Question about Pool & Spa
Sta rite pool heater
Blower puts out hot air but the light is not on saying heating and the water coming out of the jets is cold
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Sounds like manual bypass is stuck closed letting too much water through system if you cannot check it then if heater has a bypass try closing 1/2 way sounds like water is going through too fast
Posted on Jun 10, 2014
PartsCenter
  • 125 Answers
SOURCE: sta-rite heater Display shows 125 degrees, won't activate heater
sounds like the temp sensor is bad. Sta-rite Heater
Posted on Feb 26, 2009
  • 83 Answers
SOURCE: Sta-rite propane heater turns on, blower on but it doesn't fire
There can be a couple of reasons for this issue to occur. The first thing to check is the dsplay panel for which Service light is coming on. If it is the Service System light, then there is not enough flow of water in the system. You may need to clean your filter.
If it is the Service Heater light, then the problem is with the heater. What you can do is restart the heater and watch the display panel. If the water temp display is too high, or low, then the issue is the Thermister and it will need to be replaced. If the temps are about the same, then try and start the heater. The same issue may happen again, but that is what you actually want to happen. Once this does, take off the top two halves of the heater and turn the display panel over. There are diagnostic lights on the backside of the panel.
If there is a red light next to one of the following: AGS, AFS,
SFS, HLS, PS or THERMISTOR, then that is the item causing the problem with the heater. If you need an Owner's Manual, there is one online at the following link:
http://www.inyopools.com/owners_manual/sta-rite_heaters_max-e-therm.pdf
Posted on Jul 08, 2009
  • 83 Answers
SOURCE: sta-rite gas heater won't ignite
I am not sure if either of these issues have been solved, but with the AGS light on, you will need to check the flow of water first. If it is below what is needed for the heater, this will light up. If the water flow is fine, then check the water temp on the display panel. If it is readin higher than that of the ACTUAL pool water temp, you need to replace the Thermister.
If the water temp displayed is about that of the pool water, then the Automatic Gas Shutoff will be the next thing to check and replace.
You can tell IF a Sta-Rite heater has been converted by the model number. The Convesion Kit is supposed to come with a sticker stating that the heater has been converted, but there are two options for the kit and the one without the sticker is cheaper.
If you take off the top two halves of the heater, on the Junction Box there should be a Tri-fold card there. Unfold it, if the model number ends with NA it is a Natural Gas Heater, LP would be Propane.
Posted on Jul 10, 2009
  • 83 Answers
SOURCE: sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Posted on Jul 14, 2009
  • 246 Answers
SOURCE: I have a Sta-rite gas heater that has the afs and
SORRY YOU HEATER IS GONE THE HEAT EXCHANGER HAS ALEAK THIS IS DUE TO POOR WATER CHEMESTRY ,LOW PH, OR SOMEONE USING TABLETS ON THE SKIMMER THIS DAMAGE THE METALS ON THE HEATER
Posted on Oct 13, 2009
Starite sr400lp runs fine ,no errors however water to pool is not hot or even barely warm
With heater running put your hand by the exhaust and see if the air being expelled is hot. It will be if heater is producing heat. Depending on the size of the pool this heater can take some time to heat the water.
May 11, 2014 | Pool & Spa
Water barely lukewarm
is the heater running ? did u raise the temperature higher that the existing water temperature in pool ? are u running the pool pump long enough to achieve the temperature that you want ? IF CHECK (OK) 1- check the internal flow valve control is located between the cold and hot water little black cap, check the condition ,make sure no calcium deposit build inside, 2-is the water temperature in the heater is the same as the pool temperature ? is the pump got full prime with no air ? is the filter is clean ? is this heater propane or natural gas ?
Jun 12, 2013 | Sta Rite Sta-Rite Max-E-Therm High...
Sta-Rite Max-e-Therm pool heater -- cycling and HLS
make sure that you have adequate water flow going through the heater and that your water chemistry is balanced.
Jan 09, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
Oct 09, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Pool & Spa Logo
37 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
