Question about LG enV VX9900 Cellular Phone
I need the service code to manually program a VX9900,I tried all 0's
LG Env vx9900 Can't unlock and wondering if there is a way i can bypass the unlock code and reset the phone
If Verizon dial l *228 and wait while it reprograms your code to the last four of your phone number. If you have the newer firmware this might not work. on the newer firmware. Using the QWERTY keybad type in "##program9900" which translates to "##77647269900" typed in
"SYM, 3, SYM, 3, p, r, o, g, r, a, m, 9, 9, 0, 0" and then the code is all 0's
May 09, 2011 | LG enV VX9900 Cellular Phone
Hi i can not enter the name of my shop in the casio se-s300, can you show me how to enter it in to the till. also i have got e035 problem too.
For E35, try this:
Turn key to program position 1 SUBTOTAL 0 Cash SUBTOTAL 3 SUBTOTAL 0 CASH SUBTOTAL
For shop name, you need to use the codes 132, 232, 332, 432. Are you using these codes for the lines? What happens when you try to change it?
For those of you looking for a complete manual for a SE-S300,
Operating and Programming manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S300_users_and_programming_manual.html
Service (repair) manual: http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S300_SE-S2000_SE-C300_SE-C2000_TE-900_TE-1500_TK-950_TK-1550_service_manual.html
Jan 20, 2011 | Casio Parts Cash Register PC Desktop
Need code for sharp tv, and program mode
Sharp 0 0 9 3 ,0 6 8 8 ,0 1 6 5 ,0 0 3 9 ,0 3 8 6 ,0 1 5 7
Manual link for instructions
http://www.rockabilly.net/manuals/manual.shtml?URC-4605
Jul 27, 2010 | One For All URC-4605 Remote Control
What's the LG VX9900 phone's default unlock code
According to the user's manual, it is the last 4 digits of your phone number.
Feb 23, 2010 | LG enV VX9900 Cellular Phone
I found an lg vx9900 but the phone has a locked code and i cant unlock it. can you help me?
Unfortunately the phone will need to be activated and programmed on a number before it can be unlocked. Then the lock code will be the last 4 digits of that cell number. Take it to your local Verizon store and see if they can assist you further.
Oct 09, 2009 | LG enV VX9900 Cellular Phone
I need to Progam a Samsung Smooth cell phone.
To Program any Samsung Verizon Phone:
+Go to Menu > Settings (may be listed as settings & tools depending on software version)
+Press the * Key (to the left of zero / 0)
+Enter the Service Programming Code (a.k.a. SPC, MSL, SEC) This code is usually 000000 for most Verizon phones, but if it was purchased prepaid you may have to get it from Verizon. Try 000000 first though.
+Go to Network Settings
You will now be in the programming menu. Enter the information as it pertains to the field indicated.
+When you have entered all of the programming information, press END.
The device will now reset and save the programming information.
Jul 25, 2009 | Cell Phones
Manuelly programming lg vx 9900 to cricket service
any missing info should be provided by your reseller.......
here is what I found...
Note: Some Programming must be done from the internal keypad / QWERTY Keyboard.
Alternate Programming Sequence for the VX9900 (Orange) or for newer software versions.
[#] [#] + [7][7][6][4][7][2][6][9][9][0][0] + [SEND]
OTA PROGRAMMING
Step 01:
Change ESN in billing system.
Step 02:
Power up the handset.
Step 03:
Dial *228 + SEND
Step 04:
Follow the VRU prompts
USE OTA Where Available. If OTA is not available follow instructions below.
Top
AKEY PROGRAMMING
Step 01:
Generate a random A-Key and power phone on.
Step 02:
With the flip CLOSED, press 2539 + * + * to access AKEY INPUT MODE.
Step 03:
Press 1 for Akey Entry
Step 04:
New AKEY displays, enter 26 digit A-key then press OK when complete.
PROGRAMMING COMPLETE
Feb 03, 2009 | LG enV VX9900 Cellular Phone
Help
Go into the phone settings and in there under Phone INfo, it will show you the phone number it has assigned, try using the last four digits, also try 1234, As a last resort, you can reset the phone to factory defaults.
Also, you could download BITPIM ( its free, google it) and try hooking the phone up to your P.C. and using the program to reset it. You will need to buy the verizon sync package to get the cable and drivers, you need to install the program in order for it to install the drivers that you need to use with bitpim. Good luck and let me know if any of this helps.
Feb 23, 2008 | LG enV VX9900 Cellular Phone
Lg EnV VX9900
You might not be able to use that becasue thats a verizon feature and they have there network info bassically permenently installed in the hardware. If you open the flip phone, hit menu, and hit " 0 " it will give you a service menue, password is all 0's
Dont mess around in there, you could mess up the phone, but if you look at the setting, somewhere in there it will show you that verizon has there info in there even though cricket flashed it, you cant change it. At least no way that i have found.
Jan 08, 2008 | LG enV VX9900 Cellular Phone
The default lock code is always either "0000" or the last 4 digits in your phone number.
I strongly encourage changing the code going to Settings & Tools > Phone Settings > Security > [Enter the last 4 digits in your number] > Edit Code
Nov 07, 2007 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
168 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
