My problem with this is that when the PSP Mykrvmks cable connection to the computer, I can not establish communication with the computer and the computer system will not...
    Master:
  • 680 Answers
Contact support of yout service provider They can helo you to get connected.
Terry
Posted on Apr 06, 2014
Ce code
CE
Communication error
If communication between the ignition board and the display board is not established within 3 s of power-up an error will be displayed. After communication is established, if it is lost for 30 s, the error will be displayed. The error code will be cleared upon a valid data exchange between boards
All you can do is remove the panel and make sure that the connection between the two boards is good and dry. Other than that, you will be changing cable from the lower board or the lower board itself.
Jul 02, 2014 | Hayward H Series
RCA DCM425 modem ethernet connection won't work
The setting for the Computer 1, use the network connection wizard to automatically configure the modem to work as a server station. Next, set the IP number manually and the DNS at automatic or is given by your ISP. Now the Computer 2 (workstation) should be connected to a Hub/Switch. The same, go to network connection wizard and select the appropriate connection setting, there are view samples for the connection types so explore them. After the setup, try loading your internet browser.... When done, it should work fine. Keep me posted for any problems.
Nov 26, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
How to use cwa-854 other than bridge mode?I would like to have an internet access point obtained with user name and pasword where i can conetct more than one comp (ip obtained automatically)?
Two aspects have to be considered to establish a network with brideable functions
1. The computer infrustrure have to be built, for example the computers have to be connected to each other by physcal cables to achieve the first steps the the second steps requiring wireless functionality.
2.The wireless devices like modems transfer signals between the two device to communicate otherwise would have communicated by wire connectivty of cables. The wireless device creates a bridge between the two devices also called an access point located on the computer networking area ( open my computer, click system settings and select networking functionality for any alteration purposes)
3.Once each device in the connection is ready functioning, the access point becomes visible message that could be manipulted by the computer administrator.
4. Clicking on the system networking settings will allow customisable features explanable
a. The network area would have the option of creating passwords to every device for reasons of that each device on the network is a separate entity only possible to achieve connectivey by another device providing wireless capability.
b. manipulate the wireless features that would only be displayed after each gadget on the infrastructure has been phically connected with wires amongs one another and to power supply in which instance to be powered on.
c. the modem once powered on should recognise an available computer physical establishment because wireless chips are embeded in every entity of the setup.
d. The computer display of message about wireless signal recognistion is then manipulated to suit the administrators specifications explanable.
1. A user name and password are established for reasons of contolling access to the connection of several devices
2. The device could function without passwords and username only becomes available to every demander making possible connectivty so several untilities and infructure.
Important notes
1. Your computer set up of networks are a network that when capable of communicating elswhere with additional networks insfrustures together is an internet.
2. Rememer to setup your newkwork properly or esle access could not be made into another network and vise versa.
3. If you set up any passwords and user names in the process of establishing a network,, other persons requiring connectivety woudld requrre what is called Codes in computer temnology to acess the network. whenever the passwors are lost would compromise your acess to the link of wireless signals as well.
Dec 02, 2010 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
My psp won't connect to the internet. it says, a commection error has occured. a connection to the access point could not be established. check the security settings for the network and try again.
First of all check if your wireless router requires (WEP KEY) to establish a connection then you will have to put same (WEP KEY) in PSP WLAN security setting and if your wireless router is set without (WEP KEY) then in PSP WLAN security setting it should be set to None. kindly refer to the following image.3782ff8.png
Oct 20, 2010 | Sony PlayStation Portable (PSP) Console
Sc 144 en ricoh mf1515
Communication Error between BICU and SBU
Symptom:
The BICU cannot correctly establish
communication with the SBU.
Possible Cause:
• Loose connection of the flat cable
between the BICU and the SBU
• Defective flat cable between the BICU
and the SBU
• Defective BICU
• Defective SBU
Sep 03, 2010 | Ricoh Aficio MP1600SPF Copier
Accidentally disconnected TI Connectivity cable during transfer
you are going to have to completly start over reinstall your drivers
Mar 09, 2010 | Texas Instruments TI-84 Plus Calculator
TI-83 Calculator RAM cleared
To clear the message press [CLEAR]
If calculator shows message after you turn it [ON], it may be due to drained backup battery. If you have to change it make sure you have main batteries in and in good state, and installed.
If calculator appears frozen, press [2nd] [QUIT] to interrupt what it is doing.
I see you do not have the latest ROM (OS). You should download the latest ROM (1.19) and install it.
Use the education.ti.com link to download the TIConnect software. Install it on your computer. Run the TIConnect software. Connect the calculator to a computer (USB cable or TISilverLink cable or TI Graphlink black cable). Press the ON button, do not worry if you do not see anything on screen (contrast may be too light).
In TIConnect main window, click the TI Device info button. The software will try to detect the calculator. If the answer is NOT FOUND on any of the ports, click the communication settings at the bottom of the window.
Select Device: enter you calculator model
Select Cable: SilverLink, USB,
Select port : USB1 or COMx
and click OK. The TI connect software will give you some messages if communications with calculator cannot be established.
If you establish communications with the calculator, press the Update button in TIConnect main window. Install OS directly to the calculator. You may update other installed applications.
If you cannot communicate with calculator with the computer try to update by cal-to-calc connection with a working calculator/
Hope it helps.
Sep 27, 2009 | Texas Instruments TI-83 Plus Calculator
DNS Error using my PSP Internet Connection!!!!
i can assist you with this.
Instructions
1 Take out the UMD disc from the back of the PSP if one is inserted. 2 Take out your memory card from the memory card reader if one is inserted. 3 Turn on your PSP. 4 Go to the "Settings" tab in the Cross Media Bar and select "System Settings." 5 Select "Restore Default Settings" and confirm that you wish to restore all settings to the factory defaults. 6 Restart your PSP. 7 Try connecting to the Internet again. If you still get the 80410A0b error, try connecting to another network. If you successfully establish a connection to another network, your router is at fault. If you cannot connect to the second network, your PSP's Wi-Fi card could be damaged and may need repairs. Tips & Warnings
Ensure that you are entering the Wi-Fi SSID and password correctly on the PSP. You can contact PlayStation Support (see Resources) to start a repair order if you PSP's Wi-Fi card is faulty. if you require further assistance please let me know and i will be glad to assist you. Thanks
Jan 05, 2009 | Sony PSP (Piano Black)
Unable to establish two-way communication error
What kind of cable is being used to communicate?
Nov 24, 2008 | Lexmark X2500 All-In-One Printer
Share printer
First you have to set up a home network between both your computers, once that is established run an networking cable to your printer it should all be ran through a networking hub so all machines can communicate with one another
Jul 05, 2008 | Brother MultiFunction Center MFC-440CN...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
