Question about Nortel 1120E
Display still shows "Forwd Intg" and "Transfer" - No "Msg Wait"
Our default display has "Msg Wait" next to the top left button, blank next to the button below that, and blank next to top right button. After I had enabled call forwarding, my display shows blank next to top left button, Transfer next to next button below that, and Forwd Intg next to the top right button. I was able via the manual to turn off forwarding, but the display didn't revert to the default. The result is I have no hot button to speed dial my voicemail when one or more messages are waiting.
4 Suggested Answers
SOURCE: Forwarding Calls to My Voicemail?
Just turn do not disturb on.
Posted on Aug 20, 2009
consultel1
  • 860 Answers
SOURCE: Meridian M7208. I managed to reset the default
Press feature *3, press the button you want to program back to speed dial, and press feature 0.
Posted on Oct 06, 2009
Testimonial: "It worked!"
cnavarro
  • 2460 Answers
SOURCE: Forwarding outside calls from 1 extension to
You're not forwarding calls, you're TRANSFERRING calls. Try Feature 70.
Carl
Posted on Apr 15, 2010
How do I set the fax confirmation with image on a Samsung SCX4521f multifunction printer
Press Menu until "Fax Setup" appears on the top line of
the display.
The first available menu item, "Default-Change", displays
on the bottom line.
2 Press the scroll button ( or ) until you see the desired
menu item on the bottom line and press Enter.
If you select "Default-Change", you will see "Resolution".
Press Enter again.
3 Use the scroll button ( or ) to find the desired status or
use the number keypad to enter the value for the option
you have selected.
MSG Confirm
You can set your machine to print a report showing
whether a transmission was successful, how many
pages were sent, and more. The available options are
On, Off, and On-Err, which prints only when a
transmission is not successful.
Image TCR
You can prevent the Image TCR from being included in
the confirmation report for privacy or security
protection. The available options are On or Off.
4 Press Enter to make your selection. The next Fax Setup
option appears.
5 If necessary, repeat steps 2 through 4.
6 To return to Standby mode, press Stop/Clear
Jan 21, 2015 | Samsung SCX 4521F All-In-One Laser Printer
How to put photos on my sd card
This more than likely means your internal storage is low and not the SD card and may not have anything to do with your pictures but more so with your apps. Go into settings and see if your tablet has the feature to set where your downloads and other media is stored, by default that will be your internal memory. change it to SD card or USB storage. In Settings you can also click on your apps individually and transfer them manually one by one to the SD card or USB storage or download a file manager and do so all at once. Some apps and files may not have the feature to transfer these apps the tablet came with or apps you downloaded that uses the internal memory. By default if a memory card is in you tablet pictures are automatically store there, if this is not the case the easiest way to transfer is connecting the tablet to a computer/laptop and transfer to the card or again use a file manager.
Aug 15, 2014 | Acer Iconia Tablet with 8GB Memory - Steel...
Installed new cartridge still says low in ink
  1. Disconnect the power cable.
  2. Hold down On/Off button.
  3. Reconnect the power cable.
  4. With the power button still down, press the Stop/Reset button twice.
  5. Release the On/Off button.
  6. The printer is now in factory mode (wait until idle is displayed)
  7. Press the right arrow button (next to the OK button) repeatedly until Shipping Mode 3 is displayed.
  8. Press the OK Button
  9. Wait until "Without Cleaning" is displayed and then press the Stop/Reset button once.
  10. A test page should print.
  11. Open the cover. (the cartridges should position themselves at the far left - the cartridge removal location)
  12. Disconnect the power cable.
  13. Remove both cartridges.
  14. Close the cover.
  15. Reconnect the power cable.
  16. Press the On/Off button.
  17. Wait until a Replace Cartridges message is displayed. Now insert the cartridges.
  18. Wait until the printer is operating in its normal mode. The display shows the normal start menu
Dec 24, 2010 | Canon PIXMA MP470 All-in-One Printer
How do you set for 7 days lights on and off
Intermatic has two slightly different ways depending on model. first way:
Press MODE until the screen displays PGM
with blanks for time.
Press DAY/DST as many times as necessary to
display 12:00 a.m. and the day(s) you want
the program to activate. Choices are:
- everyday
- weekdays only
- weekends only
- a specific day
NOTE: If you go too far, keep pressing DAY/DST to loop back
around again.
Press HOUR+ to set the hour you want the program to turn ON.
Press M+ to set the minutes you want the
program to turn ON.
Press NEXT ON/OFF to set the OFF time for the
program. The screen again displays blanks.
NOTE: Since you're setting an OFF time for an
ON event already programmed, choose the
same days as in the ON event.
OFF.
program to turn OFF.
At this point you have two choices:
Press MODE if you are finished to exit from programming.
Press NEXT ON/OFF to set another program. Repeat from
Step 2 above.
Second way:
Press the MODE button one time. (PGM) will be displayed on the top left corner of the timer. We are setting the ON time for Program 1. --:-- -- 1 ON will be displayed on the screen.
Press the DAY/DST (bottom left) button to select the day or series of days the timer is to turn ON. You can either select the ASTRO time, which will adjust as the days get longer and shorter or a specific time. To use the ASTRO time press the DAY/DST until SNST appears on the screen. All seven days will be shown on the bottom of the timer.
Or to use a specific time press the DAY/DST button and select the day or series of days the timer is to turn ON.
Use the HOUR+YEAR- (bottom center) button and select the HOUR to turn the unit ON. Use the
M+ZONE+YEAR+ (bottom right) button to set the MINUTES of your on time.
Press the next ON/OFF button one time. We are now setting the OFF time for program 1. Press the DAY/DST (bottom left) to select the day or series of days of operation. To use the ASTRO time press the button until SNUP appears on your screen.
Or to select a specific time, press the DAY/DST button and select a day or series of days the unit is to turn Off.
Press the HOUR+YEAR- (bottom center) button and set the hour of your off time. Press the M+ZONE+YEAR+ (bottom right) button to select the minutes of your Off time.
For additional programs press the NEXT ON/OFF button to the next program and follow above steps. Check the unused programs to assure they are blank. To check the other programs press the NEXT ON/OFF button, you should see --:-- -- on the screen. If a time appears press and release the DAY/DST button until the --:-- -- appears. Repeat this step thru Program 7 off.
Press the MODE button. (AUTO) will appear on top center of screen.
If you cannot program, try to reset the whole timer:
Press the RESET and the NEXT ON/OFF buttons at the same time. Release the buttons and wait for 1200 to start blinking.
Nov 07, 2010 | Intermatic & Self-Adjusting Wall Switch...
You need to go into lines/trunks and change the line typ from unsupervised to supervised so this will stop. How though?
Changing programming on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) - display should read "lines"
4.- Press "SHOW" (top right arrow)- display should ask for a line number
5.- enter in the line number you wish to change the supervision on in a 3 digit format. ex. line 1 = 001
6.- press the show key (top right arrow)
7.- The display should say Trunk/line data
8.- Press "show"(top right arrow) - display should read "trunk type"
9.- Press the next key (bottom right arrow) 7 times"
10.- the display should say "trunk mode: unspr"
11.- Press softkey "CHANGE" to "super"
repeat steps 5 - 11 for the remainder of the lines Press the Rls key when finished
Nov 03, 2009 | NorStar M7324 Telephone
When I pick up the handset on my M7208, it goes to a dead line. How do I fix this default so it goes to a line with a dial tone
The dead line needs to be taken out of the line pool soyou can grab the right line.First you need to know the line number that you need to take out of the pool.
thats done by entering feature *0 and pressing the line button for the dead line. the screen should say
L025: line 005 (the L025 is the important part).
Write it down for later.
Next you need to get into system programming.
Programming2.gif is done on M7310, M7324 and T7316 type sets.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the next key(bottom right arrow).
the display should say LINES
the display should ask for a line number (001-004, 025-028 *thats lines 5-8) enter line that you want to take out of the pool group and press show (top right arrow)
the display should say trunk/line use
display should say line type:pool A
press the change key until it says public
press the heading button(top left arrow) til it says lines again
repeat procedure for next line/lines
press the release key when finished
it grabs the right line.
Oct 01, 2009 | NorStar M7208 Corded Phone
Norstar m7310 I would like to set more phones to ring
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
if the programming doesn't look like 1 described call me @1.410.984.4840
Mar 25, 2009 | NorStar M7310 Corded Phone
Change name on a Nortel M7324
1. Press the Rls button then ** FEATURE 266344 (CONFIG)
2. Password is 23646 (ADMIN) The display reads Terminals & Sets
3. Press SHOW ans enter the Extension for which you want to enter a name.
4. Press SHOW, again
5. Press the NEXT key until the display reads NAMES at the top left corner.
6. The bottom right corner reads CHANGE, press the far right soft key.
7. To move from one letter to the next use the far right and far left soft keys or the # key.
8. When you are finished Press next.
9. Press the HEADING key to get back to TERMINALS & SETS and start again!
Navigation Keys: Line 1 = HEADING Speed Dial = SHOW
Line 2 = BACK Last No. = NEXT
This can only be done from the main handset and only one at a time. The Soft Keys are the three small buttons right bellow the screen.
Jan 28, 2009 | NorStar M7324 Telephone
1 NEW MESSAGE SHOWING ON DISPLAY - folder empty
Hi unfortunately you are going to have to program a softkey to be a MSG key, when you have done this press the MSG key and delete the message- you can then re-program back to the original button. This video shows how to do this, go to http://www.abbeytelecom.com for more helpful videos relating to the Samsung Prostar
Dec 18, 2008 | Samsung Prostar DCS-24B-LCD Corded Phone
How too change time
Norstar Merdian Press Feature.
Enter "**8463".
Enter the password (default is 266344). The display shows
Hour: 01
Next Change
Select CHANGE. Display shows:
Hour: __
Cancel
Enter two digits for the hour. Chose AM or PM when Prompted.
Select NEXT.
The display shows:
Minutes: 00
Next Change
Enter the minutes.
Press the RLS button to end, or press NEXT to change the date.
The diplay shows:
Year: 99
Next Change
Enter the two-digit year.
Select NEXT and repeat to change the month and day.
Press the RLS key to save the time and date and exit programming.
Top of Page
Norstar Meridian CICS Time
  • Press "FEAT".
  • Press "*".
  • Press "*".
  • Press "266344" (CONFIG) or "23646" (ADMIN).
  • Enter password "23456" (ADMIN) or "72787" (SCPLUS).
  • You will see "Terminals & Sets".
  • Press "Next" five times.
  • Press "Show"
  • When you see "Hour", press "Change" or "Next" to skip.
  • Type in the hour using military time as a 2 digit number.
  • Press "Next".
  • When you see "Minutes", press "Change" or "Next" to skip.
  • Type in the minutes using a 2 digit number.
  • Press "Next".
Date:
  • When you see "Year", press "Change" or "Next" to skip.
  • Type the year in 2-digit format.
  • Press "Next".
  • When you see "Month", press "Change" or "Next" to skip.
  • Type the month in 2-digit format.
  • Press "Next".
  • When you see "Day", press "Change" or "Next" to skip.
  • Type the day in 7-digit format.
  • Press "Next".
  • When you see "End of List", Press "Rls" to exit.
Top of Page
Nortel Norstar Telephone Systems Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
  1. To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
  2. Enter password (default = 266344) - display should read "Terminals & Sets"
  3. Press "NEXT" 5 times - display should read "Time and Date"
  4. Press "SHOW" - display should read "Hour:___"
  5. Press softkey "CHANGE"
  6. Enter hour - display should read "AM OK or Change"
  7. Select AM or PM
  8. Press "NEXT" - display should read "Minutes:___"
  9. Press softkey "CHANGE"
  10. Enter minutes
  11. Press "NEXT" - display should read "Year:___"
  12. Press softkey "CHANGE"
  13. Enter year
  14. Press "NEXT" - display should read "Month:___"
  15. Press softkey "CHANGE"
  16. Enter month
  17. Press "NEXT" - display should read "Day:___"
  18. Press softkey "CHANGE"
  19. Enter day
  20. Press "NEXT"
Sep 15, 2008 | NorStar T7316E Corded Phone
Nortel 1120E Logo
Top Nortel Computers & Internet Experts
Jax Planet
Jax Planet
kwiz
Level 1 Expert
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
