Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
I replaced the motor on my Whirlpool Cabrio dryer because of loud screeching noise, drum was turning fine. Motor is replaced, I get power to the panel but does not do anything after pressing start. I
Electric problem
  • 1073 Answers
SOURCE: Replace belt on Whirlpool LE09508KQ1 Electricl Dryer
remove the lint fiter and remove the two phillips screws then lift the top up
you will find two screws on each side of the inside of the frount panel down about 4 inches , this when removed will allow you to swing the frount arround to gain access to the belt
Posted on Apr 30, 2008
SOURCE: Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Posted on Jul 12, 2008
kachbibi1
  • 979 Answers
SOURCE: Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Posted on Jan 14, 2009
  • 15 Answers
SOURCE: dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Posted on Jul 20, 2009
  • 1738 Answers
SOURCE: Whirlpool Calypso dryer GEW9868KL2
It is one or two things. Motor start switch or the motor itself.
Posted on Aug 11, 2009
How do I diagnose/fix my Whirlpool Duet Electric Dryer which won't turn on.
access electric motor and disconnect from dryer, jump wire the motor with a wire with plug to see if motor is burnt out.
Jan 18, 2016 | Whirlpool Washing Machines
Whirlpool cabrio gas dryer
It could be a bad bearing in the drive motor or on the tub if it is a really high pitch,, or it could be the drive belt on the tub is slipping.
Oct 27, 2013 | Dryers
My whirlpool cabrio dryer is making a loud knocking noise
Check to see if one of the paddles are lose in the dryer drum.
Nov 23, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
How can you tell if the motor for the dryer is working
if your inclined to jump the wires to the motor 110 volts it will tell if the motor is good
May 20, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have a LG Dryer, DLG2102W. It is about 2yrs old and is making rumbling and screeching noises when on. I am thinking is is a belt or roller
The problem (noise)can be from both side or area !
However, Loud noises coming from a Whirlpool dryer are most oftencaused by loose objects inside the unit or by a broken dryer belt. The dryerbelt allows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually cracking and then snapping. This willcause a loud noise within the unit. Repair and fix the dryer belt of aWhirlpool dryer to get rid of loud noises. Instructions And Things You'll Neededto solve the problem.
Screwdriver ,Replacement dryer belt 1 Stop the Whirlpool dryer and look inside thedryer's drum for any loose objects such as coins, pens or anything else thatmay have been in a pocket of clothing. Remove the object and restart the dyerto determine if the noise has stopped.
2 Unplug the dryer from the wall outlet todisconnect all power to the unit. 3 Remove the lint trap from the lint compartment onthe top of the dryer. 4 Remove the screws that hold the top panel inplace. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum toremove the belt. Check the dryer's belt. A belt that is worn, cracked, split orbroken will cause loud noises. 6 Slide the old belt off of the drum and pull it outto remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel awayfrom the dryer and slip the new belt over the drum. Locate the position of theold belt and slip the new belt following the old belt's position ensuring thegrooved side of the belt faces down. Push the idler pulley towards the motor toallow you to slip and loop the belt around the motor pulley.
8 Place the top panel on the Whirlpool dryer andscrew it in place.
9 Open the dryer door and use your hand to rotatethe drum counterclockwise a few turns to ensure the belt is secured.
10 Plug the dryer into the wall unit and begin use.If the noise still exists, you'll want to call a professional repairtechnician. Thanks for using fixya.
Jul 31, 2011 | LG Dryers
There is a squeaking noise upon starting the dryer no matter what size load is in there. it lasts throught the whole cycle. its a pretty loud screeching noise.
Unplug dryer. Remove front kick panel, Remove door. Lift top and lay it back, be sure to support it. Take tension off belt. Remove drum. Replace all worn parts the hold up drum. Check belt tensioner for ware and replace if needed.
Jun 03, 2011 | Whirlpool Maytag Bravos MGD6600TQ Dryer
Drum not turning-very loud sound coming frm dryer when turned on
There could be multiple problems with you whirlpool dyer depending on the type of noise you are hearing. If the noise is a low grumble or loud buzzing sound this could indicate a bad motor. Which could explain you not hearing the drum turning. If however you hear a grating or grinding type noise but the drum is turning, this could indicate that something is rubbing or has become jammed inside the blower fan that circulates the air. if this is the case it too may have to be replaced. Also the drum can sometime come off the drum support rollers at the back of the dryer, but this is very uncommon, and only happens if they are very worn or broken. This can easily be diagnosed by a technician and if the motor is fine, will cost little to repair.Hope this helps.
Thanks
Nov 07, 2009 | Whirlpool LER4634J Electric Dryer
Drum on dryer noisy when turning
Sounds like you have a bearing problem with the motor. I had to replace the motor to solve a similar problem. I was worroed that it might go on fire the noise was awful.
Jul 08, 2009 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
