Question about Honeywell Digital Round Single Stage Non-programmable Thermostat
In house temp is high and furnace stll goes on
Temp is set at 64,inside temp is 70 but furnace still fires, why
  • 50 Answers
Might be dust in the thermostat. Filters might be dirty. I would call a service man before the house burns down!
Posted on Apr 01, 2014
My fan doesn't turn off after I turn the car off its a 93 Oldsmobile Kutless Ciara
There should be a temp sensor for the fan inline with the fuse block. Sounds like the sensor is reading improperly and needs to be replaced.
Jan 07, 2015 | Standard 1991-1993 Oldsmobile Cutlass...
New furnace, Water In Induction Motor, Yellow Flame
The problem is too much gas as opposed to not enough air. It is still running rich. Did you take into account the elevation of the location your furnace is installed at. The higher above sea level the less air that you have to aid in cumbustion. The condensation is from excess gas being cold and causing water to accumulate. Can you run it like this? Yes but it will cause issues with soot and carbon deposits. It will also cost you more money in the long run.
Dec 23, 2013 | Goodman Manufacturing Goodman GCH950453BX...
New a/c - furnace installed, no instruction manual, it is 23 degrees outside, and I have no idea how to turn on heat instead of a/c. Need thermostat instructions.
Usually just put the thermostat fan on auto, the a/c heat switch to heat and set the temperature where you want it. If it's a gas furnace, you will need to light the pilot. Usually instructions are on the furnace door, maybe inside furnace door.
Dec 05, 2013 | Air Purifiers
Fan wont turn
I have taken one apart. reassembled and the fan would not turn, although there was power to the motor and it wanted to turn.
Sorry this is long...only this is about taking the motor itself apart..and I have yet to find a replacement motor.
1. Tried a little WD 40...(only on iron motor Housing!) nothing.
2. Took apart inside of motor. some rust inside..
3. carefully rubbed clean with WD 40..
4. leaned off WD 40 with contact cleaner...
5. Then worked little bearing loose on back side.
-Kind of turned upon reassembly..
6. Found some silicone High temp lubricant and took motor inside part again.
7. a very thin coat of lubricant inside rotor.
-Re assembled yet again..began to turn at high speed, kept running..24 hrs..
- It .finally turned at silent mode. and continues to work
This may be ar beyond what you want to do, however if all else fails...what else can you do? buy another one?
Tips:
1. mark rotor holders with housing. (do not reverse.)
2. make sure you remove all lint, dust, etc inside.
3. the rotor bearing I had to work by hand again and again repeatedly syringing a little WD 40 at a time to until it turned easily.
Jun 04, 2012 | Oreck XL Professional Air Purifier
We are using a living air purifier xL15S and we are all getting sick. Headaches, colds. I know on the back of the machine it states that high levels of ozone can be injurious to ones health if not in a...
I would doubt that high ozone levels are causeing your problems. It is possible if your house is not properly ventilated for ozone to be hazardous so I would recommend that you cut the time that you are using your air purifier in half and for the next 2-3 months I would change furnace filters on a weekly basis.Also clean all carpets and drapes to remove all tobaco residue. I hope this helps you and that you all start feeling better.Thank you.
Feb 10, 2011 | Alpine Air XL-15 Air Purifier
My freshair 2.0 turns on and right back off. the screen lights up and then goes out.
The most common reason for surging or changing power levels is a loose connection somewhere.
1) Make sure the plug in the back is inserted firmly and the wall socket is live. The wall socket should not be powering a high-use appliance such as a furnace or refrigerator.
2) Make sure the plate is inserted firmly and correctly in the top and bottom "tracks" inside the machine. The metal contact fingers should be pressing firmly and evenly on both sides of the plate, in the metal screen area.
3) Inspect the interior of the machine, looking for loose wires, corroded clips, any broken wires or connections. (You or a handy friend may be able to repair the loose wires or clips; it's a pretty basic fix.)
If none of these troubleshooting steps solve the problem, the problem may be in the computerized system. For that, you'll need to get in touch with Vollara (formerly EcoQuest) customer service. 800-989-2299.
Jan 11, 2011 | Ecoquest Fresh Air Air Purifier
How to reset hrv filter light
1: Press the clip_image001.jpg button to turn off the screen.
2: Press and hold the down arrow button until an 02 appears in the Roof Temp, when you see the 02 appear remove your finger.
3: Using the clip_image001.jpg button - short continuous pushes until you see 02 on the top (Roof Temp) and 5 underneath (House Temp) NB: The light should go off.
4: Press the clip_image002.jpg and this will save your changes.
Oct 25, 2010 | Air Purifiers
F300E powers up in purge mode, but shuts off when heating
In the heat mode your furnace fan operates in a lower speed. when your zone panel purges it powers the G terminal in your furnace, which is high speed. You may have an airflow problem if your EAC is powered directly to an outlet, you may have a bad air pressure switch, or if the eac is wired to the furnace control board, it is mis-wired..more info needed.
Dec 12, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Ionic Breeze Repair
Ionic Breeze GP. Unit was working. Removed insert to clean. Now the unit will not turn on.
Jun 11, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Honeywell Digital Round Single Stage Non-programmable Thermostat Logo
59 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
