Question about Sony Cyber-shot DSC-W120 Digital Camera
My camera keeps turning itself off and the amber light keeps flashing
    Scholar:
  • 89 Answers
Please check whether the battery is fully charged.
Please try using a different battery.
If the issue still persists after changing the battery try Power Resetting the Camera which should resolve the issue.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Posted on Jun 17, 2009
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
When charging amber light flashes
What model Samsung camera? With many cameras, a flashing amber light is normal while charging. Once fully charged, the light may turn green and/or stop flashing.
Aug 04, 2013 | Samsung Cameras
2001 Lincoln LS V8 Advance Trac sensors replaced, but amber light on dashboard will not quit flashing. Shop cleared the codes when they replaced the sensor. The
The repair shop did not make the repair necessary
There are no advance trac sensors
Advance Trac is an add on option when new,
to the ABS Braking system
Even if the mil lamp is cleared, there will be codes
there when you access with a professional scanner,
since you have the amber lamp on
The only sensors are wheel speed sensors
Oct 01, 2012 | 2001 Lincoln LS
Wireless amber light flashing problem
If the wireles light is flashing Amber .. Some one outside your house is trying to access the Wireless network . If it is always flashing amber.. try with a Firmware update available in belkin.com/au/support.
Thank You
Jul 26, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
Does not power up
Is the amber light flashing on the monitor?
If so, you should get your power supply checked.
Jun 11, 2008 | Dell Dimension 2400 PC Desktop
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Switching the camera on .
omg, i have the same problem! why does it do this?!
Jan 16, 2008 | Vivitar ViviCam 4345 Digital Camera
Operation lamp - amber light blinking
I do not know the solution to your problem but I can tell you that when the camera is working properly that amber light means the flash is chargeing or your camera is doing something like saveing a picture so if your battery is low your flash might not charge properly or your camera might have something wrong with is memory. Sorry i couldn't be a better help.Good luck!
Sep 06, 2007 | Casio Exilim EX-S600 Digital Camera
Sony Cyber-shot DSC-W120 Digital Camera Logo
200 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
