Question about Freezers
Frigidaire fre196a Evening, neither the fridge or freezer are cooling anything. I can hear liquid going through the pipes, and the pups seem to be doing something, any ideas? Thanks
    Sergeant:
  • 230 Answers
I would check to see if the compressor is running. If it is very hot and not humming then the comp is done for. or very hot and you can feel it running constantly the you have a leak and note enough refrigerant. If you hear it run then click then run then click and if hot the comp is done for and needs to be replaced.
Posted on Apr 13, 2014
Sea Breeze
  • 4654 Answers
SOURCE: Brand New Freezer, won't cool
You did nothing wrong. I believe it was faulty at the time of purchase. Return for refund
Posted on Oct 21, 2007
jaylex
  • 417 Answers
SOURCE: freezer temp display beeping and going through different temps rapidly!
Seems that you may have a faulty temp control switch or it is stuck in position. Check this also make sure that the air vents are clear.
Thanks J
Posted on Feb 16, 2008
SOURCE: Frigidaire Mod FFC05C2AW1 freezer won't cool, hear
please switch off your refrigerator for at least 5 hrs. than again switch it on. if your problem is not cured than it is sure that you have your gas chockage....... please visit your service authority
Posted on May 14, 2009
  • 40 Answers
SOURCE: the fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Posted on Jul 01, 2009
woodchuck789
  • 4059 Answers
SOURCE: Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Posted on Jul 02, 2009
Fridge noise cutting out
To be honest it sounds to me like your fridge may be ok?
To extract the heat from within the fridge interior a compressor (motorised pump) moves gas around a series of pipes around the cabinets insides. This movement of gas causes heat to be picked up and taken away externally to the outside world. When the fridge temperature reaches a predetermined level (around 5C) the compressor shuts down and all is quite. The sound of running water you hear is the coolant gas changing state from gas to liquid and running through the coolant pipes. If the fridge is doing it's job and keeping the content cool then I wouldn't worry. One of the reasons you are probably noticing this sound is because it is a table top fridge. Built in fridges make the same noises but you don't really hear them so much because of the cupboards screening the sound.
Dec 27, 2013 | Igloo Cooler IGLOO Freezer. 3.6 cu. ft....
Freezer cools some to a refirdgerator level, however will not freeze
A few suggestions are 1. Turn down the fridge portion a little and colder air should redirect into the freezer part 2. If it is an older unit sometimes defrost it , unplug it and turn it upside down for a day or so (this moves some of the corrosion inside the pipes). Turn it back up and plug it back in .
Aug 30, 2011 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire upright frostfree freezer keeps icing up, needing to be defrosted. whats wrong with it?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | Frigidaire 20.3 cu. ft. Upright Freezer...
Ice build up in bottom of freezer
heatman101
May 05, 2011 | Frigidaire 13.7 cu. ft. / 388 liter...
Frigidaire FRE196A
you know where you adjust the temperature of your fridge. its a knob with a line that increase in thickness. or it may have numbers written on it. before you replace it. try adjusting that knob to set it to a higher temp. please if your taking the covers off the replace thermostat,, please turn the power off first.
Nov 11, 2009 | Frigidaire Freezers
It quit running and everything thawed. It's got electric going to the dial. plugged it in and can't hear anything running.
The power coming into the fridge goes to the thermostat and when it's time for cooling the thermostat tells the compressor and other components to come on so it has to be the thermostat..Does the light insinde the fridge work? If so i would replace the thermostat and it should fix the problem!!!
Nov 06, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Fridge freezer not cooling
buy a new freezer and never go near it with a screwdriver try unplugging it to remove ice
Mar 12, 2009 | Freezers
Fridge Freezer in Autodefrost mode
Power surge can cause problems such as you have. I am not familiar with your brand but it sounds like the defrost timing circuit is your problem. Defrosting the surface of the back wall is not the answer. The cooling coil in the freezer is behind the back wall normally and a surface defrost does not do the trick of defrosting the coil. Have an appliance service tech check it out for you.
May 30, 2008 | Freezers
Freezers Logo
173 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
