Question about Husqvarna Huskystar 215 Sewing Machine
Broken handwheel for 207/215 huskystar sewing machine
Broken handwheel
  • Husqvarna Master
  • 1,388 Answers
Husqvarna Dealers will advise price/availability
Posted on Apr 22, 2014
  • 6 Answers
SOURCE: My fabric won't feed on my sewing machine
Your feed dogs are in the down position. Check your manual.
Posted on Jun 18, 2009
  • 76 Answers
SOURCE: i need an instruction manual for my Huskystar model 65
try this site
SewingManuals.com
Posted on Aug 28, 2009
  • 152 Answers
SOURCE: I have a Huskystar C10, I continue to get the
This problem occurs because the machine is not pulling the top thread upward out of the bobbin area and all the threads then jam under the fabric. The problem looks like it's in the bottom of the machine, (and there is a slight chance it is) but 99% of the time it's caused from the top of the machine.
1. Remove the thread completely from the top.
2. Lift the presser foot into the "up"position. (When the foot is up, the top tension discs loosen and your thread can get deep into the unit where it belongs.)
3. Great time for a new needle, flat side to the back and make sure it's up in all the way.
4.When threading the machine I always think of, "Down, Up and Down".
You come from the top, down to the covered spring (called a check spring), then back up to the take up lever (the lever that moves up and down rapidly as the machine sews), then back down to the needle.
5. After the needle is threaded, lower the lever in the back so the foot goes down but don't put it on the thread. Hold the thread in your left hand, directly from the needle eye at this point, pull the thread towards the rear of the machine. You should feel a tightness in the thread, almost fighting you. The needle will bow slightly before the thread comes through the machine. If you have no resistance you've found your problem. (Tension number 4 or 5 should work)
6. Remove the bobbin, check the edges, are they smooth? Does the thread wound on the bobbin look balanced? It has to be for proper delivery. Make sure you are using the proper bobbin. There is a singer bobbin that looks like the one your machine takes but it will not work correctly. If you have different clear plastic bobbins and they are different in height, you machine takes the taller one. Drop in a good bobbin and thread the bobbin tension, make sure to "click" the thread in there good. Pick up the bobbin thread, through the hole of the needle plate by taking a stitch by turning the handwheel and gently pull on the bobbin thread to feel it's tension. It should be a fraction of the top "feel" that the needle thread had, they are never even. You should feel slight resistance from the bobbin thread, not tight. Try a test stitch and see what happens, hopefully your sewing!
Posted on Oct 15, 2009
  • 152 Answers
SOURCE: I have a Huskystar C20 sewing machine and the
Take off the needle plate. There is a bracket near the front right area of the bobbin case. It is the position bracket that supports the case. First smooth the case of any rough edges, the put it in place and loosen the screw of the position bracket and align it in an area that will keep the case from spinning. There should be about 0.5mm of distance available when you use your finger and push the case from left to right, between the case and the bracket. Remember that the thread flows through this area, the case is held in place by the bracket but not tightly.
Posted on Nov 21, 2009
SOURCE: wanted free manual for huskystar 215 sewing
http://s2.vsmgroup.com/VSM/Husqvarna%20Viking/HVManual.nsf/1fd5659e6f37141041256697003e64c0/5e53fcaacf407dcd852575ed00744b6c?OpenDocument
Posted on Aug 10, 2010
Kenmore 19233 sewing machine. Then handwheel is broken, spins freely. Machine works perfectly otherwise. How do I remove the handwheel and replace it.
If the drive belt is not off or broken, then check hand-wheel setting. On some models the hand wheel can be pushed in (to engage) and pulled out (to disengage) for using bobbin winder. If it is disengaged the hand-wheel will spin freely. On older models there is a smaller wheel that has to be hand tightened in order to engage rest of machine. Hope this helps.
Nov 20, 2016 | Kenmore Sewing Machines
What could cause the motor to turn but the needle doesnt move?
it's possible that the sewing machine may need a adjustment or a part could be broken, the machine should be checked
Dec 06, 2014 | Necchi Sewing Machines
Where to get a new handwheel/handwheel switch for a Singer 3270C sewing machine?
They may not have it but they should be able to order it. How old is the machine? If it is too old, they may not support it any more
Nov 24, 2014 | Singer 3270 Mechanical Sewing Machine
How does the thread on top of machine stay put
The steel piece on top should extend upward. You probably have 2, one for sewing and one for bobbin winding. It may be that the steel piece is not fully extended upward or has broken.
Hope this helps.
Oct 05, 2014 | Husqvarna Huskystar 215 Sewing Machine
Cannot source replacement handwheel , can anyone help me source one
Have you tried http://www.sewingpartsonline.com/handwheel-viking-4123009-01.aspx ?
Apr 01, 2014 | Husqvarna Huskystar 215 Sewing Machine
Free huskystar e20
since the lights turn on then you can rule out the on/off switch and the power cord
could be a
broken part
a timing problem
try unplugging the foot pedal and then plug the foot pedal back up and see if that help
if that doens't help then it would be a good idea to have the machine checked
Oct 24, 2013 | Sewing Machines
Singer 3116 handwheel stuck. Just hums
First, remove the bobbon, hook and anything in the lower part of the machine. try to turn the handwheel. Do not force it. If this does not free it up, take it to a technician. Could be seized or may have a broken gear.
Sewing machine Tech
Oct 23, 2013 | Singer 3116 Simple
My huskystar c20 handwheel will not spin. It this an item that can be fixed or should I start looking for a new machine
it depend on what's wrong with the handwheel, I suggest contacting
a sewing machine repair shop and tell them what the handwheel
is doing or not doing and ask them if the machine is worth fixing.
because there could be a broken part or just a part that has come
loose or maybe the machine may just need some type of
adjustment.
Dec 12, 2012 | Sewing Machines
The motor on my huskystar 207 has seized up.
Needle broke then it seized? Could be any number of things from a bent upper arm to a motor that needs servicing. I recommend you take it in for professional repair.
Sep 15, 2012 | Husqvarna Huskystar 207 Sewing Machine
Husqvarna Huskystar 215 Sewing Machine Logo
90 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
