Question about IBM Wheelwriter 3 Series Ii Typewriter This Machine Is Gorgeous For Anyone
Striker does not hit ribbon or platten, just stays still when key is hit
Just stopped working, have tried everything
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
You probably have a broken solenoid and may just need a "cap" repair kit. There are some companies that sell the kit with instructions.
Posted on Feb 24, 2015
4 Suggested Answers
  • 3594 Answers
SOURCE: Striker hits the ribbon but it will not print.
If you are sure the hammer is hitting the printwheel and platen (try printing on a multi part form if the carbons print the ribbon is probably not lifting, wiggle the big black gear on the right side of the printer. If it doden't print the print solenoid cap is probably broken.
We sell the cap with instructions and shipping for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Posted on Aug 21, 2009
  • 3594 Answers
SOURCE: IBM wheelwriter 6 turns on and everything
The print solenoid cap is probably broken. We sell them with instructions and shipping for 20.00
DickyO
216-242-0027
Posted on Jan 18, 2010
  • 3594 Answers
SOURCE: Wheelwriter 6 -- Won't print.
Most likely the Plastic print solenoid cap is broken. We sell them for 20.00 includes shipping and instructions.
DickyO
216-241-0027
Posted on Sep 23, 2010
I have a templeton regulator wall clock with pendulum. Everything works fine except the striker does not hit the bell--is it ok to bend the striker?
Yes, carefully though without placing any strain on the mechanism.
When in the correct position the striker hits the bell and then returns to a position clear of the bell - it should not rest on the bell.
Apr 27, 2018 | Home
I have a manual desktop circa 1940s royal typewriter. Bought it from a professional online who claimed it worked, everything looks good but the carriage and ribbon will not move. Tried messing with the...
most royal portables have a locking lever to lock the carriage in the center position try looking on the right side near the lower edge of the carriage
Nov 16, 2014 | Office Equipment & Supplies
IBM Wheelwriter 6 Typewriter - while typing, characters just quit printing on paper. Checked ribbon, machine etc. Everything checked out?? What could be the problem.
It is probably the print solenoid that has a broken cap. I have seen a few advertisers that sell the repair kit with instructions. It is fairly simple to repair.
Jan 02, 2014 | IBM Wheelwriter 6 Typewriter
I am trying to revive an IBM selectric 6746 wheelwriter to complete some statutory Govt forms that do not have softcopy. It worked perfectly for a while then suddenly stopped printing. All motors seem to...
There is a solenoid that hits the hammer when a key is pressed. There is a plastic spacer on the solenoid plunger that falls apart and keeps the plunger from hitting the hammer. Therefore it looks and sounds like it is working but no letters appear on the paper. Try to find a typewriter repairman to fix it. It is a common problem on wheelwriters so any repairman should know what part is needed.
Jun 16, 2010 | Office Equipment & Supplies
Alas! My Brother GX 6750 got a new ribbon and won't produce words
Common problem: Ribbon is old or is mis-threaded.
Another problem is the distance fom the wheel to the platten or the setting of the hammer. Some have setting for which to use forms rather than plain paper. The hammer is set back for this and there is an adjuster lever either in the vicinity of the hammer or for platten spacing.
Sep 01, 2009 | Brother GX-6750 Typewriter
Striker hits the ribbon but it will not print. Replaced the ribbon but it did not help.
DickyO
216-241-0027
Aug 21, 2009 | IBM Wheelwriter 30 Typewriter
Striker Sticking When Erasing. Brother ML100 Typewriter
Sounds like the gears you cleaned may be dry and sticking, spray a little WD40. or that gear on the right side is still out of time. I think there is a spring clutch in the gear train which may be bad. One secret to repairs is to perform the same actions that you want the typewriter to do by hand and watch closely. You may see something not movving, or moving slow that under power you won't see.
Aug 14, 2008 | Brother ML-100 Typewriter
Almost Fixed. Stricker works, but sticking
This part yu take off, the pin goes into a slot that goes around inside a cam. If you have that pin not in the slot you will get this lock up. Try taking the part you mentioned out or remove wht is called the ribbon plate, which is the part where the ribbon sets on, then turn the machine on or wind the printer motor by hand to home out or bring the printing unit to the home or start position, turn off and very carefully install the parts you tokk off making sure the pin in the ribbon lift (The small part yout ook off on the right side of the printer) is in the correct cam track or small track or canal. Once installed you can rotate the motor by hand an see if it moves freely. GOOD LUCK
Aug 06, 2008 | Brother ML-100 Typewriter
Striker Not Working. New Problem, now.
One very important thing with Brothers typewriter, If the keyboard is not locked in place under the catches, it will not complete the home cycle. In other words when the carriage returns to the left it will cycle and then beep usually continually. The reason the carriage stop time switch is attaced to the keyboard not the side frame. You might look at that....Could be other problems too. keep in touch
Aug 05, 2008 | Brother ML-100 Typewriter
KEY STRIKING PRESSURE
Try taking the ribbon out and looking at it see if there is one spot for each character on the ribbon or if they are overlapping.If they are over lapping then either you have a problem with the ribbon drive assembly on the machine or it is set for a multi-strike ribbon.
Nov 13, 2007 | Lexmark Wheelwriter 15 Series II...
IBM Wheelwriter 3 Series Ii Typewriter This Machine Is Gorgeous For Anyone Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
