Question about Kitchen Ranges
Kenmore Gas Range Burner screws stripped -Help!
Model #790.75715893- I was trying to remove the top cover of the stove which requires the removal of 3 screws around each burner that secures the burner to the cook top. Some of the screws were already missing, and regretfully I tried to remove the screws from the 2 burners that only had one screw holding them in place. Now these 2 burners aren't secured to cook top and won't ignite. I can't figure out any way to secure the burners to the cook top and can't put new screws in because the base of the old screws are still threaded in place. Any suggestions???
  • lucyfoot Apr 01, 2014
    by stripping I mean the heads of the screws snapped off.
  • 38 Answers
Hello-
I am not familiar wit this stove, but in general, you can try to drill out the screws with a power drill. If you feel comfortable doing this, you need a punch or awl, hammer and a power drill with a sharp THIN drill bit. Using the punch and hammer, put the punch directly in the center of the broken screw base and begin to hit the punch (gently at first) in order to put a pin point indentation into the remaining part of the screw. Do this multiple times as needed. The idea is to make a indentation in the screw where you can set the drill bit and begin to drill out the screw remnants. If you do not do this, the spinning drill bit will wander around the screw hole and potentially cause damage. Press down while drilling. Use either a variable speed drill to slowly begin the process or use short bursts of the drill's on switch until you can drill out the broken screw. If done correctly, you will see as you drill through that the screw's threads will eventually come out and should not damage the thread in the hole. Use can use new screws ordered from Sears or take one of the remaining good screws to the hardware store to seek replacements. Use the new screws to secure the burners into the stove.
Hope this helps!
Posted on Apr 02, 2014
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
SOURCE: Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Posted on Sep 05, 2009
SOURCE: Seized screws in Stoves 'Range 1000G Gas Range Cooker (LPG)
I let the screws soak for a few days in release oil but with no success. I decided the only way to get the seized screws out was to drill and tap new holes through the hob and into the hob burner mixing tube support flanges. This allowed new screws (stainless as opposed to the standard, chrome plated steel screws) to be screwed into place. Once this was done I then drilled out the heads of the remaining seized screws. This allowed the hob tops to be removed so that the oven thermostats could be changed. The hob screws were then screwed back into place and lubricated with loads of high temp. copper grease to prevent corrosion. I will also remove and re-grease these screws every six months or so to prevent any chance of seizure in future!
A few points to remember: (a) make sure that any holes in the hob top are sealed with something such as a screw coated with high temp fire cement etc. to prevent any possibility of unburnt LPG getting into the space below the hob top. (b) make SURE that you do not drill or tap into anything that could damage the cooker and cause a gas leak or damage any of the gas ignition leads etc. (c) Make sure that the appliance is totally 'gas tight' after doing any work which will disturb the gas connections, and (d) If you don't have gas qualifications and are not sure of what you are doing then get an expert, registered gas engineer to do the work for you. Don't take a chance with gas!!
Posted on Oct 08, 2009
jsrock516
  • 5911 Answers
SOURCE: Opening the cook top in a Whirlpool electric range
The cooktop on this model range will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the frotn edge of the cooktop. You will need to open the oven door to see them. Just follow these steps:
Before you begin:
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the bad surface element by removing only the bracket pair that the affected element is attached to. Leave the rest of the elements wired together. Write down the wire color codes so you can be sure the new element is installed correctly. HINT: A digital camera can save you some time.
d. When installing the new surface element, make sure you use the same alignment marks (the numbered positions around the perimeter) as the old element. Avoid touching the burner surface and handle with care. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. The elements are fragile.
If the wiring harness does NOT unplug, prop the cook top in place and install the surface element from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
If you have any questions about this repair, please let me know. You can reference searspartdirect.com for some helpful exploded view diagrams of you range for assistance if you need it. I hope you find this information helpful.
Posted on Nov 12, 2009
Testimonial: "Did not update until late, thanks for the detailed directions. No hinges on my stovetop, just detach and remove. Thanks, again!"
My kenmore glass top stove has one burner that isn't working help
Having the model number would be nice, but you are going to have to remove the top and check the burner element to see if it went bad. To remove the top, unplug it, open the door. Look for screws under the lip where the door closes, check the back for screws, lift the top off,
Sep 19, 2016 | Kenmore Kitchen Ranges
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Can the cooktop surface of my Kenmore gas range model 790.72903011 be removed
Most stove tops are removable for that very purpose.... after you remove the burners and the grills above the burners.... look for an edge and inch or inch and a half below the top... get something strong like a large screwdriver and place cloth over the tip to prevent scratching the stove top. there are VERY STRONG CLIPS holding the stove top to the stove, pry upward until the clips release. then slowly remove the spark igniter (TAKE A PICTURE WITH YOUR CELL TO REMEMBER HOW PUT BACK TOGETHER)
Jul 30, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Right, front flat burner does not light and barely heats. My Hotpoint stove is five years old and gets very little use. What's wrong? Can I fix it? Can you help?
Hello and Welcome to FixYa!
Please provide us with the model details of your unit and What exactly, you are facing. Is the burner properly getting the supply. And is it partially lighting or didn't lighting at all. Is the unit repaired ever since the problem started? Some details of the trouble, you are facing, will help suggesting more precise solutions to the problem,
Feel free to Ask,
Concerned.
Jul 15, 2011 | Hotpoint Kitchen Ranges
How do I access a spark ignitor on a Viking gas
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by a 'tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and would cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range. Of course you need to ensure it is the correct one for your stove. The ignitor you remove should have a manufacturer part number on it. No calibration required on mine - a sealed electronic unit. Probably about 10 wires that need to be R&R'ed - they are on with reuseable fasteners.
Jan 18, 2010 | Stoves 600SiDOm Gas Kitchen Range
How to install ignitors on Viking Range
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by an 'come to my home tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range
Sep 07, 2009 | Viking VGIC485-6G Gas Kitchen Range
How do you open the stove lid of a Kenmore 7907138 five burner gas range? I need to clean it.
You need to be careful with sealed burner ranges. If you try to lift the range top you can damage the alluminum gas pipes for the burners under the range top. Check to see if the burner heads lift off. If the burner heads are held on by screws make sure you remove those first. With the heads removed look down into the cooktop thru the hole where the burner sits. Make sure the orfice is not attached to the lid. If they are you may see a screw you can remove. Look for any other screws behind the oven door that may be attached to the lid. Apply light pressure when trying to lift the lid. If you feel any major resistence DO NOT FORCE IT UP. Sears.com also has parts schematics for every range they make and that will visually help with the dis-assembly because you can see how the parts go together. Also MAKE SURE YOU UNPLUG THE APPLIANCE AND TURN OFF THE GAS VALVE BEFORE WORKING ON IT!!!
Sep 05, 2009 | Kenmore Kitchen Ranges
We have a Kenmore model #790.96011407 range with smooth top. It was working fine until recently one, then the other, front burner started operating on their own. They will not turn off when you turn the...
If this is happening on more than one burner the command module may be bad, small cicuit board inside control panel. With power disconnected easy replacement. check wiring to each burner control 1st by removing control panel cover. Be careful to remove small screws on either side of panel between panel & burner.
Jun 27, 2009 | Kenmore 96012 / 96014 / 96019 Electric...
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Kenmore gas range
hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
Nov 06, 2008 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
Kitchen Ranges Logo
117 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
