Question about Refrigerators
Lrtn18320ww looking for a replacement handle for this refrigerator. the part is discontinued, is there another handle that will fit
  • 50 Answers
I would check ebay or equal site. You never know what you can find. Awhile back I found a part for a 35 year old sewing machine.
Posted on Apr 01, 2014
Need replacement handle model MVH330E part # R0713641. Discontinued. New or old don't care just need one from somewhere. Thanks
I had a similar issue with another make and model. The mounting boss had broken on one end of the handle. After I took the inside trim of the door off I found that the handle had a second hole that I could screw into. I did buy a replacement that I didn't use and it might fit yours. If you could attach a picture of your old handle and the exact dimensions, the one I have might work.
Nov 13, 2017 | Microwave Ovens
Looking for tilt handle for kenwood r1000 shortwave radio? regards
  • Hi, I can help.
  • Discontinued part # N08-0601-05 SCREW,HANDLE R-1000 . At the link it will be #18 down the list. Kenwoods contact information is at the top of that page as well.
  • If you have any comments please feel free to leave them here and i will respond to you.
  • Hope this helps and thank you for using FixYa,
Regards, Tony
Sep 19, 2011 | Batteries.com 2-Way Radio Battery for...
I have a new door to replace the right side one on this refrigerator but for the life of me I can't get the door handle off the old one. New one didn't come w/ the handles/hinges, etc, obviously. The...
Are you sure...
To move refrigerator through a house door, it may be necessary to remove the refrigerator door handles.
NOTE: Handle appearance may vary from illustrations on this page.
1. Removing Refrigerator Handle
• Grasp the handle tightly with both hands and slide the handle up (1)(this may require some force).
• The keyhole slots (2) on the back of the handle allow the handle to separate from the mounting screws (3).
CAUTION: The handle could be damaged if you hit it with a hammer while removing or attaching.
CAUTION: When you assemble or disassemble handle, you must push or pull with reasonable force.
Jan 21, 2011 | Refrigerators
Hi there, sir can you please tell me if you have service manual for LRTN18320WW. I'm dealing with problem where my fridge/freezer both not cooling down. Can you please help me out? Thanks jassy
http://appliancedigest.com/index.php?/files/file/519-16025860-maytag-amana-18-21-cubic-foot-top-mount-refrigerator-service-manual/
Nov 13, 2010 | Refrigerators
My LG Model LRTN18320WW is leaking water inside frig. on bottom below produce drawer. has occurred since summer. what is solution?
Drain in freezer compartment is plugged.
Mold (fungus) buildup sometimes restricts water flowing into condensate tube in the defrost cycle, and water somehow can enter in the refrigerator compartment and out the bottom of the refrigerator door.
You must clean the condensate tube!
You must remove back cover in freezer. One screw in left upper corner behind plastic screw plug will allow you to remove the cover exposing evapourator coil and condensate drain tube hole below it. Must also remove back cover at rear of refrigerator exposing the condensate drain tube END which may be restricted also.Tube must be totally cleared to allow the water created from defrost cycle to exit to the drain pan in the bottom of the refrigerator.
Oct 05, 2010 | LG LRTP1231W Top Freezer Refrigerator
Door handle is loose
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
Feb 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator door handle is loose
If allen screws are there then that is what holds handle in place. There are screws that the handle fits over, so remove handle and tighten as needed. Allen screws are very tiny.
Nov 27, 2008 | LG Refrigerators
Cold Control
Find another spot to mount it or turn it wide open and tape it off.
Sep 16, 2008 | U-Line 15R Compact Refrigerator
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
