Question about HP RM1-5465-000 Laser/Scanner Assembly for Laserjet P4014/P401
High pitch noise when feeding thru the mp tray
High pitch noise when feeding form tray 1
4 Suggested Answers
SOURCE: high pitch noise
Try backing off on the screws that hold the fuser in place.Start with
the bottom right.
Posted on May 20, 2008
jonb3838
  • 237 Answers
SOURCE: paper not pulling thru in tray 2 creating a jam message
IF its pulling multiple pages its a seperation pad if its not pulling at all its the pick up rollers.
Posted on Mar 26, 2009
frcs68
  • 1605 Answers
SOURCE: HP 1700cp - Can only print with Rear Manual Feed and Not Tray 1
does the printer pickup the paper from tray 1?
if not check the roller, it may time for replacement.
2- make sure the computer program is set at autofeed as default.
or tray 1 as default.
Posted on May 22, 2009
Is there a specific type of oil used for the rollers
open Tray 1. Remove the paper feed roller. Remove the separation pad under the feed roller. You will see a small spring. Try to cut JUST ONE ring of this spring.
Aug 07, 2014 | Ricoh Aficio Mp 171 Copier
Feed from tray problem
it will always try to pull from the MP tray if it has a media size or type mismatch even if you default to tray 1. Check your media size and settings
Aug 10, 2013 | Kyocera Office Equipment & Supplies
High Pitched ear ringing sound coming thru somewhere up front by navigator system
Some things I would check are do you have blue tooth in operation. Do you have any form of michrophone in the cab as it sounds like a feed back problem coming through your speakers. Talk to a radio techie to see what he thinks
Feb 23, 2013 | 2008 Jeep Grand Cherokee
Manual feed isnt working. once tray 1 is open i thought it would automatically know i want to use manual feed.
Not necesarily so, it depends on how you have the printer configured. To test the MP tray, use the arrow keys to get to troubleshooting menu, press check, use arrow keys to get to paper path test, press check, set tray option to tray 1, then print test page. Printer should feed from MP tray. If it does, then the problem is that you do not have the printer set to print from MP tray first or you have the tray options set to exclusive which means that if your print job asks for tray 2 then printer will not print from MP tray unless you specify MP tray in the print options.
Mar 18, 2011 | HP LaserJet P4015 Printer
I have a Brother HL-5250DN printer and trying to replace the Paper Feed pickup roller assembly. Can you tell me how to take the old part out or send a diagram? Thanks, Sherry
Paper feeding kit for MP tray
(1) Disconnect the AC cord from the Printer.
(2) Press the front cover release button.
(3) Open the Front cover.
(4) Remove the Drum/toner ASSY.
Open the MP feed frame cover. (6) Remove the Holder bearing MP. Lift up the Lift arm MP to release it from the Pin of the MP roller holder ASSY. (8) Slide the MP roller holder ASSY to the direction of the arrow 8a and put it up to remove. Fig. 3-77 (9) Turn the back side of the Separation pad ASSY MP to the direction of the arrow 9a and put it up to remove. Fig. 3-78 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame Lift arm MP 7 8a 8b MP feed frame MP frame 9b 9a
(1) Put the Hook of the Separation pad ASSY MP into the MP feed frame and pull down the Separation pad ASSY MP to the direction of the arrow 1b until it is locked. Fig. 3-79 (2) Lift up the Lift arm MP and put the MP roller holder ASSY into the MP feed frame. Put the Pin of the MP roller holder ASSY into the hole of the Lift arm MP. Fig. 3-80 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame MP frame MP feed frame Lift arm MP
(3) Put the Holder bearing MP into the MP feed frame and turn the Holder bearing MP to the direction of the arrow 3c to lock. (4) Close the MP feed frame cover. Holder bearing MP Hook MP feed frame cover Front cover MP feed frame 3a 3b 3c MP feed frame(5) Install the Drum/toner ASSY into the Printer. (6) Close the Front cover. (7) Connect the AC cord into the Printer. Printer AC cord Drum /toner ASSY Front cover .
Mar 18, 2011 | Brother HL 5250DN Laser Printer
Printer makes a high pitched whirring sound, paper will not feed and orange light stays on
clear paper feed roller whit wet cloth or alcohol,
1. remove paper tray
2. look for paper feed roller just in bottom of printer.
3. clear it as i said early
4. Enjoy
Good luck!!!
Jan 17, 2011 | HP LaserJet 2200dn Printer
Paper is in the feed tray, but it continues to say NO Paper??? Brother MFC-8460N any suggestions?
Could be a tab or spring broken off of the feed tray, dirty feed roller can cause that error when paper doesn't feed. Paper guide too tight so that paper can't lift to the feed roller also a possibility. Sensor above paper stack out of position.. many possibilities.
Nov 06, 2009 | Brother MFC-8460N All-In-One Printer
Set up KYOCERA FS-1350DN printer
you need to scroll thru your menus...paper handling section...make sure mp tray is set to FIRST..that way it will pull from the mp tray untill it is empty than switch to your cassette
Aug 13, 2009 | Kyocera FS-C5030N Led Printer
Printer error reads 'Paper Out MP CTM'
Sounds like the document that is being sent to the printer, or the one if pending prints are present, has a page size set to other than what the printer has its set to for the tray feed (or tray feed is set wrong), so it is defaulting to the Manual Feed for insertion of correct medium CTM (not sure if int. but thats maybe a country thing we use A4, ENV and B5 mainly
Dec 01, 2008 | Epson AcuLaser C3000 Printer
HP RM1-5465-000 Laser/Scanner Assembly for Laserjet P4014/P401 Logo
27 people viewed this question
Seeker5211
Seeker5211
