the mode dial.
2. Press the Fn button and menu for the shutter speed and aperture value will display.
Up / Down button : changes aperture value
Left / Right button : changes shutter speed.
3. Press the Fn button twice and take an image.
Posted on Apr 01, 2014
In creative mode I can not adjust aperture or time for any of the functions. My camera is cannon 500D
Only in the Aperture mode and in Manual mode, you can choose the desired Aperture. It is all in the manual page 53, 54 and 55.
You can change Blurring / sharpening of the background (this most of the time will change the Aperture) you can change the brightness (will change the shutter speed) and you can add some image effects and choose for single shot, continues and self timer.
You can't directly choose for changing A, or S.
Nov 22, 2014 | Cannon Cameras
Tip
How does aperture setting affect a photograph?
The aperture is the opening in the lens through which light passes to the image sensor. Changing the aperture setting allows you to control the depth of field of a photograph. When the aperture is opened to a widersetting, (indicated by a lower f-stop number) more light is passed to the imagesensor, creating more shallow depth of field. Closing the aperture (indicatedby a higher f-stop number) allows less light to pass to the image sensor,creating wider depth of field.
NOTE: The aperture setting is one of three primary settings usedto control the overall exposure of a photograph. The other two primary settingsare ISO and shutter speed. Because the three settings work together to produce the overall exposure for a photograph, changingthe aperture setting will require complimentary changes to either the ISO or shutter speed to produce a properly exposed photograph. These changes will bemade automatically by the camera in the Auto, Program, Aperture-priority andShutter-priority modes.
There are two ways tocontrol the aperture setting on the camera:
  • Aperture-priority mode (A) - When shooting in Aperture priority mode (A), you set the aperture value and the camera automatically sets the optimum shutter speed for you.
  • Manual mode (M) - When shooting in Manual mode (M), you control both aperture and shutter speed, which gives you maximum creative control to achieve the exact results you want.
on Jan 08, 2011 | Cameras
How do I switch to an aperture higher than f/32 on my nikon d3000?
Yes. Just lock the lens aperture ring at its smallest setting (largest f/number). If you need to change the aperture, change it from the camera body by turning the command dial, the same way as with a lens without an aperture ring.
Jul 18, 2014 | Sigma 50mm F2.8 EX DG Macro Lens For Nikon
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
May 16, 2011 | Nikon D60 Digital Camera
I'm doing a project for school and i need to change the aperture for different photos. But my camera refuses to take the photo on any other aperture. Why is there an aperture adjuster if you can't use it....
It depends on the lens.
If you're using a lens with an aperture ring, simply set the exposure mode to Manual or Aperture priority and change the aperture by turning the aperture ring on the lens. In Aperture priority the camera will set the shutter speed appropriately, in Manual you have to determine the appropriate shutter speed. If you want to use such a lens in Shutter priority or one of the Program modes, you must set the aperture to its smallest setting (largest f/number) and lock it.
If you're using a lens without an aperture ring then it's a bit harder. You can only use the camera in Shutter priority or one of the Program modes. You turn the command dial on the camera to change the exposure, and the aperture will change. If you want to use an exposure different than what the meter suggests, you can adjust it by using either exposure compensation or changing the ISO setting (or both).
If you need a manual, you can download one from
http://butkus.org/chinon/nikon/nikon_n6006af/nikon_n6006af.htm
Mar 08, 2011 | Nikon N6006 35mm SLR Camera
How do I change the aperture on my N6006? And what do I change it to? I keep getting a fE E error message.
That depends on the exposure mode.
In any of the P modes, turn the aperture ring on the lens to its smallest aperture (largest aperture) and lock it. You control the exposure by turning the command dial on the camera.
In S mode, lock the aperture ring as above. Turning the command dial changes the shutter speed and the aperture changes to match.
In A mode, control the aperture by turning the aperture ring on the lens and the shutter speed with change to match.
In M mode, control the aperture by turning the aperture ring on the lens and control the shutter speed by turning the command dial.
If the lens doesn't have an aperture ring, you can only use the P and S modes.
Nov 14, 2010 | Nikon N6006 35mm SLR Camera
I have copied and pasted someone elses problem, because it is the same one I am having. So if I want to use the aperture for taking Manual photos I cannot do this because when it goes off of F22, it reads...
Lock the aperture ring at its smallest opening (in this case, F22). Change the aperture setting by turning the subcommand dial (the one in front, unless you changed it in the setup menu).
Of course, you can only change the aperture directly in Manual and Aperture-Priority modes.
Mar 23, 2010 | Nikon D80 Digital Camera with 28-80mm Lens
How do I adjust the aperture on the Nikon D5000 DSLR camera?
It depends on the exposure mode.
In Program mode (P), turn the command dial and the camera will shift the exposure by changing both the aperture and the shutter speed.
In Aperture-priority mode (A), turn the command dial and the camera will adjust the shutter speed to suit.
In Manual mode (M), hold the aperture button and turn the command dial.
If you're using a lens with an aperture ring, turn it to its smallest aperture (largest f/number) and lock it.
Feb 17, 2010 | Nikon D5000 Digital Camera
Nikon F65 35mm how to change the aperture
If the lens has an aperture ring, it must be locked at the mininum aperture (largest F/number). In PSAM modes use the command dial (possibly in conjunction with the exposure compensation button) to change shutter speed/aperture.
Sep 30, 2009 | Nikon F65 35mm SLR Camera
Aperture priority not working...HELP!!
Hey Mike, This is an easy one. With the battery grip attached, you can only have either Shutter Priority or Aperture Priority work properly. You can change it with the custom function settings of the camera. So you can change it to work with Aperture Priority if you use that more so then shutter priority won't work. Brandon
Oct 21, 2006 | Nikon F100 35mm SLR Camera
Samsung BL103 Digital Camera Logo
59 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
