Question about Progressive Suspension Fork Lowering Kit For Yamaha Xv1000 1984-1985 / Xv1100 1986-1999 / Xv700 1984-1987 / Xv750 1988-1997 - Pair - Fork Springs - Black - 10-1552
XV1000 1985 starts smoothly, but periodically runs on 1 cylinder. Tried changing coils, same problem. RPM meter drops to zero when problem is active. How can I test Ignition box??
I have had some problems with carburators being difficelt to adjust, but a trip in ultrasound fixed that (I hope), but now it only runs on one cylinder in periods, and when it does, RPM gauge drops to zero.
Engine keeps backfiring under load motor is an enduro xl 13.5 hp
Need Make/Model/Year/Engine Model/Deck Size, and hours on meter if you have one. A short description of the events preceding the beginning of the problem is also helpful.
Several possibilities:
1. Needs a valve adjustment or a valve job. Start with adjustment.
2. Needs new plugs. Start with new plugs.
3. Shear pin under flywheel is slightly damaged throwing off the timing. Remove flywheel examine shear pin for any damage. Just go ahead and replace it; if it even looks nicked or sliced.
4. Coil, or spark plug wire, is going bad. Very hard to test a coil for weakness without test equipment that the average person doesn't have. Check the first 3 problems, first. If it still backfires, then replace coil.
5. The other thing that causes backfire is fuel mixture too lean. On a small engine this is not usually an adjustment problem. It may be the fuel system/carburetor is dirty or partially clogged. It may also be an air leak in the gaskets of the intake manifold. If nothing else solves the backfire, remove the carburetor and clean or rebuild it. This is the least likely of the options so save it for last.
If compression is good and cylinder leakage is minimal, but a cylinder is misfiring or shows up weak in a power balance test, it indicates a fuel delivery or ignition problem (fouled spark plug or bad plug wire). A power balance, or cylinder balance, test should be run on a twin cylinder engine.
If an engine is hard starting, runs rough, misses or lacks power, run a cylinder balance test to determine if both cylinders are operating to their full potential. You will need an engine tachometer, a spark tester, and an insulated screwdriver.
1. Using the spark tester, with the plugs in, start engine and verify spark is equally good on both cylinders. Remove spark tester.
2. Connect engine tachometer.
3. Run engine at top no load speed. Note rpm.
4. Ground one cylinder spark plug with screwdriver. Note rpm.
5. Ground other cylinder with screwdriver. Note rpm.
The difference in RPM between the cylinders should be less than 75 rpm. If the difference between the two cylinders is greater than 75 rpm, the cylinder with the least rpm loss is the weakest and is a potential problem.
Note: If the spark plugs are new this could be an indication of a weak coil. Of course it could also be compression (rings), or valves.
Mar 24, 2015 | Garden
Reasons for cylinder misfires
Ford coil on plug systems are multi strike ignition (spark) under 1300 rpm then go to single strike a single cylinder misfire can be created by several things . #1 Test engine compression on a cranking engine compression it should be around 150 lbs but if gauge reads different COMPARE to other cylinders that work fine #2 check engine running compression this will be around 120 lbs then rev over 2000 rpm and check pressure drop again COMPARE to other cylinders that work fine. any drop would indicate valve train problems. #3 All internal engine is fine then external problems are present vacuum leaks and or fuel injection volume is low.
Jul 23, 2014 | 2003 Ford Thunderbird
I just had a motor put in and my a t temp light is flashing from the moment gee started the car ...doesnt appear to be shifting and kicks hard in first ...rmp run over 3 all the time ..changed filter and...
new subaru enigne. NO YEAR stated !!!!!!
the cold start RPM is wrong.
its NOT THE ENGINE. !!!
the engine controls are out of control.
vacuum air leaks are the reason.
or stuck open ISC /iAC air valve .
or throttle cable set too tight,
of the many. i can find it in 5min flat hands on.
but telling how to find air leaks is a 20 page doc.
you contradicted , idles find then 3000 rpm idle.
which is it.?
that tacho meter is x1000
so 3 x 1000 is 3000 RPM.. all cars
and is 2 times the legal idle.
and 3 times hot. 800 is normal hot
0.8 on the dial zero point eight. = 800
May 27, 2014 | Cars & Trucks
Engine misfireunder load
I would check the coils...In have seen some fail at under 80k miles but mostly you can get well over 100k miles... I do not know if you have a great scanner or not, but what I do is use a scanner and run a power balance test and this graphs the cylinders performance and coil output.Also you can try cranking the car and let it get to operating temp,then go to each coil and disconnect it,you should have a rpm drop,if you do not get the rpm drop then that coil is bad.Last if you can test the resistance of the coil with a multimeter...Make sure you have the car scanned with a good scanner 1st to point you in the right direction.
Apr 15, 2014 | 2008 BMW 328xi
I have a 1986 Porsche 944 turbo which was running well except for injector was leaking after intake removal to replace vacumm delay valve.put in brand New injectors and the issue started. Porsche starts...
You have a large intake leak, un metered air leaking after your maf. Grab a can of intake cleaner, start your cAr and start spraying your intake and any vacuum lines. Any change in idle activity is where I would double check
Oct 22, 2013 | Cars & Trucks
My x type 3.0 has fault readingP1647 could you tell me what this means please
OBDII DTC
P1001 Key on engine running unable to complete; key on engine running aborted
P1100 Mass air flow sensor intermittent
P1101 Mass air flow sensor out of self test range
P1104 Mass Airflow (MAF) Sensor Ground Circuit Malfunction
P1107 Left MAP Sensor Circuit
P1108 Right MAP Sensor Circuit
P1112 IATS Circuit High Voltage
P1113 IATS Circuit Low Voltage
P1121 Pedal Position Sensor Circuit A Range/Performance
P1122 Pedal Position Sensor Circuit A Low Voltage
P1123 Pedal Position Sensor Circuit A High Voltage
P1137 No Rear HO2S Response
P1138 No Rear HO3S Response
P1157 No Rear HO2S Response
P1158 No Rear HO3S Response
P1171 All Cylinders Too Lean
P1172 All Cylinders Too Rich
P1176 Adaptive Fuel Metering Trim Too Lean
P1177 Adaptive Fuel Metering Trim Too Rich
P1178 Adaptive Fuel Metering Trim Too Lean
P1179 Adaptive Fuel Metering Trim Too Rich
P1187 Both Front HO2S Heater Circuits (High Resistance)
P1188 Both Front HO2S Heater Circuits (Open Short to Ground High Resistance)
P1190 Both Front HO2S Heater Circuits (High Battery Voltage Short to Voltage)
P1193 Both Front HO2S Heater Circuits (High Resistance MAF Sensor Fault)
P1194 Both Front HO2S Heater Circuits (Open Short to Ground High Resistance)
P1196 Both Front HO2S Heater Circuits (High Battery Voltage Short to Ground)
P1198 Fuel Level Sensor (High Voltage)
P1199 Fuel Level Sensor (Low Voltage)
P1201 No. 1 Fuel Injector
P1202 No. 2 Fuel Injector
P1203 No. 3 Fuel Injector
P1204 No. 4 Fuel Injector
P1205 No. 5 Fuel Injector
P1206 No. 6 Fuel Injector
P1221 Pedal Position Sensor Circuit B Range/Performance
P1222 Pedal Position Sensor Circuit B Low Voltage
P1223 Pedal Position Sensor Circuit B High Voltage
P1224 Electronic Throttle Control Position Error
P1226 Mechanical Guard Circuit Range Performance
P1227 Mechanical Guard Circuit Low Input
P1228 Mechanical Guard Circuit High Input
P1229 Throttle Control Circuit Malfunction
P1230 Fuel Pump Relay Malfunction
P1235 VSV 1 Circuit Range/Performance
P1236 VSV 1 Vacuum Circuit Failure
P1237 VSV 2 Atmosphere Circuit Failure
P1238 VSV 3 Release Circuit Failure
P1240 Throttle Position Sensor Voltage Malfunction//Sensor Reference Voltage Low (Throttle
Fuel Tank Pressure)
P1241 Throttle Position Sensor Voltage Low Input//Reference Voltage Low (Throttle Fuel
Tank Pressure)
P1242 Throttle Position Sensor Voltage High Input
P1243 Throttle Position Sensor Ground Malfunction
P1245 Crank Signal Low Input
P1246 Crank Signal High Input
P1313 Misfire Catalyst Damage Bank No. 1
P1314 Misfire Catalyst Damage Bank No. 2
P1315 Misfire Excess Emissions
P1316 Misfire Rate Above Limit
P1335 Crankshaft Position Sensor Circuit
P1336 Camshaft Position Sensor (CMP) Circuit Performance
P1361 Ignition Coil Primary Circuit (Cylinder No. 1)
P1362 Ignition Coil Primary Circuit (Cylinder No. 2)
P1363 Ignition Coil Primary Circuit (Cylinder No. 3)
P1364 Ignition Coil Primary Circuit (Cylinder No. 4)
P1365 Ignition Coil Primary Circuit (Cylinder No. 5)
P1366 Ignition Coil Primary Circuit (Cylinder No. 6)
P1367 Ignition Monitor (Bank A)//Ignition System Failure Group 1
P1368 Ignition Monitor (Bank B)//Ignition System Failure Group 2
P1371 Early Activation Ignition Coil (Cylinder No. 1)
P1372 Early Activation Ignition Coil (Cylinder No. 2)
P1373 Early Activation Ignition Coil (Cylinder No. 3)
P1374 Early Activation Ignition Coil (Cylinder No. 4)
P1375 Early Activation Ignition Coil (Cylinder No. 5)
P1376 Early Activation Ignition Coil (Cylinder No. 6)
P1392 Variable Valve Timing Solenoid A Low Input
P1393 Variable Valve Timing Solenoid A High Input
P1396 Variable Valve Timing Solenoid B Malfunction
P1397 Variable Valve Timing Solenoid B Low Input
P1398 Variable Valve Timing Solenoid B High Input
P1400 EGR Valve Position Circuit (Valve Sticking Open or Short)
P1401 EGR Valve Position Circuit (Open Short to Ground)
P1408 EGR Temperature Sensor Circuit
P1409 EGR Valve Circuit
P1440 EVAP Purge Valve Open
P1441 EVAP Valve Circuit
P1443 EVAP Valve Circuit
P1447 EVAP Valve Circuit
P1448 EVAP Valve Circuit
P1454 EVAP System
P1474 Charge Air Coolant Pump Relay
P1475 Radiator Fans Slow Malfunction
P1476 Radiator Fans Fast Parallel Circuit Malfunction
P1506 Idle Speed Control Circuit (Low RPM; Bank B)
P1507 Idle Speed Control Circuit (High RPM; Bank B)
P1508 Idle Speed Control Circuit
P1509 Idle Speed Control Circuit
P1512 Throttle Position Sensor Idle Switch Sense Circuit
P1513 Throttle Position Sensor Idle Switch Sense Circuit
P1514 Park/Neutral Position Switch High Load Neutral/Drive
P1516 Gear Change Park/Neutral Malfunction
P1517 Engine Cranking Park/Neutral Malfunction
P1607 MIL Output Circuit
P1608 Automatic Transmission
P1609 Internal ECM Error
P1641 Fuel Pump Relay No. 1
P1646 Fuel Pump Relay No. 2
P1739 Automatic Transmission
P1775 Transmission Control Module MIL Circuit
P1776 Torque Reduction Request Signal
P1777 Torque Reduction Circuit
P1780 Automatic Transmission
P1781 Automatic Transmission
P1782 Automatic Transmission
P1783 Automatic Transmission
P1785 Automatic Transmission
P1790 Automatic Transmission
P1791 Automatic Transmission
P1792 Automatic Transmission
P1794 Automatic Transmission
Mar 22, 2013 | Jaguar Cars & Trucks
Check engine light turned on. autozone run diagnostic check come up with engine 4 misfire. engine start ok but for a while rpm drops and engine stop. i have changed fuel filter and check fuel injectors...
Is there a coil per cylinder? That's sounds like a faulty coil, that can cause a misfire in a cylinder. It's relatively easy to test. Start your engine and when the car rpm's drop, remove the coil socket from cylinder number one and if the car hesitates more that means that cylinder is working good, then reconnect and continue with cylinder number two, remove the coil socket and look very careful for hesitation and reconnect and so long until you check all off the cylinders. If you disconnect a coil of any cylinder and the engine remains the same, doesn't hesitate more, then that cylinder isn't working, so change that coil. Begin with cylinder number 4 if you want to cause of the scanner reference.
Jun 28, 2011 | 1999 Isuzu Trooper
Ihave a 2003 Nissan Altima 2.5s. Im trying to figure out how to determine which coil is burned up so i can replace it. any help would be greatly appreciated
To find the fault coil as the engine is running disconnect one coil at a time. With the engine running and you disconnect a coil and the engine and the there is a sudden change that coil is good and it does contibute, no to find a bad one if you disconnect the the coil and nothing changes you got a bad one, bad ones dont contibute
Apr 25, 2011 | Nissan Altima Cars & Trucks
Oil pressure drops to zero after warmed up or below 2700 RPM
Check the oil pressure with a test guage, if the finding are the same, the look at your oil filter, pump, pickup, or pressure relief valve.....
Jul 18, 2009 | 2002 Isuzu Rodeo
Toyota Corolla 98 Cylinder #1 and #4 misfire
It is likely a coil. Cylinder number 1 and 4 are both on the same coil.
Mar 01, 2009 | 1999 Toyota Camry
Progressive Suspension Fork Lowering Kit For Yamaha Xv1000 1984-1985 / Xv1100 1986-1999 / Xv700 1984-1987 / Xv750 1988-1997 - Pair - Fork Springs - Black - 10-1552 Logo
32 people viewed this question
Top Progressive Cycling Experts
John Egan
John Egan
Are you a Progressive Cycling Expert? Answer questions, earn points and help others
