Question about Olympus Office Equipment & Supplies
Getting the encoder to work with B-scan on the 38dl plus
Cant get encoder to start with b-scan
  • JAY DEVINE
    JAY DEVINE Apr 02, 2014
    Its a Olympus 38 DL PLus UT set not a printer!
Designjet 500 plus 42" issues
System error 56:10 Explanation
Drive roller encoder sensor error.
Recommended action
Turn the printer off and allow a few minutes for printer to cool. Turn the printer on and attempt to verify functionality.
If the problem persists, click on Support at the top of the page for additional HP support and contact options.
top
System error 56:13 Explanation
An error in the drive roller encoder sensor quadrature has occurred.
Recommended action
top
Jul 27, 2015 | Office Equipment & Supplies
Persistent Error 86:01
Oh my throw it away, too much you have tinkered with its not worth the headache
Sep 01, 2014 | HP Designjet Z6100 InkJet Printer
Error 86:01
did you perform a scan axis calibration after changing all these parts? If not then you should do that before doing anything else.
Hp designjet z6100 42:10
error code 42:10
Electrical fault in Carriage Motor or starting the Scan Axis or Homing Scan Axis.:
it is not uncommon to find that the encoder is the fault behind the error code,
in the User manual there is a procedure for Cleaning The Encoder Strip. you should follow these steps carefully
.A Z6100 User manaul is available to download at HP.com link as follows:-
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?cc=us&contentType=SupportManual&prodSeriesId=3338748
the user manual is located near the bottom of the page
Sep 25, 2013 | HP Designjet Z6100 InkJet Printer
Clarify: #Error appearing immediately with sudden ****? or while carriage parking in serve station area?# remove & take out service station, place it out side(to avoid capping/wiping by cleaners)..check
# check carriage bushing warn out condition( too much play of carriage causes this error)
# trailing cable flexibility good? or its obstructing the carriage path?
# take out cutter assembly from rail.. check..
# Check carriage belt tension, adjust if required.
# Check carriage belt properly installed? re-install again
Best of luck....
Jul 24, 2012 | HP Designjet Z6100 InkJet Printer
Will not save to dvd after appearing to render after several hrs
u shoul use dvd+r on pinnacle it works the best, un install the program, run a registry repair program to remove any old pinnacle stuff still installed then reinstall, make sure you have all the newest drivers for you hardware, and windows updates, dont install any codecs until you tried the program, exp, dont instal dvix or any other program that u use to whatch pirate movies with, it should work
Oct 08, 2009 | Pinnacle Systems Targa 2000 RTX - Video...
Cant read disc
Try checking the scan and pickup heads of the DVD with a DVD cleaning disk . If this does not help the optics or the decoder/encoder might be defective. In that case, you will need a qualified TV repair person to work on these units for you all.
I hope this helps
Thank you,
Shuttle83
May 19, 2008 | Panasonic DMR-E55 DVD Recorder
Printer message: Unable to Print
5A: encoder disc or encoder strip or main circuit board or printhead circuit board or power supply defective!
Sorry, cant be fixed by yourself!
Feb 20, 2008 | Brother MFC-440CN InkJet Printer
Printer problem
You'll need to clean the encoder strip, encoder wheel, paper feed rollers and the carriage rod (where the cartridges ride -plus lube this) and cartridge service station. If you can't figure out how to do this, you'll need a tech that knows how. It will get pretty involved and I would recommend getting a new machine because they have come down in price and you could replace this for very little.
Jul 27, 2007 | HP DeskJet 722c InkJet Printer
48 people viewed this question
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
