Question about Brother XL-2600I
Top thread stuck near bobbin
My bobbin is wound properly, and I have rethreaded several times. The top thread becomes stuck on the silver piece in front of the shuttle when I try to pull up the bobbin thread.
    New Friend:
I just had the same problem with my Brother xl 2600i.
  • Upon close inspection, I noticed and felt a tiny bur on the silver piece right where the thread was sticking.
  • I filed it smooth with an emery board.
Still not as smooth as it was before, but at least now it works.
Posted on May 19, 2016
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
I youtube a solution. They have information on the problem you are having. type..
Top thread stuck near bobbin. on youtube.
Posted on Apr 01, 2014
4 Suggested Answers
  • 399 Answers
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
Posted on Sep 19, 2008
SOURCE: The top thread keeps breaking. The thread pulls
try a tension a 3 to 5 on the top tension
try changing to a needle or if it's a new needle make sure the flat side of the needle faces the back of the machine and pushed all the way up into the needle holder
make sure the needle & thread are correct for each other, if the needle is to thin or to heavy for the fabric it will not work
Posted on Aug 27, 2011
  • 12 Answers
SOURCE: Thread not catching
Got 14 of those machines used industrially, never seen one of those with timing problems from straps or loose straps. Most often it comes from ruined needle bar assembly.
Check if the needle bar is perfectly tight. If not, bring the machine to a technician. The assembly cost about $25 and service should be around $70.
Posted on Jul 07, 2012
What to do if sewing machine is puckering?
Depends on why the seam is puckering. Read this: http://www.amefird.com/wp-content/uploads/2010/01/Minimizing-Seam-Puckering-2-5-10.pdf
Offhand, it sounds like you need to reset the top tension properly.
http://quilting.about.com/od/piecingtechniques/a/How-to-Adjust-Sewing-Machine-Tension.htm
The top two photos here are the upper and underside of a single ply of muslin sewn with a balanced tension. The blue thread is on top, red in the bobbin: http://www.picturetrail.com/sfx/album/view/22521551 -- that will give you something to shoot for.
Jun 12, 2014 | Kenmore 19233 Computerized Sewing Machine
As you sew thread bunches up in bobbin compartment
Generally, you need to rethread your machine on top. You should probably take the bobbin out and see if it is wound properly. You should change the needle too.
Apr 22, 2014 | Husqvarna Sewing Machines
Bobbin case looks stuck
Take it to a repair shop and let them diagnose it and fix
Oct 02, 2017 | Janome Sewing Machines
When sowing the thread bunches up in a ball. The inner rotary make noise, how to correct problem?
first change the needle
clean under the needle plate where the feed dogs are for lint
also clean the bobbin area for lint or loose threads
rethread the machine-top thread & bobbin
some time the top thread can come off some thread take up levers--that should be watched when sewing
check to make sure the bobbin is always wound correctly--and incorrect wound bobbin can cause sewing problems
Nov 17, 2010 | White Sewing W3300 Computerized Sewing...
When I sew, the topstitch looks fine but when I turn it over, there are large loops of thread?
also clean in the bobbin area for lint or loose threads
also check the top thread tension--try 3 or 4
rethread the machine top thread & bobbin
make sure the bobbin is wound correctly- if it's not wound correctly it will cause sewing problems
also change the needle
Nov 17, 2010 | White Sewing 1418 Mechanical Sewing...
My machine is not picking up the stitches. I have rethreaded, checked needle and tension.
try these suggestions
Not picking up thread can be several issues
1.bobbin is miss wound
2. bobbin case isn't snapped in properly
3. you're using the wrong type bobbin
4. needle is bent or burred
5. check bobbin area for lint & loose threads
6. little oil--check operation manual for this
7.machine is out of time --done by service tech
8.check automatic thread cutter to see if it’s bent
but most of the time the issue is once again mis-threading or the thread coming off take up lever
sewing machine needles put in incorrectly
Check & make sure needle is in the needle holder correctly.
Check your manual for threading diagram
check bobbin area including case for lint & loose threads
Take the needle plate off & clean under neath it ( if your machine has screws that hold the needle plate on be careful NOT TO DAMAGE THE SCREWS) because a damaged screw that has a burr on it can pull fabric
Each time you start to sew
1.make sure there’s 2 to 3 inches of top thread when you put the needle down for the bobbin thread
2.make sure there is a 2 to 3 inch of bobbin thread so the top thread can pick it up
3.Pull the tail of the top and bobbin thread behind the presser foot
hope these help--please rate this with the thumbs in the upper right hand corner-thank you
Aug 06, 2010 | Sewing Machines
Needle severs thread each time I start sewing
Take the thread completely off the top of the machine. Put in a new needle. Remove the bobbin. When you rethread the top of the machine make sure the presser foot (that rests on the fabric) is in the "UP" position and rethread the top. Also when you thread the top, put some "pull" on the thread as you thread it, don't just lay the thread in the tracks. You need to pull the thread with some taughtness through the machine so it gets into the correct places under the covers so you have good tension and good stitching. Then put the bobbin back in and make sure when you thread the bobbin case that the thread "clicks" slightly as you pull the thread into the metal tension area of the black bobbin case. Anytime a sewing machine breaks thread at the needle, you should unthread the entire top and rethread it because the thread can jump out of it's guides that are under the plastic covers and you won't be able to see it, but you will see very ugly stitching!!!
Nov 19, 2009 | Husqvarna Sewing Machines
Brother XL-5130 Sewing Machine
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_5130_5232_5340_EN_208.PDF
Feed the thread thru one of the holes (the hole that will be on top) going from the middle of the bobbin thru to top. pull up about 2 inches, push the bobbin over to start winding and before pressing the foot, hold the 2inch piece sticking up. HOLD TIGHT. after the thread is wound about 25 times, stop winding and snip the 2inch piece level with the top of the bobbin. Finish winding.
Apr 13, 2009 | Brother XL-5130 Mechanical Sewing Machine
Tension problem on Brother ES 2000
I have a Brother CE 4000 Computer sewing machine. I had the same problem when I first used it. I worked with it several hours but to no avail so I decided to stop and wait until my head clear..
I went back a couple of days later. Reread the manual and started over. I discovered my problem was that I was threading the bobbin wrong. Once I threaded it precisely as the manual stated it worked fine.
So this might be your problem. Make sure that the thread on the bobbin is wind on properly. It should be wound evenly. The bobbin must be threaded precisely as the manual says.
Try rethreading the bobbin and the machine
and see if that help.
Feb 27, 2009 | Brother ES2000 Computerized Sewing Machine
Brother XL-2600I Logo
188 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
