Pitsos 4305
I ve ask before for this and I'd like to say some more details..the remaining water at the end of the programs,almost covers the plastic hat of the filter.I ve already check the filter but its clean.I 'm not a professional so it would help me a parts diagram or photos of this model if someone has something simular or what possibly i must check with details and the way.Thank you all very much!!
  • 1462 Answers
SOURCE: AEG Lavamat w850 not finishing cycle! help!
check no kink in drain hose and if plumbed in unbder sink, check spigot into sink drain is not blocked. put drain hose lower down band check there is water coming out freely. if not, then suspect something trapped in hose from tub to pump
Posted on Mar 26, 2007
  • 1294 Answers
SOURCE: washing machine will not drain
You shd check out your pump, refer
to manual. There shd be some block there.
Posted on May 09, 2008
SOURCE: Wate rleak Miele premier 300
I have exactly the same problem with my new Miele washer dryer - and my kitchen is soaking wet. Have you found a solution ?
Posted on Aug 10, 2008
  • 57 Answers
SOURCE: The washer got stuck half way before program is finished
your drain pump isnt working or there is a blockage in the sump, drain hose or plumbing
Posted on Mar 30, 2010
  • 174 Answers
SOURCE: my combined washer-dryer Zanussi machine does not work
check the carbon brushes in the motor first
Posted on Jul 20, 2010
Testimonial: "Thank you for the quick and helpful answer!. Regards Sacra"
ADP 4305. Where can I obtain a service manual?
Thanks for the detailed description of the symptoms that we should make it easier fault detection.
I conclude that there is a mistake F1 (1 x flash,1s pause,1 x flash).
Before anything, erase the failures by pushing the START button for longer than 1.5 second.
F1 - NTC break
Temperature out of the normal value (-3°C till +85°C)Temperature inside higher than +85°CNTC defectiveDishwasher is frozen, less than -3°C If temperature is less than -3°C, fill the appliance with a cup of warm water to warm it up before you start it. The failures F1 (NTC break) and F9 (continuous water inlet) are checked and indicated immediately after start program. Because that, too small quantity water is taked.
First, I suggest to measure the resistance of the NTC, which must be about 58,1 kOhm at temperature 20°C. Also, check wiring between NTC and board.
Oct 09, 2015 | Whirlpool Dishwashers
nothing fixya site can do for you
this is between you and the bus company
Mar 19, 2017 | Cell Phones
Water leaking underneath pitsos dishwasher when in use
It is so common that the drain leaks in many ways and is the most problematic fault in a dish washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
to replace door seal : click on door seal
Jan 12, 2013 | Dishwashers
Will not end programs
Pressure switch telling the controller there's still water in the machine. Remove tube from switch and blow down to unblock it.
May 09, 2012 | Washing Machines
Programming my TiVo remote to control my Proview TV
  1. Cover the end of the TiVo remote control with your hand.
  2. Hold down the TiVo and TV POWER buttons simultaneously until the red light on the remote control remains on.
  3. Remove your hand from the end of the TiVo remote control.
  4. Enter code 0999.
After you enter the code, the red light will flash three times and then remain on.
  1. Press CHANNEL UP once every two seconds. This will test hundreds of codes, one by one.
IMPORTANT: Do not go any faster than this or you may skip over a code that works.
  1. If you press CHANNEL UP and your TV turns off, press ENTER to select the code. Press the TV POWER button to test the code. If your TV turns on, you have successfully programmed the remote
Jun 11, 2009 | Tivo Series 2 Remote Control
Water won't pump out at end of cycle
there could be a block in the outlet pipe
and please rate us
Nov 28, 2008 | Kenmore 24 in. 17039 Built-in Dishwasher
Washing Machines Logo
Top Washing Machines Experts
