Question about Tools & Hardware - Others
Coleman Evcon DGAT070BDF
Blower will not shut off, digital thermostat set at Auto, also lowered temperature setting to see if this would stop blower from going off, did not help
Does the fan switch turn it on/off?
Posted on Aug 22, 2014
  • 582 Answers
SOURCE: I have a Trane Xe-60 furnace about 19 years old.
THIS IS A COMMON PROBLEM WITH THE DOOR SWITCHES, MY FIRST ANSWER WOULD BE REPLACE THE SWITCH SECOND WOULD BE OPEN THE DOOR AND PUSH THE BUTTON IN AND SEE IF THE FURNACE WILL WORK. THIS SWITCH IS JUST A DOOR SAFTEY IF THIS WORKS. I HAVE TAPED A PIECE ON THE INSIDE OF THE DOOR WHERE THE SWITCH WILL HIT THE DOOR ABOUT A 1/4 INCH THICK AND SEE IF THIS WILL GET YOU RUNNING UNTILL YOU CAN GET A SWITCH
Posted on Oct 12, 2009
  • 221 Answers
SOURCE: COLEMAN EVCON FURNACE .. The draft fan keeps
Make sure the Thermostat fan switch is in the "auto" position.
Posted on Dec 31, 2009
  • 105 Answers
SOURCE: My furnace is in a 1994 manufactured home. It is
i think it is your fan because when it is supposed to come on (when hood is hot enough) it won't,...and when the gas valve doesn't get the o.k. from the fan that it is working, the unit will shut it self off so it doesn't over heat. Gas boilers and furnaces have alot of safety things like this,....see if the fan has an oiling place on it. I've seen control panels cause this too,....replace whatever is cheapest first. good luck
Posted on Jan 31, 2010
Testimonial: "Thank you very much for your response. That makes sense and narrows it down. I will keep an eye on it. The fan motor when running is quiet & smooth"
  • 2514 Answers
SOURCE: coleman evcon four flashes on indicator...fans work... won't fire
Hi it could be the pressure switch clean the back of the fan control sensor, and the flame sencer
Posted on Mar 04, 2010
SOURCE: My coleman oil furnace blower keeps coming on for
that furnace has bye snap ringchange that
Posted on Feb 07, 2011
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
Coleman evcon model DGAT070BDF
Open hi temp limit switch or fan limit bad
Apr 01, 2014 | Coleman Propane Forced Air Heater...
Coleman Evcon furnace. Can i make it circulate air?
Your thermostat should have a "continuous blower" setting. Use that instead of fooling around with the A/C setting
Jul 17, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Air conditioning runs all the time
I assume this is a manufactured home, this is probably a two transformer system, either your contactor is welded in the on positon or wyou have control wiring issues, (could be the thermostat)
Jul 12, 2009 | Coleman Heating & Cooling
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Continuos running blower
hi! there,
blower auto shutting off and on is dependent to thermostat setting,if the thermostat acquired the temperature set it will shut of your blower,checking thermostat performance switch off unit, set this to a lower setting 1 or 0 switch on this should not runof course,if you set up this to 200 this will run until temperature reached to 200 it will stop.when you set up to 1 or 0 and the blower run thermostat is defective.
fan blower relay, if the 3 contactor is short or permanently engage while themostat reached acquired temperature your blower will still running,defenitely relay is defective.relay is dependent to thermostat switching,it supply holding coil terminal is to lock the 3 contactor to supply source to your blower.
so two common option while your blower run continously
1. shut off breaker, disconnect thermostat on two leads,its like a switch.then switch on breaker and run unit.
observe if run, your relay is defective,it was shorted on 3 contactor.
thermostat is the key to run your blower.
2. if the blower not run when you switchn onunit,then switch off again and try to short or connect the two lead using alligator clip on both side,or have it clip the terminals,then switch on again if the blower run,your themostat is defective,the high volatile of filler bulb was leak it always switch on,no play at all to off and on.
have a nice day,don't forget to rate me,thank's
ideas came from actual and theoritical analysis base on experienced and my study of industrial intrumentation.this will guide you and help you,if you understant flow of current in circuit.
have a nice day
Apr 11, 2009 | Ruud UBHC Air Conditioner
Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Dec 19, 2007 | Coleman Propane Forced Air Heater...
Tools & Hardware - Others Logo
41 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
