Question about Bissell Perfect Sweep Turbo Sweeper
Kindle fire will not charge charging port is broken was told there was recall on this
Was told by local tech here in town there was a recall on my kindle because ofthis problem
  • 50 Answers
Check Amazon's website. Are you sure it is the port. The usb to usb mini cords go bad quite often. Have you tried another known good charger and cord?
Posted on Apr 01, 2014
Auger beater bar won't turn.
did you check the belt?
Nov 27, 2015 | Vacuums
Brand new first charge The green light on the charger plug goes off after a short time. Is the unit still charging?
Once the green light goes off, it's done charging. Since it was first charge I know they say to charge it 8? hours (or 4? don't recall right offhand) but it does come charged (that's part of how they make the batteries). What you do want to do is remember not to always recharge it when your done using it. Use it till the battery goes flat, then recharge it; it will give you a longer battery life that way.
Jan 09, 2015 | Dyson DC34 Bagless Cordless Hand Vac -...
Dyson dc35 not charging
There is a connection issue here. Service tech ate corrext.
Mar 29, 2014 | Dyson Vacuums
I need the instructions for Black and Decker Start It How do I recharge it?
This unit is recharged using any household 120v outlet. Remove the rubber cap from the recharge port on the top of the unit. Plug the barrel end of the adapter cord into this port and then the put the adapter into the wall outlet. Make sure the power switch is in the off position. To check the charge level push the button to the left of the 3 indicator lights. When the green LED lights up, the unit is fully charged, (yellow is moderate charge and red is minimum charge).
Try to charge the unit from the minimum (red) charge level to maintain the maximum battery life and use of the product.
If you have misplaced the manual I am providing a link to it from Black and Decker's site.
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90550872,VEC010BD.pdf
Have a great day.
Jim
Dec 30, 2010 | Vacuums
It a rechargeale. It will not charge. is there any way to dismantle it and replace the rechargeable batteries. ? There does not appearto be any screws to separate the two halves of the body. maybe teh
What model...lots of recalled vacuums out there under recall for batteries. Can you solder ? The new batteries WILL have to be soldered. Can you get someone to read voltage of the piece you plug into the wall ?
Nov 06, 2010 | Vacuums
I have a Shark Euro Sweeper, and it doesn't hold it's charge. I only use it a matter of a few minutes and already the green light turns to orange. I was told it would hold a charge for 30 minutes. So...
I assume you've had the cleaner for a while and your battery is dying. Batteries can only be recharged a finite number of times and they also suffer from "memory loss" due to not being fully discharged before recharging.
Basically, you need a new battery. I'm not sure of your location, so I can't recommend a local supplier, however they are available from the manufacturer's website:
http://www.sharkclean.com/cgi-bin/livew/site.w?location=b2c/parts.w&itemCateg=01&frames=no&target=main&sponsor=000006
I can't give you a price as I don't know your exact model. but it should be about US$15-20. If you call the manufacturer, they may be able to give you details of a local supplier and an RRP.
Hope this helps.
Oct 18, 2010 | Vacuums
4210 Starts for a second and then stops
This will be one of, or both of, the following.
Bad battery will not take a charge and cause this condition.
NOW... Why will it not take a charge. either the battery is bad, and CAN'T take the charge the machine is giving. OR the charging circuit is fired on the main board. Sometimes a bad charging circuit will also cook your battery causing both to be screwed.
But it is a common problem with the board going bad. Some people purchase an external charger for the battery and then swap it into the roomba when charged. But this kinda defeats the automated controls. The fried charging circuit also will drain the battery when it isn't turned on. I have repaired a number of charging circuits on these units
Jul 05, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Power Unit VX475 Stops
Checked and found that motor is definitely overheating for unknown reason. Since power unit is still under warranty, solution was to contact local service company for NuTone power unit and have them come out and fix/replace it free of charge.
Jun 27, 2008 | Broan-NuTone VX475 Bagged Central System...
Bissell Perfect Sweep Turbo Sweeper Logo
49 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
