Question about Franke Plumbing
I need a Franke faucet model # FF 822
This is a gold faucet. The cold water faucet does not work I tried calling Franke and they don't have it. Any ideas on where I can find it. I purchased it in 1992
  • 50 Answers
I would try E-bay. Might also look for a rebuild kit. A last resort: Take it apart clean all the parts and then reassemble. Good luck.
Posted on Apr 01, 2014
  • 203 Answers
SOURCE: Two handled faucet not working
could be 1 or 2 things either an air lock or a valve is blocked
Posted on Nov 22, 2008
jj505
  • 195 Answers
SOURCE: no hot water
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
You will find a quicker answer and free parts for your bath room faucet at link above . I am sure it is the mixer valve assembly. If you are not a plumber I suggest a pro be called.
John
Posted on Mar 16, 2009
jj505
  • 195 Answers
SOURCE: single handle pull out Franke faucet stopped working
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
Thanks and Please Rate jj505
Posted on Apr 06, 2009
SOURCE: I have a franke filtered water faucet and it is leaking
I have a similar problem and while I've gotten further along than you have, I still don't have the complete solution. The little "ceramic" disk that says "Franke" on the knob does come off. It's just well glued on and requires destroying two x-acto blades and putting some large chips in the logo disk to get off. Once you get the disk off you'll discover that the knob requires a special tool to remove. I haven't been able to locate one but usually when you buy a replacement washer/gasket set it will come with the special wrench to remove the fastener from inside the knob. So if you locate a faucet repair kit for that faucet, let me know!
Posted on Aug 07, 2009
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
My Franke FF-200 faucet does not swivel -
get the water main turned off , drain faucet then take top of tube off carefully. get a tub of vasoline and grease it put it back together and turn on water
Feb 13, 2015 | Franke Plumbing
How do I remove a seized handle on my FF-600 Franke faucet.
Refer to the link for drawing of the FF.660.
It looks like the Cover 45019 attaches to the faucet body I would brush some vinegar on/in any openings around this part for several minutes then heat the cover by pouring hot water over it after that use a Strap Wrench to try to turn the cover anti clockwise. It may take a few tries to dislodge the corrosion before it will release. Repeat with Valve 3699 and a wrench.
http://www.guillens.com/faucetparts/franke/images/FF600.jpg
Nov 10, 2013 | Plumbing
LOW WATER PRESURE FROM A FRANKE KITCHEN FAUCET
There probably is sediment where the water is coming at the valve. Remove the head of the faucet and clean it . This normally is the problem.
Dec 24, 2012 | Franke FF-303 Kitchen Faucet with...
Franke pull out spray broken
check to see if the weight on the hose got shifted too far back (if it was loose it could slide along the hose).
Feb 08, 2012 | Franke FF-303 Kitchen Faucet with...
Hello i have a franke kitchen faucet #fff303 and the spray head is not working is there a replacment head you can send me?
There are websites that give instructions for disassembling the Franke faucets. Also, some have a valve cartridge ($20-50) that can be replaced (you take the handle off, the catridge is inside)/
Jun 15, 2011 | Franke FF-303 Kitchen Faucet with...
It sprays fine but off the spray thair is no presuser . we replaced the water lines in the house we have good preasure though out our home jest not at the kitchen sink
One of the greatest things about Franke Faucets is that they have a lifetime guarantee. If you recently changed the waterlines in the home then more than likely when the water was turned back on or lines pressurized the settlement in the water main (Outside of your home) was activated and clogged the aerator. Most aerators simply turn counter clockwise (With the water off) after remooving the aerator simply clean and dislodge any particles in another sink. As for the pull out, some models have an inline screen located between the hose and the faucet handle. Simpy remove the handheld faucet (With the water off) and clean the screen.
Feb 02, 2011 | Franke FF-303 Kitchen Faucet with...
Plumbing Logo
56 people viewed this question
Top Franke Plumbing Experts
Donni Steen
ray gallant
William Wurtinger
Are you a Franke Plumbing Expert? Answer questions, earn points and help others
