Question about Berkel 827E Gravity Feed Deli Meat Slicer
How to change the bushings in my 827 berkel slicer
Bushings
  • wally
    wally Apr 01, 2014
    this is a 827 and want to know how to replace the bushings on the slide and meat feedr
3 Suggested Answers
  • 20 Answers
SOURCE: Berkel 827 sharpener not working properly
Your grinding stone stud is more than likely frozen try and lossen it up with a little penetrating oil take the sharpener off and work both stone back and forth untill they are both spinnig freely and remember do not apply either sharpening wheel on the knife for more than 5 seconds at a time you can burn the wheel and then it will never get sharp
Posted on Jun 13, 2009
  • 5603 Answers
SOURCE: BERKEL 825 THIS IS NOT
It s NOT uncommon to have new parts be slightly different than old version of the part and require slightly different hookup. The part number you have included does NOT appear to be a rocker switch.
I do see a rocker switch part number "823-00039-1 SWITCH, ROCKER" that may be what you need if it is a rocker type. The part number you gave is a "toggle" type with a "bat handle".
I suspect the problem is they gave you the wrong part.
Posted on Jan 04, 2011
Berkel slicer wiring diagrams
If its an an ac unit (i.e plugged into the 110Vac wall outlet) and the switch is the on/off switch, it doesn't matter which one goes on which terminal.
Aug 01, 2014 | Berkel 829E Gravity Feed Slicer Manual...
How to remove berkel slicer blade
my berkel slicer model 818 the motor runs and the automatic table will slid but the blade does not torn
Jun 01, 2012 | Berkel 827E Gravity Feed Deli Meat Slicer
I need a manual for a berkel slicer
here you go
https://my.vulcanfeg.com/resourcecenter/vulcanwolfberkel/ProductDocumentation/BK46700.pdf
Oct 10, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
I need a manuel for Berkel 170d slicer and stacker, where can I get one.
Jun 14, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
I have a berkel meat slicer which the blade wobbles on ,
Hi and welcome to FixYa, I am Kelly.
Most models have a bearing, washer and spacer that are support the knife/blade in the head housing. The parts are cheap and not to difficult to change.
Parts catalogs can be loacted using this link:
https://my.vulcanfeg.com/resourcecenter/vulcanwolfberkel/ProductDocumentation/Forms/ViewAllPartsCatalogs.aspx
You can use the following link to locate a distributor near you:
http://www.berkelequipment.com/Berkel/Service/
Without a model number I used the 823-827 series models as a reference here:
https://my.vulcanfeg.com/resourcecenter/vulcanwolfberkel/ProductDocumentation/F43190.pdf
Thanks for choosing FixYa,
Kelly
Mar 14, 2011 | Kitchen Ranges
Slicer 827a roaring noise
This can be due to the motor bearings/bushes that have worn out and is slightly having the gap within,
When the load comes on the motor must be firmly moving on the main shaft without a fraction of a gap.
To confirm use some light oil into the motor shaft where the bearing/bushes are and try out. If so you might have replace them to fit well , get help from a machine tool shop.
If the mtor seems perfectly alright then the mechanism of the cutting blades, the moving parts here- one of them - can be the suspect. Take carre to check when the power is on.
Sep 18, 2010 | Berkel 827E Gravity Feed Deli Meat Slicer
Feb 03, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
Berkel 827E Gravity Feed Deli Meat Slicer Logo
49 people viewed this question
Top Berkel Kitchen Appliances - Others Experts
john raffaele
Level 1 Expert
Lawrence Oravetz
Are you a Berkel Kitchen Appliances - Other Expert? Answer questions, earn points and help others
