Question about Whirlpool Cabrio WED6400SW Electric Dryer
Wed6400sw0 sensor replace
How to change a sensor
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
You can find the answer on google and type in the question. they many videos on repairing washing machines.
Posted on Apr 01, 2014
Wed6400sw0 change thermistor
You have to remove the back panel no heating could be a bad thermal cut-off hi limit or bad heater if you know how to use a multimeter to read continuity the one that reads open will be the problem a thermal cut-off would indicates a restricted exhaust.
Apr 01, 2014 | Dryers
Wed6400sw0 moisture sensor
It is possible that the heating element is faulty and should be replaced
Apr 01, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
I changed out the MAP sensor,and the idle air sensor on my 2006 Ford Taurus. This was before I had the fault code read at a dealer. Code came back as P0340, and P0430 Band 2 cat worn out. I had the cam...
P0340 FORD - Camshaft Position Sensor Circuit Bank 1 Sensor 1Possible causes- Faulty Camshaft Position Sensor
- Camshaft Position Sensor harness is open or shorted
- Camshaft Position Sensor circuit poor electrical connection
- Faulty starter motor
- Starting system circuit
- Dead (Weak) battery
P0340 FORD Description The Camshaft Position Sensor is an electronic device used in an engine to record the rate at which the camshaft is spinning. This information is used by the Engine Control Module(ECM) to control ignition and fuel injection. The camshaft position sensor senses the retraction of camshaft (intake) to identify a particular cylinder. The camshaft position sensor senses the piston position. The sensor system consists of a rotating part, typically a disc, as well as a static part, the actual sensor.
When the engine is running, the high and low parts of the teeth cause the gap with the sensor to change. The changing gap causes the magnetic field near the sensor to change. The change in the magnetic field cause the voltage from the sensor to change.
When the crankshaft position sensor (POS) system becomes inoperative, the camshaft position sensor provides various controls of engine parts instead, utilizing timing of cylinder identification signals.
P0430, main catalyst is worn out.
Dec 04, 2012 | 2006 Ford Taurus
Whirlpool cabrio dryer wed6400sw0 idler pulley replacement
there's a hole on the pulley arm, connect the spring there kind of under the plastic pulley and then it connects on the floor or on the motor case on the opposite side of where the pulley arm bolts into go here and look at picture hope this helps you out
https://www.searspartsdirect.com/model-number/WED6400SW0/1198/0151200.html?searchType=modelSearch&q=wed6400sw0&searchTerm=wed6400sw0
Oct 12, 2017 | Whirlpool Dryers
Replace brake pad light on, how do you reset it?
you need to replace the pad wear sensor when the pad wears down it wears the sensor and the sensor needs to be replace if you look at the sensor you can see the wire on the sensor wears threw
May 19, 2012 | 2009 Audi Q7
My Hyundai Santa Fe 2004 doesn't shift down from overdrive when driving at 70 mph. Recently replaced the crankshaft sensor and timing belt. It is an automatic and the other gears seem to shift alright....
You might try testing the tps. It may have a dead spot at the high end of the throttle opening. Make sure the resistance continues to change as you open the throttle all the way.
Throttle Position Sensor
Operation The throttle position sensor is a rotating type variable resistor that rotates with the throttle body-s throttle shaft to sense the throttle valve angle. As the throttle shaft rotates, the throttle angle of the sensor changes and the ECM/PCM detects the throttle valve opening based on the TPS output voltage.
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Disconnect the sensor connector.
  3. Remove the sensor retaining screws. Remove the sensor from its mounting.
To install:
  1. Installation is the reverse of the removal procedure.
Testing 2.4L Engine
  1. Disconnect the sensor connector.
  2. Measure the resistance between terminal 1 (sensor ground) and terminal 2 (sensor power).
  3. Specification should be 3.5-6.5 kohm.
  4. Connect and analog ohmmeter between terminal 1 (sensor ground) and terminal 3 (sensor output).
  5. Operate the throttle valve slowly from the idle position to the full open position, and check that the resistance changes smoothly in proportion with the throttle valve opening angle.
  6. If the resistance is out of specification, or fails to change smoothly, replace the sensor.
2.7L Engine
  2. Measure the resistance between terminal 2 (sensor ground) and terminal 1 (sensor power).
  4. Connect and analog ohmmeter between terminal 2 (sensor ground) and terminal 3 (sensor output).
  3. Specification should be 1.6-2.4 kohm.
3.5L Engine
  2. Measure the resistance between terminal 3 (sensor ground) and terminal 1 (sensor power).
  4. Connect and analog ohmmeter between terminal 3 (sensor ground) and terminal 2 (sensor output).
Sep 24, 2017 | 2004 Hyundai Santa Fe
Whirlpool Cabrio will not heat up....
there is usually a wire diagram inside the rear panel near the timer.
Jul 24, 2009 | Whirlpool Dryers
2004 Sequoia. VSC TRAC, TRAC OFF, and Check
It is not hard to change the sensor, it just screws into a threaded hole. The light will not go out immeditaly, after the sensor is replaced. It needs to go thru a drive cycle. Your best bet is to replace the sensor and get the code cleard by whoever scanned it for the 0031 code.
Jul 23, 2009 | 2004 Toyota Sequoia
CMP (camshaft position sensor) "chirps" noisely when engine is cold. Will changing the sensor fix this or will the CMP drive assy. also have to be replaced/repaired?
I would change the whole assembly... My 97 came on with the light and I replaced the assy with one from a totalled one but I did have to get a new sensor (Sensors and electronic components for reporting are always better to replace new).
Jun 11, 2009 | 2001 Ford Taurus
Aman biult in oven
F2 is Oven sensor is out of range .. oven sensor is sending a reading that the control can not understand... replace oven sensor and you may have to replace the control too as it may not be reading correctly... good luck and let me know if it helps
Jan 02, 2008 | Amana AOCS3040 Electric Single Oven
Whirlpool Cabrio WED6400SW Electric Dryer Logo
65 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
