Question about Schiller Cardiovit At 1 Ecg Machine
Electrode lead off light indicator
I have replace the fuse and it work one time after that, then the electrode lead off light indicator came on and was told to to replace the lead wires. I bought a new set and still have the same problem.
    An user who is expert in 3 categories / brands.
  • 575 Answers
Please let me know
Posted on Apr 10, 2017
    New Friend:
Hi I have the same problem.. of you have already solved the problem please let me know
Posted on Mar 25, 2017
How to do conecct arc welding machine bx1-250
The black lead is connected to the metal you are attempting to weld, it has the silver ground clamp connected to it
The remaining red lead with the electrode holder connected to it holds the electrode
These welders are also capable of using 125 & 230 vac, 1-phase current from your mains there is usually a switchable indicator on the machine allowing you to select the input voltage
Nov 01, 2014 | Welding Tools
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
System will not start up after a winter's rest!
On page 41 of the manual, a no-display indication can be related to a loose ribbon cable (check the cable is fully inserted into the connector), or a loose or bad connection at the white connector between the transformer and the PC board ("Check connector at white plug to insure proper connection. If burnt connector contact authorized service representative.")
As you operated the pool during the winter, did you remove the sensor and replace it with an optional spool piece, or did you leave the sensor in operation and perhaps subject it to freezing? The sensor can be permanently damaged if it was subjected to freezing.
Try removing the cell and cleaning it.
First I would go through and check all of the connections. If they are OK, and as this occurs after you make the connection to the electrode, I can't help to wonder if the electrode is clogged or damaged beyond repair.
The correct method for winterizing is section 6.5, on page 40, of your manual.
May 07, 2014 | Zodiac Jandy AquaPure Ei up to 35k...
Welsh allen at-2 lead light is on however ekg machine will not give tracing
There is some problem with the patient cable. Any one of the lead is broken inside. AT2 senses the presence of all the lead first and then only it will acquire the ECG and store it in its memory,after that it will print the ECG.
If any one of the lead have some problem. it will not go to the next procedure. and will indicate the lead off light.
1. check are you connected the lead correctly.
2. clean the electrode properly.
then try one more time. if problem remains. you have to replace the patient cable.
Feb 04, 2011 | Schiller Welch Allyn Cardiovit At 2...
Need do know the spark plugs gap
If you're replacing the spark plugs in your car engine, you'll need to set the gap before reseating the spark plug. The gap is the distance electricity arcs between the ground electrode and center electrode. The gap must be set correctly to ensure maximum performance. Here's how to set the gap of a spark plug.
  1. Remove the spark plug wires. Use a socket wrench to remove the spark plugs from their chambers.
  2. Clean the spark plug if you are not replacing it with a new one. Remove all dirt and debris from the spark plug.
  3. Check the owner's manual for your car (or any appliance with spark plugs) to find out the recommended gap setting.
  4. Use a gap tool to check the gap of the spark plug. Slip the tool between the ground electrode and center electrode. The gap tool should fit snugly at the recommended gap width indicated on the tool.
  5. Push the tool between the electrodes a few times to ensure proper gap. If the gap is too wide, push the ground electrode firmly against a flat surface to narrow the gap and then check again with the gap tool.
  6. Repeat Step 5 as necessary until you reach the correct gap. Reseat the spark plug and reattach the spark plug wires
Good Luck
Dec 10, 2010 | 1997 Pontiac Grand Am
Pilot won't lite.
replace electrode and make sure their is a gap of 3mm from electrode to burner and replace ignition lead from d.s.i box also find ignition box and look at it as you start the oven (in the dark) if you see blue sparks replace it
Apr 22, 2010 | American Range AR-4B-24G Gas Kitchen Range
Amana stove top burners click, and gas comes out, but won't ignite. It's a self cleaning ARG7200, about 11 or 12 years old. Oh, and can I lift this top? I'm used to doing that with old pilot-light...
A weak erratic spark from one or more electrode usually indicates a bad spark module. No spark from one of the electrodes while the others work properly usually indicates a bad electrode. Inspect the porcelain of the electrode for cracks, chips or burn marks. If there are any, the electrode should be replaced. If one of the burner knobs is turned to the light position and nothing happens, but all the others function correctly, the spark ignition switch for that one burner is likely bad. The switch can be taken out of the system and checked with an ohmmeter. It should close for continuity at the light position only.
Go here for:
Amana Range/Stove/Oven Parts
appliance parts, help & more
Sep 21, 2009 | Amana Kitchen Ranges
Igniter has started sparking below the range top, not at the top of the electrode. I have a 5? year old Kenmore 75508. The one igniter has stopped working. It only sort-a worked for about a year, now its...
your insulation below the electrodes is breaking down and the hi voltage to make the spark at the electrode is grounding out...replace fix
Jul 30, 2009 | Kitchen Ranges
The bottom oven on my stoves cooker ignites but then constantly clicks and will not stop until the gas dial is switched off. Can any one give me a clue as to why? Thanks
As an ex stoves enginneer, the problem may be one of three faults;
1. cracked electrode, what creats the spark in the oven
2.electrode lead has melted.
3. faulty ignition generator.
Try takin the lead off the electrode and placing it in the oven flame, if this stops the clicking, then replace the electrode.
Jun 10, 2009 | Stoves Ovens
Pilot light will not stay lit
my pilot is lighting but my deep fryer wont light
Sep 06, 2006 | Pitco Frialator SG14 Deep Fryer
Schiller Cardiovit At 1 Ecg Machine Logo
590 people viewed this question
Top Schiller Medical Experts
Jim Goldsmith
Jim Goldsmith
Are you a Schiller Medical Expert? Answer questions, earn points and help others
