Question about Intel (P42000400512SK478) Pentium 4, 2 GHz Processor
Cannot continue when i open my pc sometimes it cannot open it always display its processor then stop? is my processor damage or my memory or my hardware? when i open the case of my processor then back then start my pc sometimes it continue but if i restart it will hang there displaying my processor, can you help me?
  • Anonymous Nov 19, 2007
    cannot continue to open.Just up to missing data pool.
  • 26 Answers
Try change the battery on the motherboard, then disconnect things like your hard drive and cdroms annd floppy drive because you might have a problem with one of them, also disconnect everything else except your screen and maybe keyboard then see, if this doesn't help try updating the bios
Posted on Nov 03, 2007
  • 143 Answers
I am VERY confused by your description here. I can't tell if you're talking about the processor as it appears inside of your computer itself...or if you're refering to the processor as it appears in Windows.
Please try to be a little more specific with your explanation. Go step-by-step in what you are doing and what is happening.
Posted on Nov 01, 2007
Screen is black
Have you used the laptop for a PowerPoint presentation?
1. Sometimes when the laptop have been used with dual displays, one disconnects it in EXTERNAL display mode. You can restore it to LCD display by pressing both FN+F5 (or whatever F-KEY with two monitors printed on.
2. Check the memory sticks. Test one at a time to see if there is one damaged; if that fails, the problem may be the video card, or processor.
Aug 25, 2012 | Acer Aspire 55421462 Notebook
Compaq presario sr5000 no power but fans run cd rom opens and closes.
First check the processor fan is working if working remove the memory from the slot clean with a clean cloth and rub the conector with a erasor dont use any metel or any other thing insert the memory and see if the lock is locked on to memory properly still not working change the memory sutable for the memory slot still not working removce the processor heatsink and the processor clean the surface and apply athin layer of heat sink compound and fix back the processor if still not working change the processor if still not working use an addon graphics card and check for display
Oct 27, 2011 | Compaq Presario 5000 PC Desktop
My hp dv6000 won't boot up or show any display.
- Try cleaning the memory first, undetected memory leads to no display.
- Try using external monitor if displays shown up. If it has display then you have a Laptop LCD damage but if not then you have a video chip problem.
- damaged processor can also leads to no display.
Mar 28, 2011 | HP Computers & Internet
How to disassemble the Samsung NP-QX410-J01US to repair a cracked LCD Screen.
I highly recommend not opening your laptop to avoid further damaging it and voiding your warrantee.
Instead, call Samsung for help at1-800-SAMSUNG
Mar 07, 2011 | Samsung Laptop / Intel Core i5 Processor /...
Five long beeps at a range of five seconds then, repeats
Five long beeps for a modern motherboards indicates a processor failure. If you wish to remove the processor and re-seat it (reconnect it to see if it begins to work again) make sure to get some thermal compound to put between the CPU chip and the heatsink. More info at:
POST AMI BIOS beep codes
  • 1 - Memory refresh timer error
  • 2 - Parity error in base memory (first 64 KiB block)
  • 3 - Base memory read/write test error
  • 4 - Mother board timer not operational (check all PSU to MB connectors seated)
  • 5 - Processor failure
  • 6 - 8042 Gate A20 test error (cannot switch to protected mode)
  • 7 - General exception error (processor exception interrupt error)
  • 8 - Display memory error (system video adapter)
  • 9 - AMI BIOS ROM checksum error
  • 10 - CMOS shutdown register read/write error
  • 11 - Cache memory test failed
  • 12 - Mother board does not detect a RAM module (continuous beeping)
Source: Wikipedia
Feb 28, 2011 | Computers & Internet
I cant get my desktop toturn on completely...i have 2 amber lights and 2 green lights in the rear...sometimes it wont even start up and i have no display on the monitor...any suggestions?
For that open cpu cabinet
Reattach the RAM memory.
Open processor fan and processor reattach both.
Make sure motherboard circuit could not ground with cabinet.
Pull cmos cell from motherboard for 10 minutes .
Remove pci cards from motherboard if any.
Reattach VGA card if installed.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 25, 2010 | Dell Dimension 3000 PC Desktop
Dell vostro 400 2 beeps in bios post test
The cause of beeping is the memory problem. maybe the memory stick is not inserted correctly. If your memory stick will not correctly inserted it will damaged the memory slot. Try to use the other slot, if the same thing happen. You memory slot will be damaged you need to bring you motherboard to the computer repair center. Ask first how you will pay, if the labor cost is high. its better to buy a brand new motherboard.
Aug 01, 2009 | Computers & Internet
My pc is giving continuous beep voice.
Probably some hardware defect. You could try removing unnecessary components. Of course, as a minimum, you need the CPU and memory. If you have more memory modules, you could try them one-by-one, if this is possible with the particular type you use. Please note, some motherboards / memory types require to use particular slots for particular configuration, to use modules in pairs, etc (please consult manual).
Mar 20, 2009 | eMachines D3123 Desktop Computer With AMD...
If the hard drive is is not damage maybe you can save all important files on it.
Please do the step by step troubleshooting of your laptop.
REmove the following:
1. Memory
2. hard drive
3. processor:
4. Battery
try this;
1. Fix some other connection inside the laptop
2. Insert AC plug then start the system.
3. shutdown the system
4. Insert the processor
5. swittch on the laptop.
If beeping; continue
step 3;
6 insert the memory.
7. start the system
8. If display, connect the harddrive.
in step 5: if not beeping:
Either board or processor is dead.
IN step 8.
9. start the system.
10. if the hard drive is detected, and cannot continue booting
i recommend you to reinstall the windows.
Please notify me if problems arises. i will give you further instruction, melnavz.
Feb 04, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Intel (P42000400512SK478) Pentium 4, 2 GHz Processor Logo
134 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
