Question about Baby Lock Sewing Machines
Babylock Endurance embroidery machine is noisy when the hook turns
I have a babylock 6 needle endurance. When the hook turns it is very noisy. However, as speed picks up, it doesn't squeak anymore. I have oiled the machine very well, cleaned the hook, and cleaned the bobbin case. What could be causing the noise?
SOURCE: Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Posted on Nov 17, 2008
SOURCE: thread gets caught on bobbin and jams
You may need a new bobbin case if your machine is an older model.. Over time the cases get nicks in them causing thread to catch on it. Have you lubricated the bobbin area? Needs one drop of oil for every ,I believe it is 25 hours of usage. That may take care of it. The oil goes under the bobbin right in the center of bobbin case. Remove your bobbin before applying the oil. i hope this helps you. Good Luck
Posted on Jan 08, 2009
  • 9 Answers
SOURCE: Babylock seger machine keep breaking the left side needle.
Try rethreading the machine, and make sure the thread is not wrapped around anything. Then check the tension for the needles. Run a few inches of chainstich off slowly, while watching the thread and loopers make the loops over the finger. Your threads may be in the wrong position, or underneath the wrong parts to start.
Posted on Jun 12, 2009
SOURCE: Bobbin problems!
MAKE SURE you are using the correct SIZE bobbin. Some of the older plastic bobbins don't swap around in the newer machines & just because they LOOK the same doesn't mean they are. If you are absolutely POSITIVE you are using the right size bobbin (mark it w/ a permanent marker if you have to, to keep track of it), check & double check you are putting the bobbin in the case in the right direction & make sure there aren't any loose threads anywhere in the area where the bobbin sits... be sure all little dust bunnies are removed. I know it sounds redundant but get your book out & be POSITIVE you are threading thru all the thread paths in the right direction. My Babylock is supremely **** when it comes to putting the shuttle back in after I've cleaned the bobbin area & if I don't get it back exactly where it supposed to go, it won't sew right. I always have to get my book back & check it out again step by step. I have it do crazy stuff just because there was a little tail hanging out where the bobbin started to wind that I didn't cut off close enough.
Posted on Aug 04, 2009
miket756
  • 2702 Answers
SOURCE: NEEDLE WON'T PICK UP BOBBIN THREAD
im not!
it needs a good service the timeing has sliped out a little, nothing more that that,,,see its not a lost cause just yet
Posted on Oct 24, 2009
Testimonial: "Thanks! I was hoping to avoid paying for a fix, but it looks like I have to **** it up. So much for being thrifty and restyling my clothes."
I just purchased a babylock QTS428K what kind of needles do I need
Unable to find information on your particular Babylock machine. However, the manual should tell you what needles to use.
Similar models from the same era probably use the same needles.
Otherwise, a Babylock dealer would be able to help you.
http://www.sewingpartsonline.com/babylock-sewing-machine-parts-model-list.aspx
Jan 31, 2017 | Sewing Machines
I have a Babylock BMP9 6 needle embroidery machine. The automatic needle threader mechanism is not dropping down far enough to use to thread the needles. Any suggestions on how to fix this?
On older machines that do not have the automatic needle-up feature, the user needs to manually adjust the needle height so the threader will match the needle eye.
Oct 29, 2016 | Sewing Machines
Do The ESE ESante Baby Lock hoops fit the ESI ESante Baby Lock machines
The Babylock Esante ESE1 and ESE2 hoops are not compatible with the Esante ESI1 or ESI2 hoops. The Babylock ESI1/2 used the same hoops as the Brother PC7000 and PC7500. The ESE1/2 use the hoops that are compatible with the Brother PC6500 and PE700 series embroidery machines.
I wish that I had better news for you. This site has hoops for sale for both the ESI1 and the ESE1: http://www.allbrands.com/categories/871 . If you need hoops for either machine, use the compatibility data on each machine type to help you find more vendors that may have the embroidery hoops.
Jul 30, 2015 | Baby Lock Esante
Babylock frozen tight its a eklure plus only used 6 time I've check bobbin cade changed needle although it was fine shut it off and turn it on. Bobbin winder on right side. It threw up a safety warning...
Sounds like it's time for a visit to the repair shop Babylock Ellure
is a fairly nice machine, it will be worth it...
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 23, 2014 | Sewing Machines
I need a visual on how the thread cutter looks when put back properly together
This was the best video I could find on the machine, I don't know anything about sewing machines but this might just help you.
https://www.youtube.com/watch?v=q-okTBWAHMs&list=PLsmrvZ1PDyoN-cFLYrfx8ovktM6PNo5RQ
May 01, 2014 | Baby Lock Imagine
Embroidery cards
try babylock.com or a babylock dealer
http://www.babylock.com/contact-us/
Nov 12, 2012 | Sewing Machines
I am on the second letter of an embroidery pattern and the needles keep breaking. I have tightened everything as much as possible. I have never had this problem before. I am using the correct needles. Any...
I have a babylock serger & I use SCHMETZ UNIVERSAL NEEDLES on the serger & I don't have any problem with the serger
you should also check the tension to make sure it correct for fabric & needles
also make sure the needle is not in backward--flat side goes to the back of the machine.
if you need a manual contact babylock customer service
Mar 26, 2012 | Singer Quantum XL-1000 Computerized Sewing...
Sewing Machines Logo
52 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
