Question about Samsung Computers & Internet
Samsung M101XBB led flashing 3 times
After initialization, the led of hdd flashing 3 times.. someone know what is the signification of this post indicator ?
  • Samsung Master
  • 3,320 Answers
Probably a power issue. Try using a powered hub
Posted on Apr 02, 2014
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
8560 printer shut itself down and will not true back on
The following lists the chain of events that occur when you turn on a printer. You can follow this list as one means of determining if the printer is operating correctly. The exact chain of events depends upon the last power down condition and where the printer has last determined the printhead is positioned, this is stored in non-volatile RAM. The Checklist is the primary reference for troubleshooting power-up problems.
1. Power cord is plugged in and the power switch is turned on:
2. Power supply senses AC line voltage conditions (110 VAC or 220 VAC)
and enables DC voltages. If an overload occurs, the printer turns off the high voltage DC supplies, causing a "blink" effect on the Control Panel LEDs.
3. BIST test flashes the PE LED very briefly at a fast rate until the end of the
next test.
4. The Boot loader performs CPU initialization and RAM test. It then sends
the boot loader version to the serial port.
5. Power-On Self Test (POST) initializes the Control Panel. The Control
Panel LED turns red, green, orange, and then off. The Control Panel LCD then goes black and then clear. The POST version displays on the LCD
and waits two seconds. During this time the operator can press the Back
button to bypass the remaining POST test.
6. Low level Power-On Self Test (POST) diagnostics are performed. The
Control Panel displays status messages as each sub-test is performed.
This test takes about 8 seconds. All LEDs are off during the test.
If POST diagnostics pass, the Control Panel displays the Xerox logo and turns on the green LED.
If the test detects an error, the error message displays on the LCD and the printer flashes the LEDs with a repeating error code pattern.
7. The VxWorks operating system is initialized and engine code is started.
This takes about 15 seconds. The Xerox logo is displayed.
8. Print Engine Self Test (PEST) diagnostics are then performed. These test
the heaters, clutches, motors and solenoids. As each clutch is tested, you hear clicking with four high tones as each motor is tested. This test takes about 30 seconds.
9. The printer now runs the mechanical initialization. The exact sequence
depends on the initial position of the printhead and wiper assembly.
Feb 28, 2014 | Xerox Phaser 8560MFP Laser Printer
8560 shut down and will not turn back on
next test.
Panel LED turns red, green, orange, and then off. The Control Panel LCD then goes black and then clear. The POST version displays on the LCD and waits two seconds.
During this time the operator can press the Back button to bypass the remaining POST test.
Control Panel displays status messages as each sub-test is performed. This test takes about 8 seconds. All LEDs are off during the test. If POST diagnostics pass, the Control Panel displays the Xerox logo and turns on the green LED.
My Panasonic TCP54G25 will not turn on. Red LED begins to blink ~3sec indefinitely.
The Y-sustain board should be suspected.
Visit this site 'Electro-help' for more details. All details about this fault have been described here in detail with illustrations. Type in "electronicshelponline.blogspot" into your browsers' search box, and click search. It is a blogspot site in English language. Pull up older posts there.
Jun 27, 2012 | Panasonic Tcp54g25 54 1080p Plasma Tv...
Led flashing 3 times,
Please post the make and model as each has their own blink code. I can provide more detailed info once I know the make and model.
Thanks,
Dan
Jun 18, 2008 | Panasonic Televison & Video
The samsung monitor ssc21web shows system initialize... the three periods blink
ssc21 web does not work, It was a cameras shut down it says LA and AL why
May 15, 2008 | Samsung 4 Channel Dvr
SAMSUNG IDE HDD SP0411N (40GB)
Three possible reasons:
1. Your IDE cable is defective or is not seated/plug in correctly. Try to replace or re-seat/re-insert;
2. The on-board disk management of the hard disk is corrupted/defective. There is no remedy except to replace the PCboard or the entire hard disk;
3. Your motherboard BIOS/CMOS needs to be flashed and/or something is wrong with the IDE interface.
Of the 3, # 1 is the most common.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Jan 06, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Connecting hdd led lead and power led lead,where do they go ?
Hi, There are 3 versions of this motherboard; 1.0, 2.0 & 3.3, but the layout is identical. The general layout is shown in pins.jpg. For the power led, the white wire goes to the (-) terminal either pin 2 or 3, both are MPD- while the green goes to the ( ) or pin 1 (MPD ) as shown in powerled.jpg HDDpins.jpg shows the connection of HDD led, the white goes to pin 3 or HD- while the red goes to pin 1 or the HDD . I cropped these images from the manual which is also available at the gigabyte website. Hope this gives you some ideas and workout of you. Good luck and pls post again how things turn up. Kind regards.
Aug 15, 2007 | Gigabyte GA-965G-DS3 Motherboard
Computers & Internet Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
