Question about Samsung Alias 2 SCH-U750 Cell Phone
SIM card Trying to restore wet phone. Removed battery. Put phone in dry grain. Read to remove SIM card. Is micro-SD card the same thing or similar? I don't have one, so out of luck.
  • 1 more comment
  • Janie
    Janie Apr 01, 2014
    Is a SIM card the same thing as a Micro-SD card?
  • Janie
    Janie Apr 01, 2014
  • Janie
    Janie Apr 01, 2014
    Does this phone have a SIM card?
  • 50 Answers
I think they are same or similar. I think if it fits it will work. Might be differences in the recovery speed between photos. To access card on computer you will need an adapter.
Posted on Apr 01, 2014
patel352003
  • 192 Answers
SOURCE: micro sd card not reading songs
Yes, Brother there is one probability that your sd is formatted in fat-32 file system. For that i would like to say phone can only read FAT not FAT-32. Go to my computer, select sd drive properties and format it with FAT file system. Then load the files and you will be able to see it in your phone. If it works don't forget to vote here. For any proble contact me patel352003@gmail.com or patel352003@yahoo.co.in
Posted on Jan 07, 2008
  • 40 Answers
SOURCE: saving music on my micro sd..
well assuming you loaded music on your sd card:
to find it, just go to mystuff....
menu, mystuff, center button, it should load the mini sd right there. then all you have to do is click over right and file explore the mini sd. you should put music in the music file.
another option on the phone.....
go to att music
menu, upper left icon, center button, music player, it should find all files.
let me know how i can help some more
Posted on Feb 24, 2008
SOURCE: sgh-m620 cannot read micro sd
i just had the same problem and I found out that the phone can only handle 2gb and below. I had a 4gb card and the phone would not read it but once i switched it to a 1 gb it came right up.
Posted on Jan 14, 2009
  • 4 Answers
SOURCE: G600 SD Card Support
Firstly, ensure that the memory card is correctly slotted in fully until you hear a faint click. [the card can be removed by simply pressing/clicking it back out again]. the memory card icon should appear at the very top of the phone's screen.
In the event that you have done that, to save files to the memory card, go to:
Menu;
Settings;
Memory Settings;
Default Memory;
Then select which items you wish to be saved to the memory card in future;
For example, select 'Camera', then scroll down to and select 'memory card', and press save.
Do this for each form of media, from the 'default memory' list, that you wish to save to the memory card.
Hope it helps!
Posted on Mar 07, 2009
SOURCE: Samsung G600 - phone asks for sim card but doesnt work when inser
when phones get wet they start to rust from the inside, unfourtunaly this is a long prosses and can take a few months but usually if the phone has got very wet they will not work propley again. they may work temperally but eventually it will probably be completly usless. in future if u wet a phone try drying it immediatly with a hairdryer, inside the battery bit too, this may help the water inside the phone not to cause rusting. sorry about your phone.
Posted on May 19, 2009
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
Tip
Adding a micro sd to your phone increases multimedia capabilities
Adding a Micro SD card to your cell phone is a wonderful way of fully using the multimedia capabilities of most modern day phones.
Most current cell phones now have the capability of having a micro SD card. It it simple to add one and is similar to inserting your SIM card. Take of the battery backing, pull out you battery and you will view a small rectangular slot which holds your cell SIM card. If your phone has the option of having a micro SD storage card you will see a similar smaller rectangular slot or compartment for a micro SD.
You can purchase micro SD cards at many stores and the price has dropped tremendously and can now holds up to 16 gigabytes of memory. With this card in place you can now use your phone to hold a large amount of songs which can be used for ring tones and use you phone as a MP3 player. If your phone has a camera you will be able to store far more pictures then any phone comes standard with. You can also, place and store important documents on your phone. With a large enough card your phone should fully cover all your multimedia needs and unlock the full potential of your phone.
A micro SD card is a great way to get the most out of your cell phone.
on Mar 25, 2010 | Cell Phones
Hi chris , i'm trying to put SIM card from my contract mobile phone in to my GT-P5110.Does it go in the SD micro slot ? thanks
The SIM card is usually located under the battery. Do not put it in the micro SD slot.
Feb 23, 2013 | Cell Phones
Micro sd card in sim card slot removal
I just did the same thing. I didn't want to put anything metal in to the slot. After trying with various pieces of hard packaging plastic I put double sided sticky tape on a piece of plastic and slid it down into the slot. The sd card attached itself to the sticky tape and I was able to pull it out. Good luck
Jan 06, 2012 | ViewSonic ViewPad 7 Android Tablet
My iphone will not read the sim card. The card works fine in another phone. My phone was submerged in a tub of greasy water and i am tryinng to restore it now.
Ben, Could you try dry it first? Do not turn on.
As you said that your card is not read by iphone, i can see that you already turn it on after it submerged in greasy water. I hope it doesn't short circuit yet. Use hair dryer, dry your iphone through the usb connection hole, leave for awhile, make sure it dry, then try again. Hope this will help. For future, if phone dropped in water, first thing to do is take off battery, or turn of completely then dry it before checking it still work or not.Thanks for reading.
May 18, 2011 | Apple iPhone Smartphone
I have a Motorola W260G Tracfone and I'm getting a "Restricted Number - 34" message all of a sudden. What is this about?
Had a similar problem on my V170. Remove the battery and the sim card. Using a q-tip dampened (not dripping wet) with rubbing alcohol, clean the metallic side of the sim card and allow to air-dry, then wipe once more with a dry q-tip. Do the same for the metal terminals in the sim card slot if visible. Go ahead and clean the battery's contacts and the ones in the phone while you're there. Put it all back together and try again. This will fix most sim-card problems as long as there's no physical damage.
Good Luck
Jim
Aug 03, 2009 | Motorola Mobility TracFone® V170 Cellular...
Freezing when I install a micro sd card into my samsung eternity
i had the same problem. so i try whatever i can
- i remove battery, put it back on, turn the phone back on. seems like it works for 3-5 minutes and freeze again
- i remove sim (only ),memory card still in there, and turn the phone back on..let it sit with no sim. and 3 minutes later it freeze again
- i remove sim, remove micro sdhc, reset the phone , the phone automatic restart..it woks... it never freeze ( no sim+ no memory card )
- i put the sim back on, no memory card, turn the phone back on and it works!!!!!!! i try these 2-3 times without memory card. works normal!!!
so..i think its a memory card issue. may be the phone doesn't like it. i have 2gb. kingston. or i have to buy a new card again.
for now its still working without freeze up for shut down by itself.
hope it help :)
moo
Jul 16, 2009 | Samsung Eternity Cell Phone
I want to unlock micro sd card in nok 5200
U CAN TRY TO USE THE UNLOCKER SOFTWARE, SEARH FROM GOOGLE.IS A WINDOWS SOFTWARE.AND PUT YOUR MICRO TO THE READER, RIGHT CLICK N UNLOCK MOVE TO OTHER FOLDER.
Dec 27, 2008 | Nokia 3110 Cellular Phone
Paul skurulis
you needed to open your phone and to dry it throughly or have it check to technicians maybe thier is still moisture left inside and causes your phone to malfunction.
Oct 17, 2007 | Samsung SGH-A707 Cellular Phone
Samsung Alias 2 SCH-U750 Cell Phone Logo
83 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
