Question about Husqvarna Huskylock Computerized 905
Replace needle on a Huskylock 905
Need to remove broken left needle and replace with new one
    Scholar:
  • Husqvarna Expert
  • 104 Answers
Look in your owner's manual for needle replacement procedure. You have to unscrew the small screw holding the needle.
Be careful that the new needle is properly seated before screwing it tight. Otherwise, you might end up with it slightly askew.
Posted on Apr 14, 2014
5 Suggested Answers
sewinsnap
  • 135 Answers
SOURCE: remove needle
Yes, a screwdrive that came in the tool kit.
Posted on Jun 24, 2010
  • 68 Answers
SOURCE: I need information on how to oil my huskylock 905
Oil any and all moving parts with sewing machine oil. If you turn the handwheel, look to see which parts are moving and oil them.
Posted on Feb 25, 2010
  • 11 Answers
SOURCE: user guide Overlocker/serger Husquvarna Viking Huskylock 905
Hey if you need a new manual go to this link www.ifixmachines.com and dont forget to put this code (150t) so you can get $1.50 discount. Hope this help.. By the way the manual cost only $10. BYE
Posted on Jul 24, 2009
  • 92 Answers
SOURCE: How do I remove needles
Use the allen key or screwdriver that came with a the accessory kit. The screws are on the front of the needle bar and are hard to see. Push them up all the way when you change them.
Derek
Posted on Jan 18, 2011
How to fix a broken Needle clamp on viking 936
I don't know of a way to repair the needle clamp. It will more than likely have to be replaced. The local authorized husqvarna viking dealer should be able to service the machine. You can find the nearest dealer from husqvarna viking website - http://www.husqvarnaviking.com/us
Apr 24, 2014 | Husqvarna Huskylock Computerized 936
I have the huskylock 905 and it is running great--but-- the seam easily spreads apart after sewing. I have adjusted all of the tensions in different areas and it looks great until you hold the fabric and...
The left needle thread tension is the problem if the seam can be pulled open. Check the threading and tension on this needle, you may find that the stitch looks okay on the top but on the underside the left needle thread is actually lying against the right needle stitching.
Check the left needle tension device is working, clean it according to the manual instructions, rethread and ensure it is set to the normal number (probably 5), then test again and see if its still happening. If so the tension device is probably faulting and will need a service.
Reading your description again, if the whole seam is pulling apart fully, then all the tensions are too loose. Either way, I'd take it to the Husqvarna dealer for a service, all machines benefit from one at least every 2 years.
May 05, 2011 | Husqvarna Huskylock Computerized 905
How do I remove needles on a Viking Huskylock 905?
Derek
Jan 16, 2011 | Husqvarna Designer I
Hi, I have a huskylock 905 NOT computerized and it's making a "clunking" noise while sewing and then the "D" thread breaks. I've re-threaded many times, changed thread, changed needles, adjusted tention...
Sounds like the D needle is hitting something in the loopers and an adjustment needs to be made. The adjustments are ever so slightly. It could be that the needle bar is twisted causing the D needle to hit. It could be the looper is not within the specs for proper operation, etc. Suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Nov 18, 2009 | Husqvarna Huskylock Computerized 905
I am trying to sew runners together - its too thick for the machine - what should I do? Can I replace with a bigger needle or higher foot? Please help ?
Largest needle I would use is a size 90. There is not a higher foot available. If it's too thick for the machine, it could damage your machine to keep trying. Sorry for not more encouraging news
Oct 16, 2009 | Husqvarna Huskylock Computerized 905
User guide Overlocker/serger Husquvarna Viking Huskylock 905
Jul 24, 2009 | Husqvarna Huskylock Computerized 905
Need to find compatible presser feet for Huskylock 700
Sorry, not familiar with the Huskylock 700. Suggest you visit authorized husqvarna viking dealer. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 28, 2009 | Husqvarna Huskylock Computerized 905
Replacing needle on Elna Pro 905 DCX serger
Try and loosen the screw, and use a magnet to pullout the broken piece. It likely slightly bent in there so you may need a pair of tweezers as well
Jan 23, 2009 | Sewing Machines
Sewing Machines Logo
107 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
