Question about KitchenAid Refrigerators
Kitchenaid refrigerator air damper control makes rattling noise
Makes rattling noise
HVACRH20
  • 237 Answers
SOURCE: Hot point side by side electronics not operating damper
See if you have some paperwork on how to test, etc. located in a plastic bag taped up to the underside of the fridge. Pull the front vent cover off and you should see (feel) a bag taped up there with the test paperwork in it. If you don't have it let us know and maybe I can email it to you.
Posted on Dec 26, 2006
  • 8 Answers
SOURCE: damper door
If it is like my GE,open the refrigerator side and on the upper most left corner, there is a guard that has 2 screw securing it to frame. Remove the two screws and there is a damper which opens and closes.(it is activated by a small electric motor) Hope this helps.
Posted on Nov 20, 2008
SOURCE: Amana Mod # ABB2223DEB Refrigerator
I found this problem addressed on applianceblog.com and per they recomended part # 67006166. My repairman ordered this part and it had been superseeded by an even newer version, # 10127429. He installed that newest version in late June 2008 and it has been great ever since. So for me # 10127429 was the answer. Hope this helps
Posted on Dec 03, 2008
cj2176
  • 520 Answers
SOURCE: Fan is making noise
Think i can help. All refrigerators have the same basic components. The fan housing is fairly easy to access. slide tie ref. out enough to lie down behind it. There will be a cover plate on the bottom rear. Remove all the screws that secure it to the back and slide it out. This allows access to the compressor and fan assy. You should unplug at this time. The fan blade is made of a thin medal so it will bend easily. Visually inspect it for damage. if it is damaged it can be straightened but if it is to bad it will need to be replaced. Most likely problem is that the surrounding covers have shifted. this is an easy fix. simply give the shield a light push to readjust is until it doesn't hit blade. hope this helps and good luck.
Posted on May 07, 2009
  • 28 Answers
SOURCE: New Kitchenaid refrigerator often makes sharp bang noise.
I have an old Amana bottom freezer that does that. It's because the defrost heaters are doing their job and the area around them as well as the coil is expanding rapidly. Try making certain that the cabinet is level and not on an unsteady footing. You might want to try turning the T stat in the freezer to a lower setting. Usually between 2 1/2 and 3 1/2 works best in all freezers. If none of this helps and the banging continues, get used to it or get another fridge. It seems to be a failing in bottom freezer models for some reason. It's harmless but annoying. I actually know someone who says she has the ghost of a frozen turkey stuck in her freezer that's trying to get out! LOL!
Posted on Jul 09, 2009
Model KBF A25ERSS01 - S/N ECT2510800
I am not familiar with this refrigerator, but what you describe can happen if the refrigerator uses a motorized damper to control the refrigerator temp by varying amount of air from the freezer that circulates in the refrigerator compartment. If the damper door is stuck in the open position or broken, the refrigerator temp will not be controlled and freezing can occur in the refrigerator compartment.
Apr 01, 2014 | KitchenAid Refrigerators
KitchenAid noisy damper
There are no serviceable parts on the damper. The new damper is cheap to replace and here is the part to order.
Feb 14, 2013 | KitchenAid KFCP22EXMP 22 french door...
The fridge is not functioning: not cold. Everything is melting. It is making a rattling sound.
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Apr 22, 2011 | KitchenAid Superba Architect KSCS25INSS...
Kenmore top freezer making noise like it is powering down and then coming up again for about a half hour now.
Check freezer and make sure it is not frezing up and if not problem then pretty sure it is the fan motor. Some of these have a modual control that opens a damper control that controls the air flow. This damper controls the amount of air to the ref. coming from the freezer. Hope this helps
Nov 25, 2010 | Refrigerators
Kitchenaid refrigerator, freezer working but not bottom part
checck your evaporator fan motor make sure it is operating or running it is inside freezer behing back panel....all the cold air comes from the freezer it is produced by that fan and distrubuted through a damper or chamber into the refer.. hope this helps let me know
Feb 26, 2010 | KitchenAid Refrigerators
Th refrigerator part is not cooling ?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 20, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Warm Fridge No Airflow...Control Panel Beeping
i just had the same call today i ordered the damper control because it seems at times more air comes in and than at time like 30 seconds later nothing and the fan is working its not mine fridge but what you can do take the freezer side upper shells off the ice maker on(not necessery but i thought it was easier) and take off the little cover which is covering the damper it has two screws and look inside of the opening and you'll see a damper, turn up the fridge and see if the damper moves and you can turn down the fridge and see if the damper is moving if not you need a damper! good luck
May 20, 2009 | KitchenAid KSSC42FMS Side by Side...
New refridgerator delivered this morning to replace the same model that was a lemon. The fridge is making a sound on the fridge side. When I open the door to the freezer side the sound stops. When I...
sounds as if there is an issue with the evaporater fan motor, perhaps the fan blade has come dislodged and is makinf noises, normal for the fan to stop when the frig door opened as welll,
Dec 17, 2008 | Refrigerators
Try damper part number W10167268 from Whirlpool. They re-engineered the part, it's works different. Whirlpool issued a bulletin to servicers, but won't cover it under warranty (I have tried for many customers) "A bulletin is NOT a recall"
Jun 03, 2008 | Refrigerators
Refrigerators Logo
162 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
