On the back of my VCR recorder, it has a switch with TPSG written below it, does anyone know what it is for, or what it stands for? many thanks
  • Televison & ... Master
  • 5,515 Answers
Might be a test pattern signal. It might put a black backgound and two white vertical bars up so you can tune your TV via the aerial lead of the video.
Posted on Jun 20, 2009
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Regards,
BElectric
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
How do I replace the C232 capacitor on DRC8300N
I posted a solution Dec 4 '09. The C232 cap # is written on the board .Heat up the 2 solder connections below it and PULL the cap out.Reverse the procedure to install new one. (it is black/blue,round, an inch long with a silver top).
Good luck
Nov 15, 2009 | RCA DRC8300N DVD Recorder/VCR
Can,t Record from VCR to DVD
Make sure you have your VCR connected to the recorder by either the ANTENNA cable or 3 A/V cords. Make sure the recorder is on whatever output channel the VCR is set on (switch on the back of the VCR) for RF, or that the VCR is set for AV output and the recorder is set for Input 1 for the back of the recorder. You should be able to see a picture on the recorder of what's playing on the VCR. If you got that far, then you should be able to record the incoming program using the menu features of the RCA 8030. I hope this helps.
I need a manual for this machine if anyone has one.
Feb 20, 2009 | RCA DRC8030N
Analog VCR
no you can use your regular VCR. You will just have to make sure you put your coverter box to bring the signal into your vcr. You can also bring the signal into your TV from the vcr so that you don't have to have 2 converter boxes.
Jan 23, 2009 | Memorex MT1134 13" TV
VCR won't record
Check to make sure the cables on the VCR are hooked up correctly. If the in and out are reversed, this might cause your problem. Hopefully it's as simple as that. if not leave a comment and I'll get back to you.
Oct 03, 2008 | Quasar VHQ400 VHS VCR
Magnavox TV: Somehow the record button on the remote will not record VCR. It ejects the tape and does not record. Please help. Thank you.
Try Using a new VHS tape. If the new tape ejects when press recording, the recording switch inside your VCR could be defective.
Let me know if you require further assistance.
Aug 26, 2008 | Televison & Video
JVC DR-MV1S DVD Recorder / VCR... Problem
if you can actually reset the dvd/vcr recorder try the dvd menu...it should be under one of it's submenus
Jan 18, 2008 | JVC DR-MV1S DVD Recorder/VCR
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
