Question about Vehicle Parts & Accessories
I have a 94 dodge ram 1500 4x4 with remote start today a co worker used her keyless remote to get into her vehicle thos happened twice today is there anyway to shut my remote start off i believe it is factory but not sure
  • 33 Answers
Not sure what your question is, but dodge had no factory remote start system on any vehicle in that year. I assume you did not purchase the truck new and the previous owner had the system installed. Let me know if you're still experiencing the problem and I can help you resolve it.
Posted on May 11, 2014
  • 5 Answers
SOURCE: remote starter wont work
there are a number of things you need to check.Make sure you have all of your voltages,acc,ign,constant12v.Make sure you have a good tach signal.On the Auto start brands a goood ground is needed.make sure your brake wire is connected.If there is a nuetral saftey wire,please connect it to ground.
Posted on Feb 27, 2009
cbgarner
  • 138 Answers
SOURCE: 94 nissan altima GXE keyless option
Any vehicle can have keyless entry installed as long as the car has power door locks.I would recommend the viper aftermarket keyless entry. It works very well.
Posted on May 14, 2009
smarthome2
  • 1114 Answers
SOURCE: my new 2009 dodge grand caravan keyless remote
RF interference. same bandwidth as there sat communications system. It happens. Hope this helps.
Posted on Aug 23, 2009
  • 171 Answers
SOURCE: I bought a used 2005 dodge ram and the only
You MUST HAVE one working remote to add one more to the system. If you do not have one working remote right now then these instructions will not work. You will have to have a Locksmith or dealership use a computer to program the first remote for you.
1. Turn ignition to the RUN position (as far as you can go without starting the engine).
Wait for chimes to stop.
2. Using original programmed remote, press and hold the UNLOCK button on the
remote for between 5 and 10 seconds.
3. While holding UNLOCK button, and before 10 seconds passes, press and release
the
PANIC button. A chime will sound to indicate that the transmitter programming
mode
has been entered.
4. Within 30 seconds of the chime, press a button on all remotes to be programmed
into the system including any previously programmed remotes, a chime will
sound after each remote has been programmed.
5. Turn the ignition OFF to exit the transmitter programming mode.
6. Test Remotes
Posted on Jan 08, 2010
dj_relly999
  • 4070 Answers
SOURCE: My husband just purchased a used vehicle 2-5-10,
good day, you may try checking the battery of the remote for it may need a replacement. usually there a small screw attaching it. hope this helps, have a nice day
Posted on Feb 10, 2010
2014 dodge ram keyless entry only working intermittently with both remotes
Check owners manual and see where antennae for entry system is located. You may just have a poor range on the system's antennae, but sounds off to me. The vehicle is new enough that dealer should talk to you about it for free. They may have a bulletin on the issue and will tell you about it if you ask them. Too new to have system going bad, batteries in remotes maybe, but both at once would be a bit fishy.
Feb 16, 2015 | Dodge Ram Cars & Trucks
My 2006 Dodge Ram 1500 has electric door locks. I bought it used and just had one key. How can I tell if it has keyless remote entry or what do I have to do to add it
In order to determine if you have a factory installed remote keyless entry (RKE) system, you need to remove the instrument panel and check if the RKE module has been installed. It is located practically in the center of the back of the instrument panel. It may be more economical to have an aftermarket system installed that to get two factory replacement remotes.
The doorlock system utilizes a single wire setup. You will need to use resistors and two relays to interface the doorlocks. The resistor values you need are 820 ohms to ground through a relay for lock and 330 ohms to ground through the other relay for unlock.
Jan 24, 2011 | Alarm & Keyless Entry System Dodge...
I bought a used 2005 dodge ram and the only keyless remote I have does not work. I have already replaced the battery. Can I re/program this remote myself? If so how?
the
mode
has been entered.
6. Test Remotes
Jan 08, 2010 | Alarm & Keyless Entry System Dodge...
My dodge caravan '09 keyless entry does not work at times
I've had the same problem with my 2009 Grand Caravan also.
I asked the dealer about it, but they weren't aware of anything regarding this. Since it has only happened a couple of times during the past year I haven't done anything else about it. They offered to replace the RKE fob (remote) if the problem persisted.
Sep 25, 2009 | Alarm & Keyless Entry System Dodge...
2003 dodge ram 1500, won't start, red security light flashes
The probably installed an overlay harness past the SKIM module it think the car it being hot wired it is a security feature. They need the install the interlock system prior to the SKIM module to keep it from locking up.
Aug 25, 2009 | 1998 Dodge Ram 1500 4WD
My new 2009 dodge grand caravan keyless remote
Aug 23, 2009 | Alarm & Keyless Entry System Dodge...
May 14, 2009 | DEI Python 1400XP Remote Start/Keyless...
2006 Mazda 5 keyless remote fob
I am a technition for mazda, and if the lights are coming on to the keyfobs, the batteries are fine. What procedure did you follow?
1. Take key out of ignition
2. Shut all doors
3. Open drivers door
4. Insert key to ignition
5. Cycle between On & Lock 3 times, leaving key in Lock
6. Close and open the drivers door 3 times, leaving the door open
7. The Locks should cycle.
8. Press the Panic button on the remote twice.
Jan 31, 2009 | Alarm & Keyless Entry System for Mazda...
Vehicle Parts & Accessories Logo
85 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
