Question about Maytag MAH6700AWW Neptune Front-Load Washer
E3 code comes on during a wash cycle
Error code E3 keeps coming up during a wash cycle. Not all the time but when it does the machine wont work. you can hear it trying to work but nothing happens. Sometimes it occurs at the beginning of a wash other times the load is almost done. I have tried unplugging it and plugging back in - sometimes this works. Other times it doesnt. I have also tried manually moving the drum one direction and then the other - again this occasionally works. I can do many loads and not have any issues and then all of a sudden - doesnt matter what I do it wont work. Then after Ive taken laudry to laundormat- go to use again and it will work. Very Sporatic.
  • 121 Answers
SOURCE: frontload washer will not complete a load..shows E3 on display
e3 is a motor sensor not reading the motor properly un plug the unit for 5min and try it that will clear it but you may need a new sensor check the connectors at the motor sensor
Posted on Nov 30, 2008
  • 119 Answers
SOURCE: Washer gets E3 error and stops right after aggitation begins.
Posted on Jul 07, 2009
  • 1776 Answers
SOURCE: getting error E3
3E == overcurrent detected at the motor.
Open the control panel, there you will find a tech sheet that explains how to put the machine into service mode and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes. You will also find serveral other diagnostic service notes. Read them and follow the instructions to test the motor, motor control, and main control board. Hope this helps.
Posted on Jul 16, 2009
  • 725 Answers
SOURCE: E3 code showing sometimes on Neptune MAH-3
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Posted on Sep 23, 2009
  • 194 Answers
SOURCE: At the middle of my load there was stop with code symbol E3
E3 is that the machine can't see that the motor is spinning. Could either be a loose connector at the motor or a loose hall-effect sensor. this might be a fairly easy fix for a repair tech,
Posted on Dec 27, 2009
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ... > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Wont pump out comes up with E3 on display
Jun 11, 2015 | Washing Machines
Error e3
Thank you for your post, friend!
I understand that your Electrolux washer is displaying an "E3" error code while it is spinning. However, it appears "E3" is an invalid error code. It is possible that the error code is missing characters? I suggest resetting your washer. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, and your washer continues to display "E3" I would recommend contacting a professional to come and properly diagnose your appliance. -Matt
Aug 11, 2014 | Electrolux Washing Machines
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
My washer has passed all the diagnositc test BUT when running through a simple quick cycle it keeps beeping E3
e3 means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 02, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune washer will not get up to speed in spin cycle error code E3
E3 means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code somes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 09, 2010 | Maytag Washing Machines
Maytag front load washer keeps giving an E3 error during wash, rinse and spin cycles. Not all the time. Sometimes restarting the washer works, othe times not. It seems the error occurs when the tub won't...
The machine control ("main computer board") is attempting to drive the motor but not detecting any tach response from it. The E3 fault code appears when the rotor or the drum is locked or the Hall Sensor is faulty. But the intermittent behavior of the problem suggests a loose wiring connection. Check the harness that connects the Hall Sensor and the motor to the machine control and make sure the connections are snug fit and not corroded. Clean the connectors and terminals then reseat the connections several times to clean off dirt and corrosion build up in the connectors and terminals. Replace the wiring harness if necessary or if it is badly corroded.
Indicate the exact model number of the washer if the problem is not addressed above for further advice.
Jun 06, 2010 | Washing Machines
E3 error
looks like a heater failure it statrs to heat at about this time into wash mode.
Nov 13, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My NEC NFL855 E3 error
E3 error is discharging water problem. ie 1.the pump not working (under bra wire will stop it spinning) or 2. the discharge hose blocked or most likely 3. the pump inlet hose from the drum is blocked (with small article of cloth or coins or similar).
To Fix:
1. Open the pump filter and check if spinning during empty/spin cycle, make sure nothing jamming or twisted around impellor.
2. Check discharge hose is not crushed or kinked.
3. Lay machine on its side, access pump and remove inlet hose assembly and remove any blockage.
Jul 19, 2009 | Washing Machines
E3 keeps poping up
Hello leggettelect,
The e3 code has to do with the Hall Sensor. This is a sensor that looks at motor RPM. There have been some issues with the wire harness or the harness connectors being loose. You can also get the code if the sensor itself is loose and cant read the motor RPM. Here is a link to a tech bulletin from Maytag explaining it in more detail and has some pictures so you can see what to check. Hope this will fix your problem.
May 12, 2009 | Washing Machines
Maytag MAH6700AWW Neptune Front-Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
