Question about Hardware & Accessories
Ge digital timer manual
Need manual for digital timer; believe model # is 15071. Thank you
4 Suggested Answers
SOURCE: GE Indoor In-Wall Smart Digital
The timer is wired incorrectly.
ON the GE timer and Utilitec timer: The red and black wires are reversed.
On the Intermatic ST01C
Posted on Oct 13, 2010
jyackle5
  • 8197 Answers
SOURCE: I have GE in-wall digital
Welcome to fixya!
The timer should be wired like this.
All white wires put together.
The red wire goes to the black wire to the light fixture.
The black wire to the black supply/power to the wall box.
The green wire gets screwed to the box if it is metal.
Or you can look at the picture below.
If you would like the manual please ask and I will supply one to you.
Good Luck
Posted on Nov 15, 2010
SOURCE: 15071 GE SMART TIMER BLINKING WHEN TURNED ON
Sounds like you connected white wire incorrectly, or are trying to replace 3-way switch.
GE 15071 and 15086 are for single-pole switch replacement only, and will not work for 3-way.
Open following page for correct wiring of GE in-wall timers, and for list of timers used for 3-way.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
If you have different timer, add a comment with in-focus photo of your timer for correct identification and possible assistance.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 22, 2011
I cannot program the "Off" time on my GE smart digital timer model 15071
Copy following link to identify timer:
GE 15071/ manufactured Tork SS720
Reset timer, and try again.
Push and hold reset button with paper clip or toothpick for 3-5 seconds.
Buy new timer at Home Depot and return defect with new receipt.
Otherwise instruction manual is straightforward, and would not accept ON time unless wired correctly.
Mar 19, 2013 | Hardware & Accessories
Intermatic/GE 15071 digital wall timer - Connection Problem
1) GE 15071 (Tork SS20) is single-pole timer, and cannot be wired as 3-way timer
http://waterheatertimer.org/How-to-wire-timers.html
2) Check wire nuts are tight
Remove light bulb and spray WD40 into socket. Reinstall light bulb
3) Reset timer using paper clip or tooth pick, then reprogram to see if functionality is restored
4) Move timer to different location and see if it controls different light
5) Buy another 15071 from home depot.
Remove bad timer, take photo of wires, and install new timer same wire-for-wire.
Return bad timer to home depot in new package.
This is GE's extended warranty plan, but do not mention warranty at return desk.
5) Intermatic and GE are fierce rivals in the timer business.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Intermatic makes their own products. GE timers are generally made by Tork. Both companies sell timers worldwide.
Feb 09, 2013 | Hardware & Accessories
Does timer 15071 automatically adjust for changing daylight length in addition to adjusting for daylight savings time?
GE 15071 sold at Home Depot and on-line has feature that adjusts for daylight savings time.
GE 15086 does not offer automatic adjustment for DST
Daylight savings time (DST) is not same as dawn-to-dusk astronomical timer.
GE 15071 and 15086 single-pole timers do not have dawn to dusk astronomical feature.
For single-pole dusk-dawn astronomical with DST, Lowes sells Utilitec-0192773
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
For 3-way switching, 7-day DST -or- dawn-dusk astronomical:
http://waterheatertimer.org/Aube-timers.html
Apr 17, 2011 | GE Hardware & Accessories
May I hook up the GE Smart Digital Timer model 15071 in a three way system. I am replacing an Intermatic SS8C.
GE 15071 is single pole only.
Open following link to see GE 15071 timer, on-line manual, and steps for wiring:
Link also shows timers that work for 3-way switch and include links to those timers and manuals:
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 27, 2011 | Vacuums
My GE Smart Digital timer won't shut off at the assigned time, but it will shut down manually.
I am guessing that you have digital in-wall timer GE 15071 or GE 15086
To identify timer for sure, see images at following link:
Manual for 15086
http://waterheatertimer.org/pdf/GE-15086-Manual.pdf
If this is new timer, the problem could be a couple things.
1) Circuit has electrical problem that is affecting timer electronics.
Use circuit analyzer from Home Depot electric department and test any receptacle on same circuit breaker as timer.
2) event1 ON was programmed but event1 OFF was not programmed. To review events, press Prog button once to see event1 ON and press Prog button again to see event1 OFF. When review is complete, press clock key to return to current time.
3) event1 ON and event1 OFF are programmed with conflicting day schedules
4) event1 and event7 have conflicting schedules
If this is new or old timer:
5) Timer needs to be reset because of internal glitch. Press and hold reset button for a moment and timer display will start flashing 12:00 am MO
6) These timers can go bad any time. I test timers and 4-6% arrive defective, and most quit after couple years, but some can last quite a while. This is why I suggest using a circuit analyzer to check if circuit is causing difficulties.
Dec 26, 2010 | Hardware & Accessories
My GE smart digital timer keeps flashing I need help to rewire this
You posted under GE timer.
Open following link to identify timer and see manual and written wiring instructions:
Most in-wall timers are wired the same way except timers listed on page that work for 3-way switching.
Dec 20, 2010 | Intermatic Inc. ST01C Digital In-Wall...
GE 15 amp 7-Day In-Wall Programmable Digital Timer Model # 15086 Internet # 100685863 Store SKU # 543414 ------------------------------------------------------------------------------- I...
Your timer is bad. It comes with 1 year limited warranty.
Buy one at Home Depot and then return defective one.
Make note of wiring before removing bad timer, so re-wire is easy.
GE 15086 is White 7-day digital, non-astronomic timer made by Tork, and sold on-line and at Home Depot.
On the shelf, 15086 timer looks identical to 15071 >> same package >>> difference is 15071 offers daylight savings time and random option, and costs a bit more.
These in-wall timers usually last a few years, and some can last for several years.
Especially when timer operates from electric circuit and not battery.
15086 operates from electric circuit.
15086 manual on-line:
Dec 05, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
GE Indoor In-Wall Smart Digital Timer Model # 15071 blinking when turned on
Aug 03, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Jul 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
