Question about Dell Inspiron 1525 Laptop Midnight Blue
Have a inspiron i15RV-1333 x 3 months. when I oush power button get black screen. can see mouse cursor only. what can I do ?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Contact Dell Support. You might still have a warranty.
Posted on Apr 01, 2014
  • 16 Answers
SOURCE: Black screen with mouse pointer after lcd screen repair
If you can see a mouse pointer clearly, you have a software issue especally if see a post..
Posted on Apr 20, 2009
aouate3
  • 123 Answers
SOURCE: Black Screen
its either your inverter or ccfl backlight tube that is out
here is a tip, if you ever buy a new laptop, try to get one with led backlight technology, they last a lot longer and are more durable
Posted on Jun 14, 2009
scott4169336
  • 103 Answers
SOURCE: dell inspiron 1000 never boots up, screen black
go into bios and fix boot menu
Posted on Dec 06, 2009
cabanagj43
  • 225 Answers
SOURCE: my dell inspiron 1525 has a black screen with a white cursor
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
Posted on Dec 10, 2009
n5kb
  • 349 Answers
SOURCE: Black screen on Inspiron 1525
This is a common problem. The problem is probably a bad charger. Take charger to a repair shop and ask them to check it. If it is good then problem is inside the laptop and probably the power connector.
Please rate this answer as a rating is all we get for answers. Thanks
Posted on Apr 11, 2010
Trackpad jumping around
Go to control panel and then go to mouse setting to reduce the mouse speed. If the problem still persist then you may can download and re install the fresh drive.
Oct 02, 2013 | Dell Inspiron i15RV-3763BLK Notebook...
Black screen with blinking cursor upon start up
You don't say what Windows are you using.
Anyways, it seems like you have a corrupted BOOT problem.
On Windows Vista and Windows 7, you can insert your Windows installation CD, and choose the "Repair my pc" option.
Windows will do it automatically fro you, and you'll be up and running in a couple of minutes.
Dont forget to rate this answer if it helps.
Jul 18, 2010 | Dell Inspiron 531s Desktop Computer
Apr 11, 2010 | Dell Inspiron 1525 Laptop
Turn on computer and I get a black screen with the cursor up in the left corner
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button.
Feb 27, 2010 | Dell Inspiron 6000 Notebook
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Will not boot up!
Windows has probably become corrupted,,,try using you restore cd,,,or starting in safe mode.
Dec 23, 2008 | Dell Inspiron 1200 14.1 XGA LCD...
Dell Inspiron 1525 Laptop Midnight Blue  Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
