Question about Husqvarna Huskystar 215 Sewing Machine
Cannot source replacement handwheel , can anyone help me source one
Source 207/215 handwheel
  • 23 Answers
Have you tried http://www.sewingpartsonline.com/handwheel-viking-4123009-01.aspx ?
Posted on Apr 01, 2014
How to sew buttons on a Singer 2273
Perhaps the manual would be helpful:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwj4msWhgtbOAhUK0mMKHW7EDBwQFggkMAE&url=http%3A%2F%2Fs3.amazonaws.com%2Fszmanuals%2F9fc370bfc46e27af5aa17d88966585c8&usg=AFQjCNHHGuX6tL_IYfqSjCX6ifUd87_Aug&cad=rja
Something I do when sewing on buttons is to stick the button to the fabric with glue stick (don't worry, it washes out). Just be very careful when setting up the stitch width to make sure the needle doesn't hit the button. Turn the handwheel by hand first to make sure it is set right. Then sew slowly & carefully with the machine. Finish off with a dab of Fray Check on the back of the stitches to lock the thread.
Aug 22, 2016 | Singer Sewing Machines
How can I disengage the bobbin winder?
Depends on the machine. An owner's manual would probably be the best source of information.
Most older machines have the disengagement on the handwheel--on the right is the handwheel but in the center there is usually a smaller wheel that, when turned counterclockwise, disengages the needlebar and activates the bobbin winder.
Jan 09, 2016 | Husqvarna Sewing Machines
I have a Bernina 707 that is hesitating to sew from time to time. I turn the handwheel and it will start running again. I cleaned and oiled not sure what else can be done. Please help??
Be sure that you are using a good quality sewing machine oil (Bernina oil for mechanicals is great). Check the manual to be sure that you have oiled every spot noted in the manual. If you need a manual, you can download one here:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0CCwQFjAE&url=https%3A%2F%2Fwww.bernina.com%2Fde%2FSupportData%2FOut-of-Print-de%2FBERNINA_707_717_manual&ei=hZuiVe7YBovhoAT0ppHADg&usg=AFQjCNHTAlgzOWgwVjNYj5JSuy1L3t9FhQ&bvm=bv.97653015,d.cGU&cad=rja
The belt could be slipping and need replacement. Sometimes the problem is in the foot control when the carbon brushes are wearing down. If you are handy, you can order them online and replace them yourself.
Jul 12, 2015 | Bernina Sewing Machines
I need to know the amperage for the power source for the tiny tailor. The power source is missing and i need to replace it.
I have the original power source - it is Hon-Kwang, class 2 transformer D45-10
Input 120V 60 Hz 12w
Output 4.5Vdc 800mA
Hope that helps - that is all it says
Dec 16, 2010 | Singer Tiny Tailor TT700
My Janome 10000 has been sitting idle for about 6 months and I can hardly turn the hand wheel. Is there a place to oil or grease the machine to allow easier turning?
Remove the top cover (3 screws) and lubricate with good quality thin lubricant the top shaft running horizontally through the machine. This haft has 2 bushes and is a common source of seizing, especially at the handwheel end.
If this doesn't cure the problem have it serviced by a technician (there are numerous lube points inside the machine and these should be adressed every 12 - 24 months.
Nov 04, 2009 | Janome Memory Craft 10000
White euroflair 8910 motor won't turn on
motor inside the casing you have to remove the cover motor at the rear beside the handwheel of sewing machine loosen set screw or lift upside machine bed so you can see the motor and wiring circuit,if bottom cover is present loosen bolt remove cover you can check motor wiring using multitester setting to R10 set switch on and setting test probe red and black rod attaching the two terminal of male plug start pedal switch besure it was unplug on ac source if there resistance on the circuit and the motor.If negative result.Isolate checking the electrical circuit.check continuity of switch,if ok.check armature winding of the motor in two terminal of the motor, you have to pull out motor inside the casing first remove belt from the motor and handwheel.Loosen the 3 bolt from motor holder to the casing.In motor assymble unlock and pull out two carbon brush attaching tha armature brush replaced a new one pair of carbob brush and install back again.besure winding was not
burn out otherwise you to replaced the motor.
Mar 07, 2009 | Sewing Machines
Husqvarna Huskystar 215 Sewing Machine Logo
61 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
