Question about HP Color LaserJet 2600n Printer
Where is the mirrors and lenses in HP Color LaserJet 2600n
  • Brad Clapp Apr 26, 2014
    They are located in the Laser Scanner Assy behind the toner cartridges. When you pull out the cartridges you will see four horizontal slots with lenses. If one of these gets dirty it will cause problems with the print of the color lens that is dirty. The rest of the assembly is sealed and can't get dirty.
    Problem Solver:
  • 13 Answers
Posted on Apr 26, 2014
SOURCE: HP Color LaserJet 2600n
Called HP service today as I had a similar problem......and I was out of warranty....but they said this happens at times if dust get into the top of the printer and they have a recall on them because of that.....they are shipping me a repolacement....FREE of charge.
Posted on Dec 04, 2007
713printech
  • 32 Answers
SOURCE: HP color LaserJet 2600n stucked on Initialzing
Well we can check and see if the printer is able to run an engine test. This is how you can run this test;
  1. Turn the printer around so the back of the machine is facing you.
  2. Remove the Engine etest button acess door. This is located in the bottom center of the back.
  3. Push the botton once while the printer is on. The printer should print a page with colored horizontal lines.
If the printer is able to print this page there is a very good indication the problem revolves around the PCA formatter board.
The Firmware might be outdated and causing this problem. Worst case scenario the board might be faulty, in that case your better off buying a new machine, since the cost to replace the board will be higher than that to replace this machine.
Posted on Nov 19, 2008
  • 237 Answers
SOURCE: Sensor error, turn off then on
Check the level of your toner or TOP errors. If the problem persists, let me know
Posted on Nov 25, 2008
SmartFix
  • 89 Answers
SOURCE: My printer says there is a jam in the output bin
Just try the steps
Jam in output bin - fuser area Error messageJam in output binalternates withOpen door and clear jam DescriptionA paper jam has occurred in the output bin near the fuser area. Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.
Jam in output bin - duplex area Error messageJam in output binalternates withOpen door and clear jam DescriptionPaper jam in duplex reversing area Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.Please Rate my response!!!Thanks, SF
Posted on Jan 28, 2010
SOURCE: hp color laserjet 2600n displays error 55.1 turn off then on
hello friend i have a printer HPColor Laserjet 2600n it displays Erroe 55.1 Turn OFF/ON. How do i over come this problem?thx
Posted on Jun 15, 2010
I changed a cartridge but the print is still very light
I received a similar HP Laserjet Color Printer with same issue for repair/ maintenance.
Actually the problem is with the printer design not the cartridge and it needs professional hands for servicing and cleaning. The mirrors which reflect laser beam get covered with dust and toner. Laser beams are partially reflected due to dust. Hence the image is not produced properly. Note that first magenta goes off, followed by yellow, then cyan and lastly black. this is because of the mirrors placement inside the printer.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. For cleaning, the printer's outer covers are required to be removed to reach the inside laser unit, mirror and lenses, which requires professional expertise.
Clean them yourself with dry, soft, lint-free cloth (if you are familiar with such tasks) or get it cleaned by any printer repair/ service professional. Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors.
If you need any help in cleaning mirrors and lenses let me know
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | HP Color LaserJet 2600n Printer
When i print toner status black color is faded as well as yellow and cyan, magenta showing white color, can you please give the best solution for this. by the way i am using hp 2600n. thank you very much.
First, make sure that the toner cartridges have enough toner. The toners may be exhausted. In case the toners are ok, the printer requires servicing/ cleaning of lenses and mirrors inside the printer.
Please refer here to my earlier solution to this problem, which was very helpful for the users of Color LaserJet 2600n Printer.
GoodLuck!
Dont forget to appreciate the solutions if I could have been of any help!
CreativeTECH
Dec 08, 2010 | HP Color LaserJet 2600n Printer
My Hp Color laserjet 2605 was not working some colors (yellow,megeanta) so how to resolve this problem ? all color tones are new ! i would pinted test page black and cyan was ok
This is a common problem with this model of printer. The scanner optic degeneration is due to dust buildup on mirrors and lenses. Since the most vulnerable mirror reflects its laser beam to the magenta and yellow toner cartridges, red tones are the first to show fading. Colors shift: purples turn blue and oranges turn yellow. The printer optics will need to be cleaned by a compliant technician to resolve this issue as it means dismantling your printer and cleaning the mirrors and lenses in the optic section to fix the problem.
Aug 09, 2010 | HP Color LaserJet 2600n Printer
MY HP ''COLOR LASER JET 2600n'' HAS FUOLL INK CARTRIDGES BUT THE PRINTING IS REALLY DULL AND FADED LOOKING. CAN ANYONE HELP? TERRY M.
This is a common problem with this model of printer. The scanner optic degenration is due to dust buildup on mirrors and lenses. Since the most vulnerable mirror reflects its laser beam to the magenta toner cartridge, red tones are the first to show fading. Colours shift: purples turn blue and oranges turn yellow. The printer will need to be cleaned by a certified HP technician to resolve this issue as it means dismantling your printer to fix the problem.
May 30, 2010 | HP Color LaserJet 2600n Printer
I have an HP laserJet 2600N Printer Iinstalled
The laser unit is positioned in such a position that the air intake fan draws any environmental dust into the unit and the lens and mirrors of the magenta laser are first to be deposited with this dust resulting in a week laser beam onto the magenta drum , resulting in very light magenta images. Solution if you are technical minded take the unit out the rear ond clean all the laser mirrors and lenses be very carefull. I regularly have a machine in the workshop with this problem , the cleaning of the laser unit can also be a solution to the colour mis alighnment problem.
Mar 12, 2010 | HP Color LaserJet 2600n Printer
Hello, I have HP lj 2600n. It does not
the problem is due to scanner mirror dust.you have to clean the scanner mirror.
Oct 26, 2009 | HP Color LaserJet 2600n Printer
Color printing (not black)is light on left side with HP color laserjet 2600n.
you have to clean the scanner mirror . open the front cover and remove all the cartridge. you can see a 4 no's of rectangle box in which inside you can a mirrors.clean all the four mirrors.
Oct 20, 2009 | HP Color LaserJet 2600n Printer
Color LaserJet 2600n Some of the colors are not printing.
replace color cartriges restart and let computer clean the heads
Jul 29, 2009 | HP Color LaserJet 2600n Printer
Colours show differently in different parts of the page, tried the cleaning routines no go
you need remove the laser/scanner unit and clean the mirrors and lenses, use a dry qtip , mostly of this quality problems i resolve with this procedure.
Jul 10, 2009 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
41 people viewed this question
Seeker5211
Seeker5211
