Question about Samsung Televison & Video
Factory reset samsung lcd la32r8
Switched on tv and the colors are gone. seen it can be resolved using remote with codes plz help
  • farrukh
    farrukh Apr 03, 2014
    The LCD was working normal. While watching TV it turned blur. More of a neon type picture. I read it on the net that the problem can be resolved thru factory reset. However, I donot know how to factory reset using the remote control. Plz help me get the code to factory reset the TV. Its model is LA32R81BX
SOURCE: COMCAST REMOTE AND SAMSUNG TV
I was having the same issue with a Samsung 4053 40"
Comcrap had no clue.
Their phone rep suggested I come in and trade out the remote. That seemed unlikely if others are having the same experience. It is also unlikely a phone rep would have any answer other than what on the web page.
I used 5 digit code "10060" and it worked got the double flag from the remote like Comcast's documentation says. It turns TV on and off and works volume. So far so good.
The key to figuring it out was getting the double flash on the remote 4 digits didn't 5 did.
The moral of our story? Comcast has no clue what they push out the door. I guess that isn't a surprise to anyone.
Posted on Jan 13, 2008
moto34
  • 155 Answers
SOURCE: Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
Posted on May 03, 2008
SOURCE: Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
Posted on Feb 04, 2009
  • 210 Answers
SOURCE: how do i reset factory sttings on samsung lcd tv
go into analogue tv press menu move down to settings you should be able to enter plug and play in menu press ok( if you can not enter it you are not in analogue )
if not solve problem try this !! warning !!
you will enter the service menu DONT ENTER OR CHANGE ANY OTHER ITEMS THAT ARE DISPLAYED AS TV WILL NOT WORK IF YOU DO
With tv in standby press INFO / MENU / MUTE / STANDBY on remote
then use ONLY DOWN nav-key move to number 12 FACTORY RESET
press RIGHT nav-key will reset all tv settings to factory ones
PRESS STANDBY TO EXIT on remote
you will have to RETUNE after tv after
Posted on Oct 26, 2009
  • 210 Answers
SOURCE: Samsung Le40a556 factory reset
with tv in standby press INFO / MENU / MUTE / STANDBY on remote the tv will come on in factory menu settings look for reset use DOWN NAV KEY until highlighted and press RIGHT NAV KEY
to exit settings press standby the tv will come on and follow on screen instructions
DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK IF CHANGED
Posted on Dec 13, 2009
Volume is at MAX every time i start my Samsung TV LCD LA37A550P1R
Check your manual for resetting the TV to 'Factory Default'. I have heard of this happening before. It may need you to press a combination of buttons on your remote. Usually you have to be pressing the buttons in sequence with the TV in standby, then wait for a service menu to appear. Look through this menu for the words 'Factory Reset'. It may be in a sub menu. The TV may well switch itself back off and then on again. At which point your problem should have gone away.
Dec 21, 2013 | Dell W1700 17 in. HD-Ready LCD Television
Black diamond tv manual
make this steps and fix it. God bless you
Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Jul 31, 2013 | Televison & Video
Flashing 3 colors red, green and blue to turn it off I had to unplug it. Trying to switching from TV to DVD. This have happened before. I don't have a remote but the service man reset it some how
Download the user manual to your TV. It will have all details about how to reset it to factory default. A factory default set should be done now. To download its user manual, click here.
Jun 21, 2012 | Sylvania LD320SSX LCD TV
Sony bravia v series 32"
hi,
IT normally happens after factory reset is done. You need to reprogram the channels. Try the auto program (AUTO TUNING) Process.
  1. On your remote commander " Press HOME or MENU button"
  2. Scroll down to " SETTINGS or SET-UP"
  3. Then to "CHANNEL SET-UP"
  4. Select " AUTO PROGRAM " To Auto program your LCD TV and it's done..
Jan 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Samsung tv rest code
in order to reset a locked out TV you must contact Samsung technical support, they are the only ones that give you a override code to reset the lock out. the number is listed in your owners manual.
Mar 19, 2010 | Samsung DLP HL-P5663W 56" TV
Red color is completely gone out of the LCD flat screen
You can try performing a factory reset of the TV. Go into the service menu (Press, then release the INPUT button on the remote, then key in 2580). Scroll down to "Other Settings", then go to "EEPROM Init", then press enter, select YES and press enter. This will reset the TV to the factory defaults. Good luck!
Jan 12, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Dec 13, 2009 | Televison & Video
I want to restart my samsung LCD TV LE32R71B, how can i do it?
You can reset 2 ways Put tv into analog mode by pressing TV/DTV on remote then press Menu move down to the satellite pic press enter you will see plug & play in the list press enter and follow on screen instructions
The other way
WARNING TV WILL NOT WORK IF YOU CHANGE ANY OTHER SETTINGS
With tv in STANDBY Press INFO / MENU / MUTE / STANDBY on remote the tv will come on with the factory settings displayed
FACTORY RESET ( 12 ) will be in there USE DOWN KEY ONLY until Factory reset is Highlighted then press the RIGHT KEY the set will reset all settings PRESS POWER ON TV TO EXIT
Turn ON TV AND RETUNE
Nov 05, 2009 | Samsung LE32R71B 32 in. HD-Ready LCD...
Televison & Video Logo
65 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
