Question about Whirlpool Cabrio WED6400SW Electric Dryer
Wed6400sw0 moisture sensor
Working but no heating
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 144 Answers
It is possible that the heating element is faulty and should be replaced
Posted on May 09, 2014
I have Samsung gas dryer model DV410. no heat, replaced two thermal fuse and hi low limit. Now it only works with timed cycle mode. the rest mode, it runs only for least the 5 minutes and shut off.
timed cycle mean dryer not on sensor dry mode. check wire connection on moisture sensor bars (i think you forget to put 2 wire connector put together). when you use other cycle dryer use moisture sensor to dry cloths so sensor not working dryer will stop in 5 minutes or so because dryer think there are no wet cloths to dry. hope this help you.
May 02, 2017 | Samsung Dryers
Wed6400sw0 change thermistor
You have to remove the back panel no heating could be a bad thermal cut-off hi limit or bad heater if you know how to use a multimeter to read continuity the one that reads open will be the problem a thermal cut-off would indicates a restricted exhaust.
Apr 01, 2014 | Dryers
Wed6400sw0 sensor replace
you can find the answer on google and type in the question. they many videos on repairing washing machines.
Apr 01, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
My camcorder cassette did not close instead it display dew
The dew sensor of the player detects some moisture as the sensor activates the processor to cut off the control to the servo. so unless the moisture or condensation on the HEAD DRUM is removed as when the set is switched on and the small heater on the drum works it will be cleared.
you can use a hair dryer into the inner tray section- drum - and heat up a bit . now switch on and see if the fault clears.
Do not over heat but even if the set is kept on for a while it will clear.-- a safety from tape entangling if moisture is present.
Aug 09, 2011 | Sharp Viewcam VL-Z3U Mini DV Digital...
My dryer will not heat. does this have anything to do with the moisture sensor. Where is this sensor located ?
No, the moisture sensor only senses the wetness of the clothes and the computer determines how long it will take to dry the clothes. The no heat situation is one of 3 problems. No gas situation, high limit switch has tripped or motor contact switches broken. You will need a professional LG technician to diagnose the problem for you.
Good luck
Oct 01, 2010 | LG DLG7188 Gas Dryer
Whirlpool Cabrio will not heat up....
there is usually a wire diagram inside the rear panel near the timer.
Jul 24, 2009 | Whirlpool Dryers
It heats, but won't shut off when using the moisture sensor
The moisture sensor is shot and needs replacing It works till it sees dry air going past it (As set by the maker)if it thinks the air is still moist it will keep on trying to dry it. Call out a repairman or buy a sensor and fit it yourself
Jun 07, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Moisture sensor does not seem to work
your heating element may be bad if your cycle completely finishes and the clothes aren't dry. If
Jan 28, 2009 | Dryers
Moisture Sensor Location
It could be the sensor. However, check the exhaust vent for restrictions first. you can test the moisture sensor Damp Dry Test 1. Set the following Timer- DAMP DRY Fabric Care/Temperature switch- COTTON HIGH Wrinkle Guard switch- OFF Signal switch- LOUD Door- must be closed 2. Press the PUSH TO START switch. After approximately 16 seconds, the Timer will start to advance to the OFF position, and the ?End of Cycle? signal will sound. If one or more of these functions do not occur, proceed to the Factory Test. Factory Test The Factory Test allows factory/service personnel to test and verify all inputs to the Even Heat control. The basic operation of this test is to notify the operator with an audible beep every time the status of an input to the control changes state. Activating the Test Mode 1. Set the following configuration: Door- must be open Fabric Care/Temperature switch- AIR FLUFF Signal switch- LOUD Timer- TIMED DRY OR AUTO MOISTURE SESING PLUS selection 2. Turn the Wrinkle Guard switch from OFF to ON three times within a five second period. A single beep will sound to indicate that the factory test mode is activated. NOTE: If any of these initial conditions are not satisfied, the control will not enter the test mode. Test Mode Functionality When the control is in the Factory Test mode, every input change of state will result in a beep (with the exception of the Signal switch). This includes: Door switch Moisture Sensor (short/open Sensor will result in a beep) NOTE: A moistened finger or damp cloth may also be used. Fabric Care/ Temperature switch Wrinkle Guard switch Push to Start (PTS) switch (with the door switch closed) Timer (any cam input change will result in a beep) NOTE: Timer will advance during test. If any of the inputs do not result in a beep, proceed to the following component tests If the dryer shuts off too soon when set to the AUTO MOISTURE SENSING PLUS cycle, check the following: -HARNESS/CONNECTION -MOISTURE SENSOR -THERMISTOR -EVEN HEAT CONTROL Procedure: 1. Test the Moisture Sensor by following the procedure outlined in ?Factory Test?, beginning on page 3. If the Moisture sensor fails the ?Factory Test? (does not produce a beep sound), check the Moisture Sensor. a. If there is continuity to Ground for Yellow/Red (Y/R) wire with no load, look for a short in the Sensor or Y/R wire. Verify harness connections both at the Sensor and the Even Heat control. b. If the Sensor and Y/R wire are good, replace the Even Heat control. 2. If Factory Test passed, verify thermistor by performing test procedures outlined in ?Thermistor Test? 3. If problem persists after replacing Moisture Sensor and thermistor
Aug 27, 2007 | Kenmore 62972 Electric Dryer
Whirlpool Cabrio WED6400SW Electric Dryer Logo
94 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
