Question about Konica Minolta bizhub Office Equipment & Supplies
Ink smeared dirty print
The paper prints with a horizontal smear of extra ink across the top. Used to be from just one tray. Is now also happening printing from the second tray we switched to.
  • Konica Minolta Master
  • 6,161 Answers
What model machine what color
Posted on Jan 10, 2016
maverick24
  • 56 Answers
SOURCE: print jobs smeared
Hi Are you using OEM or rebuilt toners? If your using OEM and your able to smear the ink with your finger more than likely you have a fuser problem?. If your using rebuilt cartridges it could be the cartridge. Good Luck!!
Posted on Dec 03, 2007
heather_09
  • 28 Answers
SOURCE: Dirty smudges when printing
try to go to the enternal part of your printer and check if theres an inks.. or try to check on the set-up if you have a clean printheads... try running it again...
Posted on Jun 12, 2008
mitpatterson
  • 74 Answers
SOURCE: samsung CLP-300 dark prints and smears
For starters remember this is not meant to be a PHOTO Printer, I am guessing the Spearing is because Glossy paper does not hold the toner like Regular paper or at least until it is fused. I am a technitiian and i also own this printer.
Posted on Jul 18, 2008
Corysf62
  • 188 Answers
SOURCE: prints roller smear marks
Laser printers do not use Ink. The problem is most likely a defect on the drum, which in this model printer, is part of the toner cartridge. Replace the black toner cartridge with a known good one and test.
Posted on Oct 04, 2008
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
How to clean phaser 7750
Included general maintenance video and how to clear smears from the paper.
Solution: Remove Print Smears / Printing Fuser Cleaning Pages
7750 Support Knowledge Base Remove Print Smears Fuser Cleaning...
With Troublshooting highlighted on the printer display perform the following steps:
  1. Press OK.
  2. Press the Down Arrow and scroll to Print Quality Problems.
  3. Press OK.
  4. Press the Down Arrow and scroll to Remove Print Smears.
  5. Press OK. The printer will print 5 cleaning pages.
Repeat this process five or six times, to remove stubborn toner buildup from the fuser.
Always make sure you are matching the type of paper loaded in the printer tray(s) to the correct Paper Type front panel setting. When you load a tray with paper, the front panel will ask you to indicate the type of paper you loaded. For correct print quality and printer operation, be sure to set this correctly.
MAINTENANCE:
Phaser 7750 Video Instruction Maintenance for the Printer Phaser
Apr 23, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
Aspire 7535 7235 series
Changing drawers wont solve a problem like that. You have to clean the printing heads, and all the area around the printing head. It's best to let a proffesional do the job.
Apr 01, 2014 | Konica Minolta Office Equipment & Supplies
Ink from smearing all over my papers
Using original cartridges won happen like this.
May 30, 2010 | Canon Pixma MP450 All-In-One InkJet...
How do I clean the printer nozzles as it leaves streekes on printed pictures?
If the ink is smearing, it probably is not getting enough drying time. The ink drying time is a period of time inserted between pages to reduce the chance that a page will smear the one below it in the output tray. This time is factored into the time between when the first page finishes and when the next page finishes. Printing will pause temporarily if more time is needed. The time it takes for ink to dry varies greatly depending on paper type, printer driver settings, humidity, and temperature. In addition, the paper and print settings may affect the speed at which the ink can dry:
  • Transparencies require much longer drying times than other paper types.
  • Some store-branded photo papers do not allow ink to dry correctly because of the coatings used in their manufacture.
  • Printing in Best mode can increase the dry time.
Resolving the problem If the ink smears, increase the drying time. To increase the drying time in Windows, follow the steps below:
  1. When ready to print, click File , click Print .
  2. Depending on your driver version, click Properties , Settings , or Preferences and follow the steps below depending on the option.
    • For Properties or Settings , follow the steps below:
      1. Click the Advanced tab.
      2. In the Extra Dry Time section, move the slider toward More .
    • For Preferences , follow the steps below:
      1. Click the Basics tab.
      2. From the Basics tab, click Advanced Features .
      3. In the Extra Dry Time section, move the slider toward More .
  3. Try a sample print and see if the drying time needs to be increased more.
To increase the drying time for a Macintosh computer, follow the steps below:
  1. From the File/Print Menu , select Ink under the General tab.
  2. In the Dry Time section, move the slider toward More .
Other steps that will reduce ink smearing If the ink still smears when printing, try some of the following suggestions:
  • Decrease the amount of time it takes for the ink to dry by decreasing the print quality to Normal or Fast mode.
  • Try printing on a different type of paper or on paper from another manufacturer. Paper formulas are different between manufacturers and may have a coating that causes the ink to be absorbed at different rates.
  • When printing large graphics or photos on plain paper in Best or Normal modes, improve the results by using heavier paper. Paper that is rated at 90 g/m2 (24 lb.) or higher will not curl or smear as easily as paper of a lighter weight.
Mar 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
Hello, when it prints it makes a noise and bottom of page is smeared
Smeared output can result when you re-feed a printed page into the printer to make a double-sided page. This happens because the rubber rollers that grip the paper to pull it into the printer can pick up toner from the first side’s printing and smear it. So before replacing parts, this is an easy thing to check. Printing multiple pages consecutively will make the pages print progressively cleaner or you can clean the rollers with rubbing alcohol.
Smeared toner also happens because the nonstick coating on the fusing roller is scratched or has baked-on debris. This can happen if the printer is in a dirty environment especially. If you are comfortable removing the fuser, you can try to clean it with a soft cloth and alcohol, but make sure you let it cool down first!
Finally, if this does not resolve your issue then make sure the fuser is heating; toner that is not heated properly will fall from the page and smear. If the thermostat is bad or the fuser not working properly, you will most likely need to replace the entire fuser assembly. This will be pretty expensive to repair so hopefully it's one of those other issues.
As for the noise, there are several complex gear and roller segments that drive the paper between the paper tray, the scanner, the fuser, and the finisher. If these are not perfectly aligned or dirty the printer can make a grinding noise. It's even possible that if the paper is not being fed correctly, that the shift might leave segments of it less accessible to the fuser and prevent the toner from adhering to the page.
But I would try using WD-40 to lubricate some of these components and assume the noise and the smearing are separate issues.
Nov 18, 2009 | HP LaserJet 3330 All-In-One Printer
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
Konica Minolta 2300W ink smears
check the transfer belt..there is a reason why some used printers are sold on ebay!
be prepared for sticker shot.
Apr 08, 2009 | Konica Minolta magicolor 2300DL Laser...
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
My photo prints have lines across them?!
the glossy paper you are using (hp) is smearing the ink... there is now ink on the feed rollers and you need to get in there and clean it all up with alcohol...also run epson matt paper for a few prints to get the color to lay down ..good luck
Oct 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Streaked & smeared printing on envelopes
Check area where the envelope is pulled into the unit. There may be some debris causing the ink to smear.
Sep 24, 2008 | HP OfficeJet 7310 All-In-One InkJet...
41 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
