Can i run a dw55t haas deluxe 127v-60hz in the uk
I would like to know if i can run a dw55t haas deluxe 127v-60hzin the uk if i buy a converter and where would i purchase one
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Contact a electrian.
Posted on Apr 01, 2014
Is it possible to use this turntable from UK 220V 50Hz, in the US 110V 60Hz?
Go to Radio shack or other electronic places and buy the correct converter for it.
May 18, 2015 | Audio Players & Recorders
What sort of step down transformer should I buy to use the cuisinart hand blender (US plug), in the UK?
http://lgcdn.220-electronics.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/5/0/500-watt-voltage-transformer-regulator-type4.jpg
It is actually a step-up transformer you need- from 120v to 220 v.
There are many of these transformers or converters listed on the web. Do a search " 120 v 60 hz to 220 v 60hz converter. "
The critical feature is to have a converter that has a wattage rating equal to or greater than the appliance that is plugged into the converter. It is best to a converter with a higher wattage rating than the appliance beacuse most appliances have a surge of current at initial startup.
May 05, 2014 | Cuisinart CSB-79 Smart Stick 2-Speed...
Replace power supply
Are you sure the power pack has failed? That should be straightforward and fairly cheap. Note carefully the model and type on the present one, then shop around.
  • Power Supply
    Internal 220W (100V-240V)
    Form factor: Internal for slim form factor
  • Total wattage: 220W
  • Nominal input voltage range:
    • 100-127V/6A (50-60Hz)
    • 200-240V/3A (50-60Hz)
  • Dimensions: 200mm x 85mm x 53mm (7.9 x 3.3 x 2.1 inches)
  • This power supply has an LED to indicate a possible failure condition when the LED is off and power is connected.
Feb 20, 2014 | HP Pavilion Slimline s5710f Desktop PC
Hi i have an alba lcd32880hdf 32" which i bought about a month ago from argos. its for my childs room. he has an xbox 360 and some games only play on 60hz. the telly says its a 50hz but in the...
Hi, I`m having the same problem aswell, It happend to me 2 days ago, i even took the xbox back and after some Hoo Haa i got a new one but that didn`t solve the problem,I`m going to buy a HDMI cable for £14.to see if that works, i`lll keep you posted.
May 22, 2011 | Televison & Video
Thorens TD 166 Mk V1 (UK). Have moved to Canada
Just a thought but wouldn't it be easier to find some kind of power supply converter to knock the 60HZ down to 50HZ?
Jun 13, 2010 | Audio Players & Recorders
Hi! I am interested in buying the Cuisinart Programmable Conical Burr Mill CBM18. I am thinking of buying it from a US and bringing it in to the UK and use together with a step-up mains transformer to...
Colinchee, this sounds like a rather complicated electrical engineering issue. Why not buy a coffee grinder in the UK design and rated for your power? It might even be cheaper and the guarantee will cover design flaws. Regards.
May 26, 2010 | Cuisinart Supreme Grind CCM-16PC Grinder
How do I convert the electrical wiring to run on
if you mean the plug and receptacle are not compatible then if you have 230 volts just hard wire it in place i.e. omit the plug and receptacle, but beware in the U.K. they are at 50 hz. not 60hz. like in the U.S.A. and if its an electronically operated dryer you may have problems with its operation due to the frequency difference
Jul 08, 2009 | Dryers
Voltage on Acer Aspire One -110 - 220?
It is 100 - 240 V.
All you needs is the Votage adapter, no converter needed.
Acer Aspire one rating 11.1V laptop battery. Charger Specs: Input Voltage: 100 ~ 240V AC 0.24~0.60A 50/60Hz Output Voltage: +12.6V DC Output...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 14, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Need to convert my 110 volt 15amp to 240 volt
You can buy a transformer which allows all 110v power tools to work from a 240v supply. You will also need to change the plug on the compressor to a yellow 110v type. You can buy transformers for around £25 and around £3 for the plug
Mar 29, 2009 | Craftsman Air Tools & Compressors
Crown XLS 802 D Amplifier Transformer!
You will need AC to AC converter that will accomodate US to UK mains. Look for power requirements of your amp on name plate and match with available converters online. Make sure power line frequencies match in/out requiremnts
Apr 17, 2008 | Crown XLS 802 D Amplifier
Washing Machines Logo
130 people viewed this question
Top Washing Machines Experts
