Question about Dehumidifiers
I require an instruction manual for Blyss 300W Convector Heater with Turbo Fan & Timer - EAN 5052931077953
Missing instruction manual
  • Dehumidifiers Master
  • 3,368 Answers
Try looking on the internet. I do not expect you will find a solution in the dehumidifier section.
Posted on May 30, 2014
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
I recently posted about my Blyss dehumidifier not working. I removed the back panel for the 2nd time today and noticed the fan wasn't even moving. I spun it round (Health & Safety - with the plug pulled...
This is great. My guess it will keep working much longer. But perhaps when you put it down for a while you will enter the same problem. Electro motors, there are lots of different principles, sometimes stop on a point, they can't start. If this happens every time, you switch it off, there is a malfunction. this time, perhaps only a little dust gave to much friction, to come on.
The induction motor, in your Blyss, could have one defective coil in its rotor, but the chance it will stop on the same place again, will be slim. If it becomes annoying, because you have to rotate it more often, the motor should be replaced. (or start saving for a new dehumidifier)
Oct 06, 2014 | Dehumidifiers
Haier CPN12XH9 Portlable Air Conditioner/Heater - The upper water plug (which I can't find a picture of on any manual) accumulates water while the lower tank (where water should be) is dry. Unit is only...
Not up on the unit, but water condenses on the evaporator of an a/c unit dropping onto a tray, as self evaporating, would assume that the drain from that tray is fed to the top of the compresor, which will have a tray around the top, heat from the compressor will evaporate the water, same as with a fridge. In dehumidifier mode, water would need to be collected, rather than evaporated back into the atmosphere, defeats the object other wise. so is lower tank around compressor? that would be for a/c mode upper tank for dehumidifier
Aug 05, 2014 | Haier CPN12XH9 12,000 btu Portable AC Air...
Need a Blyss dehumidifier instruction manual
I would look on line try Manual Blyss model number
Jan 26, 2014 | Dehumidifiers
How do I change the filter? Frigidaire 70 pint. I bought one with no manual from Lowe's.
Here's a link to your missing Owner's Manual. Look under the section Care & Cleaning on how to remove the filter. This manual will prove invaluable to you. So download & print it for future reference.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0180en.pdf
I hope this helped you and thanks for choosing FixYa.
Aug 03, 2011 | Frigidaire FDF70S Dehumidifier
I need the intruction manual for Delonghi dehumidifier model #DE40P.
Here is a link to the Owner's Manual, you're looking for. You can download and print the manual for future reference. Take good care of your model, perform routine maintenance, as required. As it no longer in manufacture. It has been replaced with a 45 pint unit. However, some parts your model are still available, if needed.
http://www.appliancefactoryparts.com/content/pdfs/109280.pdf
Hope this helped you.
Jul 11, 2011 | DeLonghi DE40P Dehumidifier
No instructions
only two fan speed - fast or slows. use fast humidity - cuts out appliance when required humidity is reached. set it about half way note that is f bucket if full, then a float switch will cut out the appliance
May 21, 2007 | Ebac HD880 Dehumidifier
Dehumidifiers Logo
121 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Dehumidifier Expert? Answer questions, earn points and help others
