Question about Hayward Pool & Spa
Is there a remote thermostat control for the hayward comfortzone? if so where can i get one of these?
Hayward comfortzone
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Hayward Master
  • 1,448 Answers
Its on the main board if using a system 3 wire use pool spa and common see which wires go to which on sytem board put pool temp at desired temp then same with spa temp if jandy system go to pins 1 and 2 on long plug on top of board then go to pool and com at heater if jandy turn heater all the way up RS sysyem will govern heat
Posted on Jun 10, 2014
2 Suggested Answers
  • 139 Answers
SOURCE: Hayward Comfortzone pool heater pilot will stay
check for continuity at all control and safety components,i.e. press switch,high limits,thermostat,on/off switch and flame roll out switch
Posted on Jun 21, 2009
Comfort zone infrared heater keeps flashing A05 what does this mean?
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Jan 30, 2016 | RTO Comfort Zone Electric Portable Space...
Need manual for operational issues
Shaw Direct - Troubleshooting Remote Controls, Codes ...
www.shawdirect.ca/english/customercare/.../remote/RemoteC...
Shaw DirectTroubleshoot all your remote control issues with Shaw Direct satellite TV systems. ...Get familiar with the remote and its operation by reading our guide to remotes. ... Make sure you have a clear path between the remote and the infrared eye on your equipment.... Try re-programming the remote to talk to your receiver.
[PDF]Wireless Handheld Remote Control - Hayward
https://www.hayward-pool.com/.../manuals/AquaPodOperationsManual.p...
Base Station required: The AquaPod 2.0 requires that the pool control have a base ... Refer to the "Operating Status" section of this manual for an explanation of ...problems. Operation. The AquaPod 2.0 remote control offers users the power to
Jan 24, 2016 | Televison & Video
How do i test my heating elememt
If the model information that you provided is correct, you need to remove the power from it, take the cover off and use a meter to test the coils. They should not read infinity when you test them with an ohm meter.
Jun 30, 2014 | Hayward COMFORTZONE ELEMENT 6000 WATT 240...
Hayward electric comfortzone heater won't heat
check pressure switch if ok check safety circuit if ok check ignitor
Jun 30, 2014 | Hayward H Series Induced Draft Abg 100,000...
Hayward Heater H series 400 BTU will not start
This is a normal display when heater is being controlled by a remote thermostat. No service is required. If heater is not being controlled by remote thermostat, change setting by using the MODE key to put the heater into STANDBY. Press and hold the DOWN key and then press and hold the MODE key. HOLD down both keys for 3 seconds until the indication "bo" is removed from the display.
The key to this is DOWN first and then together with MODE, both for 3 seconds.
Make sure the display is not showing "BD".
Jul 06, 2017 | Hayward H Series Pool & Spa Heater 400k...
A friend gave me a Hayward Comfortzone pool heater several years ago, I have not used it yet but might, wondering how I could get a manual for installation and hook up etc.
Hayward no longer offer parts or any other support for the old Comfortzone heaters but you can follow the general guidlines from any of the Hayward heaters as far as gas line sizing, spacing requirements and piping. This one on the H-Series should work...
https://www.hayward-pool.com/pdf/manuals/Manual285.pdf
John
May 15, 2011 | Hayward Pool & Spa
Heater wont stay on. HELP!
Have the Hayward guys come out and prove to you that it is indeed low pressure and then get an estimate for repair costs. Assuming there is no warranty in effect, you might want to locate the heater manufacturer for guidance. They may have a website that may be of help.
Mar 20, 2017 | Hayward Comfort Zone Electric Spa Heater...
Hayward H400 error code bo
This error means "Bypass Operation". On the back of the control module there are some "dip switches". They have an on or off position. Check switch number 2. Make sure it is in the "off" position. The "on" position is for a remote thermostat.
Jun 27, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward Comfortzone pool heater pilot will stay lit but main burner will not fire. If the TH terminals are jumpered it will, but it won't stay on.
Have you tried jumping the pressure switch, as well as the on/off switch. sounds like something in the safety circuit is open
Jun 10, 2009 | Hayward Comfort Zone Electric Spa Heater...
Pool & Spa Logo
75 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
