Question about Epson Artisan 800 All-In-One InkJet Printer
Paper jam on a mfx-3530? how do i clear the problem
Paper jam
3 Suggested Answers
  • 13433 Answers
SOURCE: E-04 Clear Paper Jam, no paper in printer
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
  • 28 Answers
SOURCE: paper jam message does not clear
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takiqq14
Posted on Sep 04, 2009
JAM ERROR 0207 ON CANON IR 3530
Open the printer and remove the paper jam.
Dec 04, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
How to read meter on mfx-3530?
You can print the machine's information and job report.
1. Press Menu on the control panel.
2. Press the up/down arrow to highlight System Setup and press OK.
3. Press the up/down arrow to highlight Reports and press OK.
4. Press the up/down arrow until the report or list you want to print appears.press OK.
To print all reports and lists, select All Reports.
5. Press the left/right arrow to highlight Yes at the Printing? prompt and press OK
May 28, 2014 | Muratec Mfx-3550 Pro Edition mfx-3550 Pro...
Printer keep saying paper jam
The most common cause is the green paper guide in the paper cassette is pushed towards the paper too much. I am referring to the large one right in front as you open the tray. Move it out towards the front a bit, lessening the pressure that it is applying to the paper.
Oct 12, 2013 | Muratec Mfx-2550 mfx-2550
Paper jam at the fixing unit for IR 3530
Check the exit sensor actuatir and the the fusing unit upper and lower roller strippels.
Apr 18, 2013 | Canon IMAGERUNNER 3530 Copier
My copier say open side cover and remove paper every time i try to print? Why is it doing this
Because it "thinks " there is a piece of paper jammed.
Open the machine make sure there is no jam, take out the paper cassette and check or change the paper for fresh paper...put the cassette back in and try to make a copy again. As a last resort try making a copy with a piece of paper thro the "by-pass" tray and see what happens.
Nov 16, 2010 | Muratec - MFX-1300 Copier
Paper jam
OPEN THE MACHINE...THERE ARE ALSO GOOD INSTRUCTION IN THE USERS MANUAL ON HOW TO CLEAR ANY JAMS AS WELL AS ON THE DISPLAY OF THE MACHINE IT SHOULD TELL YOU WHERE TO LOOK.
Aug 21, 2010 | Muratec MFX-2830 Black and White Copier
DP 3530 error code E04-02
Hello sir; You have to look at heating unit you havv paper jam over there!
Aug 23, 2009 | Panasonic Workio DP-3530 Copier
Jamming of letter size paper
You will probably have to set the paper size in the settings of the machine and/or on the software driver on the PC (if you are using it as a printer?)
May 26, 2009 | Muratec MFX-1500E Plain Paper Laser Fax
Paper jam message but there's no paper
There should be an exit sensor, as part of the fuser unit, I suspect it either has not been connected or is physacally jammed out of position. Check these areas, and also for pinched wires.
Hope this helps.
Ed
May 07, 2009 | Muratec MFX-1500E Plain Paper Laser Fax
Muratec mfx-2000 error problems
please check the switch of mentioned cover may be it is abnormal or open and close the front cover or check may be there is one reset switch in your machine
Sep 26, 2007 | Muratec Copier
Epson Artisan 800 All-In-One InkJet Printer Logo
78 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
